Hotpoint wmf740 the dial for the programmes just spins around without clicking and the machine is stuck on pump cycle. Can anybody help?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 129 Answers
YOUR PROGRAMME DIAL HAS THREADED SO YOU WILL NEED A NEW ONE, YOU CAN GOOGLE THE PART FOR AN EXACT PRICE
Posted on Dec 29, 2013
SOURCE: programme dial again
yes thats your problem,the reason it wont unscrew is because of things caught inside ie coins gunk you will have to take out machine turn on side,there are two sometime four screws at front of machine where black dail is remove these,when machine is on its side you can acess pump from underneath,there is a black rubber hose which goes from drum to pump which is held on with a circlip remove this at pump end you will need a vicegrip,remove all gunk coins ect, refit all back to machine ,,problem solved......the reason dail was turning was because it was looking for progam to release water which it couldnt because of blockage,after tou unblock you will find that black srew on cover on front can be removed(always better to check for blockages every few weeks hopes this helps
Posted on May 23, 2008
SOURCE: Washing machine will not drain
I have a maytag washer that when it fills with water it wont drain out..the spin cycle just makes a noise and it wont do anything..any ideas what i can do to fix it thanks
Posted on Nov 24, 2008
SOURCE: Beko wma1510s washing machine dial problem
my beko wma 1510s will not spin and is heating up
Posted on Jan 03, 2010
barkencoa
  • 3463 Answers
SOURCE: Hotpoint Aquarius 1100 WM63 Not Spinning Clicking Programmer
I would suggest you check the brushes in the motor, as it sounds like they are worn out.
Replace them if they are less than 3 or 4 mm long
This would give you the symptoms you are describing.
Please rate my solution.
Thankyou.
Posted on Feb 09, 2010
miket756
  • 2702 Answers
SOURCE: Hotpoint aquarius WMF740 (1 year old) - noisey spin
its the drum bearings there worn out try opening the door and lifting the top of the drum with your fingers if there is any life and the drum drops back when you let it go its them bearings,, then spin the drum by hand is should grumble or growl,,,if it dont do any of this, it could be the "spider" broken off, its an ally part that holds the drum bearings and the drum up,
Posted on Mar 07, 2010
Washing machine not selecting cycles. It is stuck on fast wash, dial moves but wont click and select any other cycle.
Hi
the problem is the shaft on the control knob
is cracked so the knob turns but won't grip
the shaft on the control panel
requires an new knob
Jun 06, 2016 | Hotpoint Washing Machines
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Hi my hotpoint Aquarius wmf740 dial is just spinning no clicks is there an easy fix
try to tighten the screw using a small screw driver or try to pull the knob and give some paper packing and fix it then rotate the knob to the desired position
Dec 10, 2014 | Washing Machines
Apr 11, 2009 | Washing Machines
Hotpoint WF340 - wont complete programme
hi without looking at it i would think that the control board behind the timer knob has broken down these can quite pricey so shop around before you buy one,hope this helps.
May 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
