Question about Lexmark Interact S605 All-in-One Color Inkjet Wireless Printer
Touchscreen parts touchscreen control panel does not display anthing.
    Problem Solver:
  • 6 Answers
How to clear the cm2320 mfp printer,
note: printer switch on 50.2 fuser error
Posted on Dec 29, 2013
How do I calibrate the touch screen on a Konica 7165?
To adjust the touchscreen sensitivity, perform the following:
1. Power the copier OFF.
2. Access the Key Operator Mode (Power the copier ON, while pressing the [HELP] key).
3. Touch [10. Control panel adjustment] on the touchscreen to display the control panel adjustment screen. Note: If the touchscreen is so far out of adjustment that there is no response when touching [10. Control panel adjustment], the control panel adjustment can be accessed (at this point) by touching any numeric key on the 10-key pad.
4. Touch the + at the upper right corner of the touchscreen lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Check the coordinates displayed in the top line at the top of the touchscreen.
5. Ensure the X coordinate and the Y coordinate displayed in the message area fall within the standard values. The acceptable values are on the second line.
6. If the values are not within the acceptable parameters, repeat Step 4 until the values are acceptable.
7. Touch the + at the lower left corner of the touchscreen lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Repeat the process used for the upper right coordinate until acceptable values are achieved.
8. As verification of a correct adjustment, touch the [CHECK] icon at the upper left and lower right corners. You should hear a beep tone for each one. If a beep tone is not heard, repeat the adjustment.
9. Power the copier OFF/ON to exit the Key Operator Mode.
Nov 04, 2014 | Konica Minolta Office Equipment & Supplies
C2525e touch panel not working
Run a business card between the touch screen and the outside surround. Dirt or dust can make the screen believe that you are constantly touching the screen which will lock up the touchscreen. Try adjusting the screen brightness by adjusting the thumbwheel located at the far top of the display panel.
If this does not rectify the fault then the touchscreen will need to be replaced.
Mar 08, 2014 | Kyocera Color Copier, Km-c2525e
Screen wont show
Many Kyocera Models have a little round contrast knob on the control panel. Sometimes they get moved. Check that first. If not the control panel will likely have to be replaced. KM series copier LCD display/Touchscreen assemblies had a tendency to de-laminate at the ribbon cables and lose connection
May 18, 2013 | Kyocera Office Equipment & Supplies
Mx-3000 screen display
It is not possible to get its display as sare part.
May 02, 2012 | Universal Remote Control MX-3000 LCD...
Touch screen do not work when touch on any icon
Your might need touchscreen configuration. Please follow the below solution.
If you are asking about the touchscreen of your desktop PC then I would suggest you go to control panel and look for ELO Control Panel where-in you will be guided to touch three targets on the screen. Then Verify the touchscreen if it is working and aligned properly. If you need to align further then go back to the ELO control panel and repeat the process.
Jul 16, 2011 | Computers & Internet
Touchscreen stopped working
HERE'S A LINK TO REPLACEMENT SCREEN... http://www.cellulardr.com/motorola-cliq-xt-mb501-faceplate-with-touch-screen-digitizer-and-lower-navigation-keypad-assembly-with-flex-cable-tmobile-quench-front-housing-frame-with-touchscreen-lens-glass.html?cat=248
THIS IS THE SITE: THERE ARE TWO DIFFERENT SSCREENS, ONE WITH THE WHOLE FRONT PANEL FOR $100.00 AND ANOTHER WITH JUST THE SCREEN PART FOR $89.00 YOU CAN CALL: Call 818-553-2700 OR HERE'S THE LINK: http://www.cellulardr.com/motorola-mb501-cliq-xt-main-lcd-display-screen-with-flex-cable-tmobile-quench-main-lcd-display-module-with-flex-cable.html
Dec 17, 2010 | Motorola Mobility CLIQ Cell Phone
The touch screen has stop responding. All the other buttons on the control panel work and change the display on the panel accordingly, but you cannot select any options from the touch screen. Any...
PROBABLE CAUSES:
1. The control panel adjustment is incorrect. This adjustment will shift the position of the touch sensor of the LCD unit. Perform the following steps:
a. Hold the Help key and turn power ON.
b. Touch selection #10 (control panel adjustment) on the touchscreen to display the control panel adjustment screen. Note: If the touchscreen is so far out of adjustment that there is no response when touching #10, the control panel adjustment can be accessed (at this point) by touching any numeric key on the 10-key pad.
Two + (plus signs) should be visible on the screen.
c. Touch the + at the upper right lightly with a touch pen (something with a round tip which is made of resin is recommended as a touchpen). Check the coordinates displayed in the top line at the top of the screen.
d. Ensure the X coordinate and the Y coordinate displayed in the message area fall within the standard values. The acceptable values are on the second line.
e. If the values are not within the acceptable parameters, repeat Step 3 until the values are acceptable.
f. Touch the + at the lower left lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Repeat the process used for the upper right coordinate until acceptable values are achieved.
g. As verification of a correct adjustment, touch the CHECK keys at the upper left and lower right corners. You should hear a beep tone for each one. If a beep tone is not heard, repeat the adjustment.
h. Turn the machine OFF to store the adjustment. Turn the machine ON normally and check operation of the touch screen.
Dec 09, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
The Touchscreen don't work sometimes. I wish to
If you go for the replacement option, the LCD screen assembly (part # 8204689) runs over $200, and the control unit assembly (part # 8205408) runs about the same.
You can order them here.
But we regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jun 04, 2009 | Kenmore 63792 Microwave Oven
Touchscreen is inaccurate
if the POS unit runs windows go to start/control panel and look for the monitor software (ELO is a popular touchscreen) and you should be able to calibrate the screen in the options
Apr 13, 2009 | Computers & Internet
Bose 023795
Water damage on these types of devices is rarely recoverable.
You can contact Bose directly to enquire about how to order spare parts.
http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/faq/product_faq8.jsp&ck=0
Jerry G.
Jul 15, 2008 | Bose 023795 LCD Touchscreen Remote Control
Lexmark Interact S605 All-in-One Color Inkjet Wireless Printer Logo
56 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
