Question about Centrios Wrist Strap Blood Pressure Monitor
Instruction manual have a 631-8302/05A04 Centrios Wrist Strap Moniter. No manual. How to start?
Welby blood pressure monitor instructions
This is a good question. Does someone have a manual to upload?
Feb 27, 2013 | Centrios Wrist Strap Blood Pressure...
Gives wrong pressure readings. also shows only error on pulse. can be repaired or buy new one. if fixable where to send to
You didn't mention how long you've had this wrist monitor, but it may be a case of it not being used properly. For it to work best, you need to keep your arm/wrist still at heart level. Place the cuff on your wrist, at least 1" above the heel of your hand. Be sure the strap is fitted snugly ground the wrist before starting the unit. Then remain still. Don't flex or shake your wrist during the testing procedure. You may also need to change the batteries.
If none of the above solves the problem, most BP wrist monitors have a 5 year limited warranty (check your Owners Manual for yours) and will allow you to return to them for repair or re-calibration. But you must have their approval before sending it, as well as your Proof of Purchase.
Hope this helps you to solve the problem.
Mar 28, 2011 | Centrios Wrist Strap Blood Pressure...
I need to set up the centrious puls teck heart monitor watch, model #6318143, please help
I don't have manual but to reset ..press SET and and ALM together. will beep 3 times.
First set age, then max heart rate, (not sure of next item mine came up as 040), then set 24 hr or 12hr, then set hour, last set minute answer_thread2_side.jpg
Mar 22, 2011 | Centrios Wrist Strap Blood Pressure...
Always shows to high pressure pulse to low
Be sure that you are applying the wrist monitor properly. It should be placed on the wrist at least 1/2" from the up the wrist from the heel of the hand. Tighten it snugly and inflate. Remain very still, until the process has been completed. Also, keeping your wrist at heart level, will provide a more accurate reading. If you doubt the reading you get, switch to the other arm/wrist and take it again. If you get the same thing, it's probably accurate..
Feb 12, 2011 | Centrios Wrist Strap Blood Pressure...
It always indicates error on the wrist monitor even though i changed the batteries and place myself in the right position at heart level . is there something wrong with the monitor.
You can try BOTH wrists, not that this should make a HUGE difference, usually it is the actual pressure itself. I would try to use to machine on someone else and make sure that your actual pressure(meaning the amount of blood, rate of flow) can be monitored with a wrist model. Some people are forced to use a arm style..... take care... Guy
Sep 17, 2010 | Centrios Wrist Strap Blood Pressure...
Error 5
#5 error keeps coming up when bp taken with new batteries
May 30, 2010 | Centrios Wrist Strap Blood Pressure...
Centrios wrist BP monitor, model 10A03. When pu...
centrios wrist monitor works to inflate and deflate monitor but displays "1" instead of blood pressure reading
May 21, 2010 | Health & Beauty
My centrios blood pressure monitor starts working and then quits with an err 5 what is this?
Hello there:
Normally if the blood pressure is too low you will have a error but this could be caused by the battery being low
So what i would suggest is to first double check the battery by taking it out of the monitor and pressing in the power button and holding it for 10 seconds this will clear the machine now put the battery back in and power up the unit ** note when using the monitor always make sure that the arm is crossed against the heart and that the machine is on the wrist properly and is facing the right way then try this ok?
Hope this is very helpful for you
Best regards Michael
Feb 25, 2010 | Centrios Wrist Strap Blood Pressure...
With fresh batteries I get an error 1 displayed
Dear bjamijeson81: Try using LITHIUM batteries that are used in high tech. electrical devices. Regular or alkaline may not be strong enough. Dr Ron Grassi,DC.,MS.Jupiter,Florida.USA.06a10c6.jpg
Oct 12, 2009 | Centrios Wrist Strap Blood Pressure...
Centrios Wrist Strap Blood Pressure Monitor Logo
51 people viewed this question
Top Centrios Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Centrios Health and Beauty Expert? Answer questions, earn points and help others
