Question about Kenmore 24 in. 16032 Built-in Dishwasher
Dishwasher not draining
Water standing up in bottom of dishwasher after cleaning not draining I have same problem and no garbage disposal. Water pumps out of dishwasher but then water comes back in from the drain. I recently had a clogged sink. I used a drain cleaner that may have gone down that drain hose too. Maybe that "ate" through a baffle or one way valve. Something must let water out but not back in.
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
r
Posted on Sep 29, 2010
Had problem with outlets in kitchen, now dishwasher turns on, fills and then shuts off... standing water in bottom.
Since the drain pump will pump the water out using the "cancel/drain" button, if it did not work then your problem is likely to be in the drain hose system or the garbage disposal downstream from the drain pump. Check for kinks in clogs in the drain hose. Grease can build up in the portion of the drain hose just before it attaches to the garbage disposal.
Sep 08, 2010 | Dishwashers
Dishwasher won't drain- standing water in bottom of machine after cycle finished
Since the drain pump will pump the water out using the "cancel/drain" button, your problem is likely to be in the drain hose system or the garbage disposal downstream from the drain pump. Check for kinks in clogs in the drain hose. Grease can build up in the portion of the drain hose just before it attaches to the garbage disposal.
Aug 31, 2010 | KitchenAid Dishwashers
Water didn't drain, left in bottom of washer tub
I had similar problem and it ended up being a clog at the point where the drain hose meets the garbage disposal. I had to unhook the hose and clean out the food that had accumulated (horrible smell). You may have to stick a screwdriver into the garbage disposal hole where the hose fits and clean the food out there also. Then put the hose into a bucket and run a few cycles to ensure the hose is free.
Aug 01, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher drains but leaves behind about 1/2" of standing water
Water standing in the bottom of the tub is normal.
A small amount of clean water around the outlet on the tub bottom at the back of the tub keeps the water seal lubricated.
Jun 22, 2009 | GE Nautilus 24" Built-in Dishwasher
Need Help Regarding Draining Problem
you might have a blockage in your air gap or your garbage disposal line. check those areas first. do you hear the pump humming and not pushing any water through or do you hear is poushing the water through but just trickling through the garbage disposal? let me know
Jun 02, 2009 | Dishwashers
Dble sink, one with the garbage disp. won't drain standing water
It's a drain clog within the disposal. Try a drain cleaner, if no luck, you will likely need to replace it.
Feb 18, 2009 | GE 24 in. Profile PDW7800 Built-in...
Water won't drain out of it after cycle
  • Check sink drain and drain hose for restrictions
  • Unjam the motor
  • Unjam the pump
  • Check the drain valve
  • Check the drive belt
  • Test the timer motor
  • If you have a brand new dishwasher or garbage disposer, check the knock out plug on the garbage disposer
  • Hope this may help;
    Regards,
    VOTIT
    DON'T FORGET TO RATE;
    Sep 16, 2008 | Hotpoint 24 in. FDW60 Free-standing...
    Oe code on LG dishwasher following garbage disposal replacement
    Hi. I just had the same trouble. Your garbage disposal comment there gave me an idea. The drain hose from your dishwasher likely goes to the garbage disposal and then out the drain. My hose had a little blockage at the joint where the hose goes into the disposal. I was able to clear it just by giving it a wiggle....all is well now.
    Good luck.
    Sep 01, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
    Kitchenaid dishwasher - water standing at end of cycle
    less than 2 cups of water in left after cycle complete
    Dec 02, 2007 | Siemens 24 in. SE25A266 ExtraKlasse...
    Kenmore 24 in. 16032 Built-in Dishwasher Logo
    339 people viewed this question
    Top Kenmore Dishwashers Experts
    Ken Johnston
    Ken Johnston
    Level 1 Expert
    Fred Sops
    D. E. Hev
    Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
