Question about NRS Slinky Dog
How do I untangle a slinky dog? - NRS Slinky Dog
How to untangle inside the spool head ryobi expand it
start with a pair of diagonal cutters .
Sep 13, 2014 | Ryobi Garden
Untangling a shimano sienna 1000
well the easy way is to CUT old line off then replace with new,but you can untangle line carefully and reuse it tho this takes a lot of time
Aug 27, 2014 | SHIMANO AMERICAN CORPORATION Sienna 1000...
How to untangle letters to make words in Jumble Word Puzzle
Hello, You are going to have too use dictionary, google, or yahoo to help with untangling words.
May 26, 2014 | Video Game Consoles & Games
How do you know what guage ernie ball strings are it just says regular slinky 2146?
Usually the guage of the strings is defined by the first string. In other words, light strings are usually 11s. 12s are heavier and 13s are heavier still. The string set that you list is a 12 which is a medium grade. The medium grade is also called regular as opposed to lights (11s) or heavy (13).
Hope this helps,
Dan
Jul 09, 2011 | Ernie Ball 2146 Acoustic Regular Slinky...
Looking for inexpensive shortwave antenna for use with Grundig S350 AM/FM Shortwave Radio
Simple wire can make a great antenna, and it's relatively inexpensive. I've had the best shortwave and AM reception thus far using a long loop (actually a rectangle) of copper wire as an antenna (but folks shouldn't try a loop with some radios designed for use with powered antennas without inserting an appropriate capacitor in series). If you do try wire, you would want to try to make the loop shape as large as possible, and connect the ends of the wire to your radio's antenna connectors.
Apr 06, 2010 | Grundig S350 AM/FM/SW Radio
Bbb
Good strings. Ernie Ball has been around for years. Not only strings but teach yourself books, scores, guitar accessories. The late Jeff Healey only used Ernie Ball Slinky Electric guitar strings. If you haven't listened to Jeff Healey and you thought Jimi Hendrix was good have a listen to this guy and remember he's blind.
Good Luck
Sep 02, 2009 | Ernie Ball EB2146 Regular Slinky Acoustic
Grandma's nylons wrapped around the bottom of the agitater
now you need to pull upward firmly but hard.  there are small splines holding the agitator in position. carefull if the agitator has two parts to it as there are usually plastic (dogs)inside which could spring loose if you are not careful.
Oct 24, 2007 | Washing Machines
NRS Slinky Dog Logo
87 people viewed this question
Top NRS Toys Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a NRS Toy Expert? Answer questions, earn points and help others
