Question about Kenmore 45081 Front Load Washer / Dryer
The water won't drain and the drum will not turn. The washer will fill with water but makes no other sound.
    Sergeant:
  • 187 Answers
please chk this link
http://www.acmehowto.com/howto/appliance/washer/diagwasher.php
please rate my suggestion...
Posted on May 22, 2009
The motor is running but it won't turn the belt on my front loader ge washer
It definitely sounds like the belt is stretched, worn-out, and in need of replacement.
Jul 30, 2014 | General Electric Gfwh2400lww 4.9 Cu. Ft....
Washer fills but won't agitate or spin
Try making sure the belts are actually on the drum, probably have to turn upside down. Sounds silly but a lot of simple things are missed.
Apr 02, 2012 | Whirlpool Washing Machines
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
May 18, 2010 | Whirlpool LHW0050PQ Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Whirlpool AWN 321 washer continues to drain water out of drum throughout the whole wash and rinse cycles. The consequence of this is the machine continually draws in hot and cold water to achieve the...
This sounds like a siphon condition. Remove the drain hose (the thicker black hose from the back of the machine) out of the wall. Now re-insert it back in only 6" going into the drain. When they go in too far, the drain in your house that prevents odors from coming back out of your drain causes a siphon that pulls the water back out when the washer is filling. Make sure to tie the drain hose down with a tie so it does not pop back out when the washer is draining/ spinning.
Jun 30, 2008 | Whirlpool Washing Machines
Washer filled up with water when not turned on
It sounds like the water inlet valve assembly is letting a trickle of water thru when its not supposed to. It is located on the rear of the washer, it is the part the water hoses connect to. Make sure the power and water are turned off, then disconnect the water fill hoses. The valve is attached to a bracket, the valve will have 4 electrical selenoids on it and a hose leading further into the machine. Make a drawing of where the wires/colors were attached before you pull them off. The valve for that machine (MLG2000AWW or MLG2000AXW) usually costs about $45.00 to $55.00
Jan 19, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Kenmore 45081 Front Load Washer / Dryer Logo
82 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
