Question about HP Office Equipment & Supplies
Not on network
I have Hp laserjet 3052 printer and I tried to connect on network by using Rj45 from a router, but I can't find the printer on network. I want to directly connect to the network rather than connecting my computer with a caple. so, can somebody help me do this?
    Problem Solver:
  • 6 Answers
My Printer Absorber Full Solution
Posted on Dec 29, 2013
  • 68 Answers
SOURCE: I would like to network
What model of HP LaserJet do you have?
You will have to go into the configuration menu on the printer itself and set up the network connection.
I don't know what model you have, but here is a generic answer
Press the Menu Right until you find the HP MIO Menu - Select it. Next press the Item right button until you find the Cfg Network Card = No, - make it say yes by pushing the value right button, then push select to put an asterisk ( * ) next to it. Then press the item right button until you find Cfg TCP/IP = No, - make it say yes by pushing the value right button, then push select to put an asterisk ( * ) next to it. (assuming you are on a basic network) Last press the item right button and insert the following information.
IP Address: Not one already in use - generally 192.168.1.XXX (where XXX is some number between 2 - 253) Subnet Mask: generally 255.255.255.0 Gateway IP Address: Generally 192.168.1.1 or 192.168.1.0 or 192.168.1.254
Once you give it this information, print out the config page and it should be there. If this doesn't work, or you don't know how to find those numbers, I would be glad to help you further.
Posted on Dec 04, 2008
vincent721
  • 240 Answers
SOURCE: connection of HP PSC 950 All-In-OneInkjet to Wireless N network
since your printer dont have NIC or network card..there are 2 option to connect it to your local network
Option 1
Go to Control Panel
Select Printers and Faxes
Right Click on the Printer icon
Select Sharing
then Configure it
Option 2
Buy Print server Port (Wired or Wireless)
depends on cable interface on your printer (USB or Parallel)
Posted on Mar 13, 2009
SOURCE: Canon MF4370dn printer network connection problem
I had the same problem. I entered the info manually and it works. You could follow the instructions on how to do it manually in the e-manual (on the CD).
To get the IP, subnet mask, and default gateway: open a command prompt from windows. At the command prompt, type "ipconfig" without the quotes. Write down the IP address, subnet mask, and default gateway.
For the IP, for example, if what you have from the step above is 192.168.0.100, add 10 (so that you wont have repeated IPs by auto DHCP from the router. I am assuming you have no more than 5 machines on your network.) to the last number to have 192.168.0.110 to enter manually into the printer. Use the same subnet mask and default gateway.
Hope it helps.
Linh.
Posted on Jun 02, 2009
Geekman
  • 32281 Answers
SOURCE: HP Laserjet 4050Tn can't be found by network computers (XP)
To install the HP as a network printer you need to do the following -
1. Configure the HP's IP address so it matches the IP range of your network. eg if your IP's are 192.168.0.xxx then set the HP to a high number say 100.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer to the network hub/router and power up the printer.
4. Click on Printers an Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standart TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP's IP address.
8. Click OK and tick Enable bidirectional support and then OK
You need to setup the HP printer the same way on every computer on your network.
You can now print from any computer on your network
Posted on Sep 03, 2009
MUKHTAR
  • 2017 Answers
SOURCE: HP LaserJet P2015 Printer
in printer properties disable the power saving mode.
Posted on Jan 28, 2010
The HP 3055 network printer, connected to 3 dell inspiron laptops doesn't print...it says it's offline, even though the screen on the printer says "ready." I tried adding a printer profile and...
Check the IP of the printer, it should be manually assigned, if you are not confirmed,
  1. Press menu/enter .
  2. Use the or the > button to select Reports , and then press menu/enter .
  3. Use the or the > button to select Config report , and then pressmenu/enter .
  4. The printer exits the menu settings and prints the report.
Try re installing the printer software from the cd, or download the full version from the links below for your area
HP LaserJet 3050/3052/3055/3390/3392 Asia Pacific Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 Eastern Europe Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 North America/Western Europe Full Software Solution
(The full software solution provides print, fax and scan functionality. This software solution is the same solution as the Version 4.0 in-box CD that came with your HP LaserJet 3050/3052/3055/3390/3392.)
You can download Printer manual from the link below
Printer Manual
If you require more assistance in this regard feel free to reply to this post
Best regards-BA
Jan 20, 2011 | HP LaserJet 3055 All-In-One Printer
I have an HP LaserJet printer 4050N with RJ45 and Parallel Port. The Printer is kind of far from the WireLess router and I can't connect it. Unfortunately, my PC doesn't have a parallel port. The best...
Another option is to find an old laptop, with "wireless" capabilities and a Parallel Port.
Connect the printer to the laptop.
Connect the laptop to your wireless network.
Tell the laptop to "share" the printer.
Then, any computer on your network can "find" the networked printer, and can print to it.
Jun 12, 2010 | HP LaserJet 4050 Printer
Does hp laserjet 5200 have netword printer
Here is your network guide for the 5200n printer
If you do not have the 5200n printer, it is not network. You will need a 'print server' ($100 approx). Get USB or Parallel, depending on the connection it uses.
Mar 30, 2010 | HP Hewlett Packard LaserJet 5200 Printer
HP Laser Jet 3052 - is this a wireless printer? If so, how do you initially hook it up so the computer recongninzes it?
you should be able to go into the printer menu (on the orinter) and print out network settings to give you an ip address
Jun 06, 2009 | HP LaserJet 3052 All-In-One Printer
Unable to install the printer
if you want to install Laserjet 3052 All in One Printer
then you can download the drivers from the below link
Choose appropriate Operating System according to your PC or notebook
Download HP Laserjet 3052 AIO Driver
after download the file, double click to run the setup
and do as directed to install your printer
Remember : just turn your Printer and Do NOT connect USB cable to PC. Connect only when directed by Setup
All the best
Jan 05, 2009 | HP LaserJet 3052 All-In-One Printer
New LJ 4200N Install
simply connect the rj45 cable and create the printer using hp network printer software. you can download it from the hp website
May 30, 2008 | HP LaserJet 4300n Printer
How to install Hp laserjet 3055
If the connection is ethernet. Print configuration from Printer.
Manually install printer.
Select computer is on local port
Local port to select is TCP/IP
then type in the network address to the printer.
Driver will still be inside computer.
Mar 03, 2008 | HP LaserJet 3055 All-In-One Printer
HP Laserjet 3052
i am getting scanner error 5 in my hp laserjet 3052, pls giv me the solution for the same
Jan 29, 2008 | HP LaserJet 3052 All-In-One Printer
19 people viewed this question
Seeker5211
Seeker5211
