Question about Bosch Dishwashers
Water does not make it to the jets
I have a Bosch Diswasher model SHU4016 UC/06 It has been setting for a while because we thought the timer was bad. Come to find out the out let was working intermittently. Now the soap has been setting and i think it may have clogged something as the the machine runs, water gets to the unit but nothing comes from the jets. Please advise.
  • 25 Answers
You need to take a flexible wire and stick it in each of the jet holes, all of them. Then run the machine, so the water can dissolve the soap. repeat the process w/o dishes/ soap (lather rinse...repeat)
The Best!
Posted on May 19, 2009
Bosch Dishwasher model #SHU3002UC-06 continues to run on any cycle, does not stop at the timer shut off spot
Anti flood device in a lot of german machines and pump keeps running only way to knock it off is too un plug what has happened water has leaked possibly over a period of time ,and set the anti flood device off if ya disconnect macine plug and drain hose and lie on its side water will drain off anti flood put some towels to catch water and macihne should work after ya reconnect
Nov 01, 2015 | Bosch Dishwashers
Bosch Diswasher
Remove the drain hose and check if you have any residual into it. After 11 years your appliance may need a thourought cleaning.
Check also if the pump has enough pressure.
Apr 22, 2008 | Dishwashers
Bosch SHU4006 UC/06 Dishwasher will not fill with water and timer does not advance. Voltage to Water Valve Solenoid does not toggle when timer knob is manually advanced through all cycles.
If you have power to water valve when it is supposed to fill yet doesn't the water valve is bad, as long as their is a good water supply to the valve. Sometimes espically if it has one of those flexible stainless steel braided hoses something in cabinet could have pinched it,
Good luck,i hope this helps
Gene
Aug 01, 2011 | Bosch SHU4006 Dishwasher
I have a built-in Bosch dishwasher SHU 4302 UC. It no longer drains the water out at the end of all the cycles. I have tried everything mentioned in the booklet (make sure water is hot, use the jet-dry...
The problem is a solenoid on the bottom of the unit. It is a small black cylinder next to the pump. It operates the valve that changes to the drain cycle. You can probably order one from Bosch
Aug 18, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
We have a +11 year old Bosch SHU3006/UC/U06 that never leaves the wash cycle. We had to stop it during our last test run at 3 hours. Chat advise is suggesting a water temperature problem (I origionall...
Check continuity of the heating element to see if it is broken/open.
The dishwasher prefers that the incoming water (water heater) be 120 degrees (F)
Apr 04, 2009 | Bosch SHU3036UC Dishwasher
Diswasher wont fill
Faulty fill valve?
Timeing out with insufficient flow of water?
Hot water to hot and locking up valve?
Apr 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher runs but does not clean
Try using a cycle that doesn't heat the water. (Quick cycle?) Using high heat rinse or sanitize will stop the timer while it heats the water. The sensor may be bad.
Apr 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
My Kenmore diswasher gets stuck between the quick rinse and drying cycle
I am having the same issue as described above. I think it is either the timer, thermostat (temp assure), or thermostat (temp boost) that needs replacing. The dial gets stucks in both the wash temp boost cycle and rinse temp boost cycle. However, I don't have a picture of the temp assure or boost part. Does anyone know how to fix this? Thanks. -Bill
Aug 31, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
150 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
