Question about LG Televison & Video
Setting up the right colour on our new Lg 42LN578V-ZE
We would like a list of the optimal settings for the colour etc for our TV to get it right.. ty.. colours are not right at the moment ty
    Top Expert:
  • LG Master
  • 74,383 Answers
Refer it user manual for details. http://google.com/+GopakumarGopalan
Posted on Dec 29, 2013
  • 146 Answers
SOURCE: Optimal Settings
There are no perfect settings. Most people leave the controlls in the middel. The controls are for you to adjust the picture to where you like it the most. Keep in mine that the picture can be different from one chnnel to the other. Try to find a happy medium for all channels.
Posted on Mar 15, 2008
  • 43 Answers
SOURCE: Connect LG 42LY95 LCD to Toshiba Laptop
Hiran
can you use the vga source from your laptop to the pc input on the LG a standard vga monitor cable will do then set your laptop to output the vga signal
Scott
Posted on Mar 23, 2008
jerryg50
  • 1667 Answers
SOURCE: lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Posted on Apr 12, 2008
  • 476 Answers
SOURCE: need settings because of rubbish picture
There is no right or wrong setting for the TV, but I find the following give about the best results:
  • Contrast - 65 maximum
  • Sharpness - 2 maximum
If these are set any higher, the picture becomes very grainy, particularly around defined shapes.
  • Contrast + - OFF
  • NR - ON (If applicable)
These settings will need to be changed for each of the following:
HDMI 1& 2
  • EXT 1, 2 & 3
  • Analogue tuner
  • Digital tuner
The problem you describe, is usually with a satellite or cable box.
Unfortunately, there's nothing much you can do about the dead pixels, but the settings may make them less obvious.
Posted on May 02, 2008
SOURCE: TV buzzing when showing whites and bright colours
I had the same problem when I connected my new At&T cable to the tv card in my PC. I did a little internet research and found out that the problem is called "video buzz". It is where the video signal bleeds into the audio signal. I was connect via coax to the cable box. I was able to fix it on my system by "fine tuning" channel three (my TV card has this capablility). Your system may or may not have this feature. If you are connecting using the A/V input it may be something else.
Posted on Feb 23, 2009
Colour
Under settings or set-up on the remote you should be able to adjust the color of the screen images. If that does not help it may be time for a new TV.
Nov 26, 2013 | LG RZ-20LA70 20 in. LCD Television
Colour settings lg 50pc60
the settings are by how you like to see your picture. play around with the settings and see how you like it. an older tv is going to give a bit different picture then a brand new tv, so the settings may be different.
Mar 05, 2013 | Televison & Video
I am trying to find the out plug on my tv but all that seems to be on the back are connections for in audio I have a LG 42in flat screen set
Hi.
Many LG LCD TV models have also connections at one side, usually the right hand side watching at the TV from the back. Some model may have a protective panel. Standard connections on LG include AV cables, HDMI (depending on model), SCART (depending on model), USB (all new models), audio, VGA, diagnostic etc.
The precise settings depend on the TV model. Please post a new Fixya question including the TV model. The model number is printed on a sticker at the back of the TV.
Regards.
Ginko
Jul 17, 2011 | Televison & Video
Xbox 360 games lag just on this t.v. Does not play games right.
Depending on your model, this is caused by visual post-processing which may introduce lag. Many LCD diplays have a "game mode" setting make sure this is on when playing your Xbox 360 through this LCD TV. Also, depending on your model of TV, there are motion enhancers (usually proprietary e.g. LG calls its TruMotion) which can also introduce lag; these should be turned off while playing. Another step that should be followed, is to turning off any set video setting in the Xbox's configuration (i.e. turning off any set video output such as 480p, 720p, 1080i, etc.) and setting it to "Optimal Resolution". This should allow for native video output instead of possibly upscaling which would in turn induce lag.
This should correct you lag issue for most common LCD TV's. Hope this was helpful. Thanks for visiting FixYa.com
Feb 01, 2011 | Televison & Video
LG 32LH200 stuck on standby mode. pls assist
Im afraid the set is probably in an over current protection mode wherebye it shuts
down to protect itself as one area of the tv is drawing excess current, if the tv led light attempts to change colour at start up as normal or flashes etc this would verify my suspicion
led flashes etc can have a code which would guide a techie to problem, im afraid you
will need an engineer visit,sorry George
Nov 03, 2010 | LG 32LH20 32 in. LCD HDTV
Adjust monitor
hi, most monitors have between 4 buttons or 8 to udjust picture. the 4 button MENU, PLUS, MINUS, OFF. when the menu button is pushed the screen will show a list of COLOUR, BRIGHTNESS, CONTRAST, etc,etc the plus is pressed to change the COLOUR, BRIGHTNESS, etc,etc. if you need to change the SCREEN setting BECAUSE THE ICONS ARE TOO BIG click on START go up list to CONTROL PANEL go to DISPLAY click on this and go to SETTINGS click on this and on the left. change to 1024 by 768 SCREEN SIZE (COLOUR 256). press APPLY wait press OK. gerry
Sep 10, 2010 | Envision EN 9110 19" Flat Panel LCD...
Best settings possible for its color contrast brightnesss etc.....Im aware of roomlighting. my caliberations are numbered not percent. help
Find what the low and high numbers are and set them to the middle, e.g. 0-10 set on 5 This is the optimized condition from the engineers. Then you can increase or decrease each parameter to your likings.
Jul 05, 2009 | Hitachi Televison & Video
Choosing a calibration tech - please help!
black levels in lcd depend 99% on the technology used lg uses ips panels well sammy and sony use the latter thats why they get a tad better blacks but ips generally do colors better and the fact that th lg we have, has the all new 10 bit panels in them i myself like the pop of the lgs color over the barley there difference of blacks between it, sony and sammy, my honest opinion and let me reiterate my own opinion well lets put it like this my friend this is honestly the best way to describe greyscale, its like a painters canvas while its not as close to accurate as possible well the colors will not be as close to accurate as possible the greyscale is the starting point period this guy adjust while you watch then when ur mind is tricked into liking it well hes done kinda con but not a 100 % i mean he shows up atleast greyscaling and well isf ccc is an art and a science ur tv is able to hold ruler straight scale from 10 to 100 man like i said earlier this guy will only give half the pie, save ur money, and after x-mas treat ur self i promise u wont be sorry i am loving mine and well its hard for a tv to impress me but this lg well i cant quit playing with Hey the response time in cinema mode is 2.7 seconds wow, and leave fresh contrast off that equals 40,000 dynamic contrast now that is torch mode, hey intelligent sensor can save u 65% thats alot, did u get extended warranty.
c. YOU KNOW IN UR MIND THAT U WANT TO GET IT DONE RIGHT! lol
Oct 28, 2008 | Televison & Video
Hiran
Scott
Mar 22, 2008 | Televison & Video
Televison & Video Logo
103 people viewed this question
Computer Repairing
Computer Repairing
