Question about Little Tikes Toys
Little tikes The pinhole for the front wheel is drilled to the rear but the instructions and pin guide are to face forward?
    New Friend:
    Problem Solver:
  • 17 Answers
Have you tried flipping the wheel? wheels comes in pairs, fronts and backs, so maybe you've switch it up?
Posted on Jan 16, 2014
  • 60 Answers
SOURCE: i need four tires for my little tike adventure wagon 9x9 wheels
Contact little tikes directly. They may still sell replacement parts for your wagon depending on the model number.
Posted on Mar 11, 2009
  • 4234 Answers
SOURCE: Little Tikes Cozy Coupe red plastic wheel caps
The caps are a type of "acorn nut". Check a local hardware store (not the big guys) for this type of fastener and bring the shaft with you to get the correct size. These should not cost more than about $.50 each.
Dan
Posted on Apr 09, 2009
SOURCE: Converting Little Tikes Roller Blades
My nephew has these skates and I just converted them from the training position to the inline position. The skates come with a bag of extra parts that you need to make the conversion. Basically you need the same bolt that is used for the first wheel and the middle wheel since the back two wheels are mounted on a long bolt that doesn't work for just one wheel. If you didn't get these spare parts then you're probably out of luck. If you're converting to the inline position you might be able to just use the front and rear positions but the plastic frame may not be strong enough. Good luck!
Posted on May 10, 2009
slave2aslave
  • 302 Answers
SOURCE: Little Tikes replacement wheels
http://www.littletikes.com/consumerservice/ReplacementParts-detail.aspx?Product_ID=3564&#
This should help.
Posted on Oct 04, 2009
  • 34 Answers
SOURCE: Lost Instructions for Little Tikes My Real Digital Video Camera
For those having trouble utilizing a memory card, turn on the camera and press right arrow key for 5 seconds until blue screen pops up. Press RC button until screen shows a camera image on left and memory card image on right titled "storage". Then press right arrow key to select memory card.
For those who lost or misplaced the instructions, you can email them using the contact us page on their website. For faster service, you can call their number, 1-800-748-2204, and request the instructions. I received the instructions in two minutes.
Hope this helps!
Posted on Feb 22, 2010
The wheels on our Little Tikes Cozy Coupe do not turn/swivel easily
Not a solution but I wondered if you ever sorted this? I have same problem with one front wheel only... Just seems too snug a fit to the main body...? Any suggestions?
Dec 04, 2012 | Little Tikes Cozy Coupe
While changing rear tire, my deraileur came off. The chain seems to be snarled up. I don't know how to ge the deraileur back on correctly. Thanks for your help.
With the wheel off remove the two pins which locate the guide wheels on the deraileur. Take off the guide wheels and the guide plate. Now straighten the chain and unwind the snarled area. Locate the chain around the smallest cog wheel on the back wheel and mount the wheel to the bike. The chain will hang slack. Now mount the upper guide wheel and guide plate to the deraileur making sure that the chain feeds off the rear cog and passes around the guide wheel towards the front of the bike. Push the deraileur forwards relative to the chain and slip the lower guide wheel in between the guide plates and pushing the chain back in the guides & fasten with the pin. As you reassemble the plates and wheels on the deraileur be sure to observe carefully which way the chain is running. It is quite logical and this should prevent mistakes being made
Oct 03, 2010 | Mongoose Exile 26 Men's Full-Suspension...
I now have the software installed. Horn works, I
i have cd and used it in autorun the horn works but the car does not forward can you help
Dec 11, 2009 | KB Gear Little Tikes 3D Cruiser (1727)...
Little tikes cozy coupe
Try replacing the screw. If you cant, get a long thin bolt and nut to replace it.
Jun 15, 2009 | Little Tikes Swing Along Castle
Where to find bushings for front wheels of little tike wagon?
You can try these push nuts from this site:
http://www.shopjandl.com/0801-0226.html
I don't know what size of axles you have on your toy, but these fit my little tikes hummer wheels.
Hope this helps
Jun 01, 2009 | Little Tikes Adventure Wagon
I need to remove the rear tires on a little tikes hummer h2,
I would take a pair of pliers and pull off the push nuts.
You have to replace the push nuts with new ones, but when you purchase the little tikes hummer wheels from http://www.shopjandl.com/kids---baby-ride-on-toys-little-tikes.html
they provide the push nuts with the wheels
May 31, 2009 | National Little Tikes Hummer Yellow
The reverse gear is not working
You have to pull the push nuts off the rear axles with a pair of pliers.
I would check to make sure the motors are connected secure to the gearboxes. Usually if you have a gearbox problem it also affects the forward speeds.
The little tikes gearboxes are found at http://www.shopjandl.com/884931300.html but I would make sure the motors are secure to the gearbox.
hope this helps
Mar 23, 2009 | National Little Tikes Hummer Yellow
Toys Logo
47 people viewed this question
Top Little Tikes Toys Experts
 Russ Hill
Russ Hill
Brett Duxbury
Brett Duxbury
Bill Boyd
Are you a Little Tikes Toy Expert? Answer questions, earn points and help others
