Question about South Side Hitmen: The Story of the 1977 Chicago White Sox
I need a story that starts with I walked down the alley way and there was a smell of old stale meat. As I turned the corner a mist rose covering the body, I tripped over.
    Prodigy:
    An expert who has answered 500 questions.
  • 545 Answers
Tell me more and I will re-write the opening paragraph for you.For instance you could start the story something like..As I walked down the alley I was overpowered by the smell of rotting flesh,and as I turned the corner a heavy mist hung in the air, cloaking what appeared to be a body......
Posted on Jun 30, 2014
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
How long do pork chops last in freezer
They can last as long as a year. Depending on how well they are covered or wrapped. Freezer burn will only affect the taste. Best way to find out if any meat spoiled is to defrost it in your refrigerator and cook it. If the meat is bad, it will start to smell bad once you start cooking it.
Mar 01, 2015 | Grilling
Rough idle smell after stopped running
If you have a strong gasoline smell, get that car into a mechanic ASAP. Forget fooling around trying to discover the problem yourself. Gas explodes, right? You already have a strong smell. That means that somewhere down the fuel system line there is an active leak and that is dangerous. The fact you have to post here means you don't know anything about a car, so stop messing around with a potential lethal problem. I am an old alley mechanic from wayyyyy back and am speaking from experience.
Apr 08, 2014 | Mitsubishi Mighty Max Cars & Trucks
Wont blow out mist
it has a quiet operation when you got it brand new did it put out mist
Nov 02, 2012 | Vicks Cool Mist V400 Humidifier
My dryer smells like an old wet wash cloth. It has a stale water smell to it and is making my clothes smell like it. I can smell it when i open the door and stand right in front of the dryer opening. the...
There is a very simple way to get rid of unwanted smells. I would suggest use a cup of white vinegar every wash to clean from stale muck and smells inside the machine.
Jul 24, 2017 | Dryers
1993 buick rivera has not been started or moved in 3 years. It has been sitting in driveway. what should i expect?
Dead battery and bad gas,should start but will have bad gas smell, after you got it running add gas and fuel additive, change all fluid, check belt's and hoses. also have brakes checked.Hope this was helpful.
Dec 11, 2009 | 1995 Buick Riviera
Doesn't get dishes clean
Remove the lower spray arm, the filter and the volute cover. Check for a foreign objects inside.
If there is nothing wrong then the pump & motor has to be replaced.
- The part number for the pump & motor assembly is AP3160640
Here are the break down diagrams for the Frigidaire dishwasher Model MDB125RGS0
Aug 22, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Can't figure out how to put the poles in the tent to set it up
Well, without a brand and year, it will be hard to figure out exactly. Here are some basics.
First thing, peg the tent down. (At leat the corners)
Next, locate the two longest poles. These are usually fit through a sleeve in the roof of the tent and attached in the corners via pegs or inserted into a pin. Put one corner in, then go to the other side and slide/bend the pole until it fits into the corner. Let it flop on the ground. Do the same for the other corner and the tent should be standing.
Next, if there are other poles, they could be for the front entrance or to support the rain guard. Look for peg holes or pins to place the poles into and that should give you an idea. (Also look up your model on the internet to give you an idea how it looks.)
Depending on where you are camping, you may not need the rain cover. It goes over the top and probably bungies into the peg holes.
Hopefully this will get you started. good luck. Alley
Aug 01, 2009 | Remington Sport & Outdoor - Others
Kenwood coffee machine stale smell
I used white vinegar and ran it through with hot boiling water about three or four times worked a treat
May 17, 2009 | Cuisinart 12 Cup Digital Thermal Coffee...
Front loader smells like stale cigarettes during cycle
Make sure that you are using high efficiency (he) detergent. Pour 2 cups of vinegar in the tub and fill the detergent tray with vinegar. Run it on the hottest, longest cycle. You can also use a Front load cleaner such as Afresh, made by Whirpool. I think that Tide makes one too. Vinegar is usually readily available. At the end of washing for the day, leave the door to the washer slightly open so that fresh air can get in and dry it out keeping moldy, milduey smell down. If it mildews, use a rag and bleach water to clean the boot seal. Hope this helps.
Apr 02, 2009 | Kenmore HE2 Plus Front Load Washer
Bad smell on dried dishes after being washed.Stale water smell.
Try Running Goo Gone Through It Although It Smells Like Oranges It Removes Stains As Strong As Sap. Also Try Running The Dry Cycle While Its Empty Two Or Three Times.
Jan 06, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
South Side Hitmen: The Story of the 1977 Chicago White Sox Logo
67 people viewed this question
Top Arcadia Publishing SC Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an Arcadia Publishing SC Vehicle Part and Accessory Expert? Answer questions, earn points and help others
