Question about Vacuums
Rainbow repair manual
Motor seemed to get hot and now it will not start
  • Vacuums Master
  • 1,320 Answers
This is best diagnosed by a professional repair person
Posted on Jan 29, 2014
Where can I get a step-by-step procedure for rewiring?
[PDF]Rainbow Vacuum Schematic - WordPress.com
https://carniomosdirt.files.wordpress.com/.../rainbow-vacuum-schematic....
We carry the Rainbow Vacuum e2 (Black) Main unit parts. to our schematics page and download the schematic that ... Question about Rainbow E series Canister Wet/Dry.Vacuum ... We carry everything from the OEM electrical cord,. Upright .
[PDF]rainbow vacuum manual repair.pdf - WordPress.com
https://arahentau.files.wordpress.com/.../rainbow-vacuum-manual-repair....
Recent Rainbow E series Canister Wet/Dry. Vacuum ... Rainbow Vacuum E SeriesFilter Queen Vacuum Wiring Diagram Oreck rainbow vacuum cleaner.
Nov 04, 2015 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow vacuum repair
May be a bad bearing and possibly be serviced by a dealer. I think the newest models don't have bearings.
Apr 04, 2014 | Vacuums
How do I get the motor out of the power nozzle on the E-series?
The eSERIES Rainbow has several versions of the power nozzle. Some screw apart and others have snap connections. Look at our website on the manuals page to determine your model. You can also call us and speak to a Rainbow Specialist.
RainVac
www.rainvac.com
800-523-0510
Jun 02, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow vacuum head squeels
Your motor or brush roll needs repaired or replaced. The eSERIES has had several different versions and there is 2 different motor possibilities. Give us a call when you are able and we can walk you through on how to determine what version you have.
RainVac
www.rainvac.com
800-523-0510
Mar 24, 2012 | Rainbow E series Canister Wet/Dry Vacuum
I have a Rainbow E2 which I purchased in early October. My Power Nozzle is not working right. When I used it before, it pulled, now it barely moves on its own. I cleaned all the hair off of it and it...
Does the brush turn freely when you try to manually turn it?
Does it rotate when the power nozzle motor is on?
If not, it's most likely the belt that turnd the brush has broken. This will result in the brush not rotating, which in turn doesn't provide the pulling action and ease of use it's supposed to have.
If it's a new machine, you need to take it to the nearest Rainbow store for warranty repair. Disassembling yourself will result in the warranty being voided.
Dec 19, 2010 | Rainbow E series Canister Wet/Dry Vacuum
RAINBOW E SERIES REPAIR MANUAL
Hi. I found it on amazon, here: Amazon com rainbow vacuum manual. I hope I have helped. cheers
Mar 31, 2010 | Rainbow E series Canister Wet/Dry Vacuum
VACUUM RUNS FOR A MIN AND THEN SHUTS OFF
It sounds like a problem with you motor. The hepa filter has nothing to do with the motor, and should not have been removed. It sounds like the repair man doesn't know much about rainbows. It could be a short in the motor housing or faulty/improper wiring. It may have happened after it when it was worked on the first time. Is it similar to the problem you were having before?
If you bought it from a rainbow dealer, you need to contact them, you should have a warranty, depending on when you bought it. If it is still under warranty, they will fix or replace it for free. If the warranty has expired, they may be able to work out a deal to get it fixed or may be able to direct you to a rainbow repairman.
Aug 09, 2009 | Rainbow E series Canister Wet/Dry Vacuum
I want to take the vac apart to clean around the motor ?
likely a break in your cord somewhere. if you have a ohm meter check it otherwise tale it to a vac repair shop
Oct 25, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Older Rainbow Noisey
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=576894
Older Rainbow Noisy
Posted by Capt_Troll on May 06, 2008
I Have an Older Rainbow (i think it's a d4)
my Old roommate ran it once without water.
it Still works now (with water), but
it's Very noisy on start up
Also I Can't seem to remove the separator (no instructions) but the nut at the end of it appears to free spin the motor when i try to turn it.
Can I Take this apart and Clean/lube it? And if so how? Or is this thing on its last legs? Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum. The Rainbow D4 is an older Rainbow Vacuum and the part where the separator is part of the armature, the separator should be able to be removed and that might be one of the things making noise. As normal maintenance the separator should be removed and cleaned after every use and re-installed, then place a newspaper or towel under the motor unit and turn on the Rainbow and spin the moisture out of the motor unit. This should be done every time you use it. Other wise the Rainbow has 3 fans in the bottom of the motor and if they are weak they will make noise from the motor unit as well. Watch out… the repair of the Rainbow D4 may exceed the cost of a new motor of which will solve your problem of noise and separator --- compare the cost and the labor and make a decision. If you have further questions please feel free to contact your local vacuum cleaner dealer. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 06, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow Vacuum Cleaner starts slow smells hot
Sounds like the motor is going bad and will eventually not start. I am in the process of changing the motor in mine too and they are not cheap. just search around for a motor
Aug 31, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
18 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
