Question about McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK
My electric mculloch chain saw will not start
It is plug in to the electicral connection
    Brigadier General:
  • 4,088 Answers
Most motors of this type are universal type construction meaning that they have brushes and commutators. Stuck brushes or worn-out brushes cause this problem. Vibration can break wiring connections inside the case. Could be a bad on-off switch. Can you move the chain by hand?
Posted on Jul 04, 2009
My mculloch power mate 310 chain saw has broken a starter pawl, where can I get this sorted please?
Try Dixie sales at 800-487-5951 they carry many of the McCulloch parts.
Nov 21, 2017 | Garden
Need to know carb mixture
fuel mixture for 2 stroke' s is 20:1
100ml of oil in 5L of fuel
Mar 13, 2015 | Oregon McCulloch 12" Chain Saw Repl. Chain...
Is a capacitor on a 3200 mcculloch chainsaw also called the coil
starting capacitors on electric chain saws just provide a short burst of stored up energy to get saw moving , coils on gas powered chain saws provide all the electric energy to "fire" the spark plug
the two are totally different and one does not work for the other , but both are an electric device
Jun 05, 2014 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Replacing chain brake on mculloch mac 738
That's really fascinating and all, but do you have a question?
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Oct 18, 2012 | McCulloch Mcc1635a 16-inch 35cc 2-cycle...
I have a mculloch electramac em200 2.0 what mix do I use in it
I'm a little confused here. First I see a problem with Homelite 9.0 amp chainsaw, then you ask about an Electromac EM 200. Both of those are electric saws and don't require a "mix". The only thing you have to put into them is bar and chain oil.
Sep 23, 2012 | Homelite Consumer Products 9.0 Amp, 14 In....
Just bought wg303.1 plugged in would not start no instruction manual must add chain to start?
Most electric saws will have a saftey cut out micro switch for the chain brake, pull the hand guard fully back toward the rear of the saw to make sure the brake is completly off, now try again.
Feb 13, 2011 | Worx (16") 3.5 HP Electric Chain Saw -...
How do you replace chain sprocket on1988 mculloch 16in. chain saw
Open the right side of the saw enclosure where the chain screw adjuster is.After that you will see the screw,unscrew and thigh the chain forward but not too much just adjust and test by hand,tight the screw and do a start test.
Post or thumbs back!
Nov 11, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Start procedure for chainsaw ncr 4550
The header says that this is an electric saw which doesn't have a start procedure--just push the button and it runs. Electrics also don't have a clutch because the motor doesn't need to continue running when not cutting like a fueled engine does. Most electrics, however, have a safety device that uncouples the chain drive sprocket from the drive shaft to protect the gearbox. Remove the bar and chain, then look for a broken/disconnected drive link or spring connected with the sprocket. If the shaft itself does not turn, then there is likely problems in the gearbox. Hope this helps!
Jun 03, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
How to get Remington electric chainsaw M30016AS warrenty repair?
Good luck with MTD. They buy assets (various companies) but leave the liabilities (warranty) in the dust. As you should know, all those details are discussed in the agreements between the companies. If you really want to know and the both companies are publically traded, you could find the answer by reading all the small print public companies are required to disclose to share holders. Forget a legal remedy.
Is your bar (the thing the chain rides on) properly adjusted? When it is properly adjusted, the chain should ride freely on the bar but not hang away from the bar at any place. If you pull up on the chain, when you let go it should snap sharply back into the bar. Yet, it should move freely when you grab it with your GLOVED fingers.
Never work on a chain saw if the saw is (1) plugged in (2) the spark plug is connected. Chain saws don't care at all what they cut!
Let me know if this works for you
a
Sep 21, 2009 | Remington Electric Chain Saw
McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK Logo
170 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
