Question about VOX AC30HW2X Amp Combo
Pilot light problem
The pilot light bulb stopped working, there is no identifiable markings on the bulb, not sure where and what type to get to replace it. Would one , I believe 47 commonly used for fender work, 6.3 volt?
    Problem Solver:
  • 11 Answers
Most power lights are line voltage, i.e. 12v power=12v lamp, 120v power=120v lamp. Get a voltmeter and see what voltage is goin' to the lamp. Once you have determined that,, 12v lamps are easily found @ auto parts stores. 120v @ Radio Shack or electronics supply stores.
Posted on Dec 30, 2013
What is the meaning of the song 3 rounds and a sound'
Hello, Rebecca -
See this May 2012 article of an interview with Israel Nebeker of Blind Pilot in the magazine American Songwriter:
http://americansongwriter.com/2012/05/chatting-it-up-with-blind-pilot/
Starting with paragraph 14 the inspiration for the lyrics for "Three Rounds and a Song" is discussed.
Note: I took the liberty of re-categorizing your question to the Music category from Cars & Trucks, where it initially landed.
Best wishes.
May 18, 2018 | Music
I replaced Can I change the tubes on my fender blues deluxe reissue from 6l6 to 6v6 power tubes
An internal component has failed. Without it in front of me for testing I cannot say which. You need to takje it to the repair shop.
Jan 28, 2016 | Fender BLUES-DELUXE-REISSUE Tube Guitar...
I'm not sure how to put the string swing ukulele hanger inthe wall!!
It should come with mounting hardware, including screws and anchors. You'll need to:
1. Locate a stud in the wall.
2. Position the hanger where you want it.
3. Mark where the screw holes are.
4. Using a 1/8 in. drill bit, drill pilot holes on the marks you just made.
5. Put the hanger back up to the holes, and insert the screws.
If you have to use wall anchors, these should go in after drilling the pilot holes, but before screwing down the hanger.
If you need any clarification, let me know!
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Feb 09, 2011 | String Swing Ukulele Wall Hanger w/ Wall...
How do I replace a fender 2 x 2 deville pilot light? CL
You unscrew the plastic dome over the bulb. The bukb is a bayonet base. Push in and turn... probably counterclockwise and extract the bulb. Replace by reversing the process.
Use T47 or #47 (6 volt) lamp... available at Radio SHack and other places.
Jan 23, 2011 | Fender R) Hot Rod DeVille III 212 Guitar...
My Valveking isnt working at all, the light wont come on, i can hear the power on in it but the tubes wont warm up, i dont know if they are blown or what but im not getting any sound response other than...
There is a fuse in the heater power to the tubes and also the pilot light. In some of the Valvekings it is labeled F203... not sure on your particular unit. In this one it is shown as a 3 amp fast blow. Since it feeds a bridge rectifier diode, it is possible a diode may be shorted or a couple electrolytic capacitors that follow the bridge.
Dec 08, 2010 | Peavey Valveking Vk100 Guitar Head
Fender HRD - clean channel works fine, drive & more drive VERY low volume, like a headphone across the room w/ all 3 volumes at 10. LED works fine in drive/more drive. All same w/ footswitch,...
Wayne, There's a time to take the amp to a pro shop andf get it done right. It' saves time and headaches, and also keeps you from inadvertantly smoking other parts or yourself. Now is that time.
Apr 17, 2017 | Fender Hot Rod Deluxe Guitar Combo...
My Orange amp recently stopped working, as in no sound
The pilot light means NOTHING other than the switch is on and unit is getting power from a receptacle.
There is an electronic failure that requires servicing and until unit is opened and analyzed we can''t help you further. Take it to a shop or a person experienced in electronic repair.
May 09, 2010 | Orange Rockerverb Rk100htc 100watt...
Amp doesn't do anything.
If you hear a pop when you turn it on and the squeak when turning off most of your amp is probably working.Depending on whether it is a tube or solid state amp there are several things to consider some being as simple as a deadLED or bulb in the pilot light and a defective input jack to as complicated as a dead power supply to the preamp circuitry. If you are not familiar with safety procedures and electronic trouble shooting and have no test equipment and the schematic you might be better off having it serviced. Here is a link to a troubleshooting guide:http://www.geofex.com/ampdbug/ampdebug.htm A lot of the info can be applied to solid state amps. Hope this helps.
Jan 19, 2010 | Music
Crate amp blew a house fuse and stopped working. pilot light still works and I can get a distorted signal through the headphones if I play a guitar very loudly through it.
When a piece of equipment causes a fuse to blow or a breaker to trip, it normally means something in the equipment's circuit was shorted. Either because of heat, moisture, a loose screw, loose wire, loose part, a bug, etc. For safety reasons, don't plug it back in and take it to a repair shop.
Hope this helps!
Jun 04, 2009 | Crate Music
I have a 20 watt peavey micro bass, and what happened was my brother knocked it over and will not turn on. I checked the fuse and it was ok, any help you would be great.
When it was knocked over it may have cracked the main circuit board, but does the pilot light come on at all? If the pilot light comes on but no sound is output from the speaker try plugging some headphones into the head phone jack and then turn it on and see if you can hear sound in the headphones. I have had a similar problem before and the main speaker had gone bad but it would still play thru the head phone jack.
Apr 22, 2009 | Music
VOX AC30HW2X Amp Combo Logo
57 people viewed this question
Top VOX Music Experts
rhodesworks
David
David
Are you a VOX Music Expert? Answer questions, earn points and help others
