Question about Miele Novotronic Premier 500 Front Load Washer
How to take the brushes out of a miele w504 washing machine
Rinse light flashing
  • 183 Answers
SOURCE: The washing machine wont start
This indicates either a faulty inlet valve, afaulty pump or a blocked filter Regards Engineer
Posted on Jul 30, 2007
  • 16 Answers
SOURCE: Miele Premier novo washing machine
Flashing rinse light is a drive fault. No motor action. If it's an earlier model it would be the motor brushes. Later model will be the electronic which controls the motor.
Posted on Feb 08, 2008
  • 16 Answers
SOURCE: miele washing machine
All Miele washing machines and dishwashers need to fill in a required time. Flashing inlet (Tap icon) indicates that the machine can not fill in time. There are filters in the end of the hoses which connect to your water supply from the machine and filters in the inlet valves which you can get at by removing the hose from where it fixes onto the machine it'self. You will need some long nose pliers to grab the little tab on the small filter to get it out. Clean all filters and hoses. Still same problem then check the pressure of the water coming into the machine. There should be a good pressure coming out of the hose and will be difficult to stop the flow of water with your finger.
  • 13 Answers
SOURCE: Miele W864 Fault
I have a W844 and the exact same fault occured. I traced it to badly worn brushes on the motor.
Posted on Sep 21, 2008
Mark Harmer
  • 8 Answers
SOURCE: Washing machine problem
Same - there's a company in Denmark which does brushes - you have to hunt them down on the web. The brushes come in a brass slider and spring, and sit in a rubber cage. Make sure you don't throw away any bits of the old brushes as you might need to reuse the old rubber cage.
Another solution (if you have the rubber cage) is to move the brushes along a bit and bend the metal tabs on the brass slider. That will give you a contact again - the machine will work for a few weeks or so, which gives you time to order the new brushes.
Posted on Sep 21, 2009
There are two main causes for this failure:
- carbon brushes are worn
- electronic is defective
The exact solution is depending on the model of your Miele washing machine and works for all modules that start with:
EDRU, EDSU, EDSTU, EL, ELP, EDPL,
you may visit youfixit.eu for a solution.
Miele repair Address and payment information
Feb 09, 2014 | Miele Washing Machines
How do I open my Miele W504 and change the motor brushes
Hi Kieron
Open door then turn off power. Undo 3 bolts around door seal. Remove soap draw. Undo the screws. Peel off door seal at front of machine and fold in towards drum. Metal spring catch located at bottom behind pump filter door. Now open up front of machine (its hinged on the right). Good luck
Feb 19, 2012 | Miele Novotronic Premier 500 Front Load...
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
Rinse light flashing on miele novomatic washing machine
Check the motor for worn brushes and or noisy bearings while it is removed for service. Any auto mechanic should have experience replacing brushes and bearings. Much cheaper than ordering a new motor. New brushes and bearings should cost around $30. The shop time should not exceed one hour. Miele charges about $50 for brushes if you can not find a local supplier. The W1930 motor that I rebuilt used a 6202Z and a 6201Z bearing set.
Sep 02, 2008 | Miele Touchtronic W1213 Front Load Washer
Miele 2104 Washing Machine
If your model is displaying the same symptoms as the W1930 that I repaired, then the cure is to replace or check the brushes on the main drive motor ($17) and check or replace the bearings ($12). This is much easier on the pocket book. I was able to confirm the presence of drive voltage (25VDC) to the motor terminals prior to the removal.
May 25, 2008 | Miele Touchtronic W1213 Front Load Washer
Miele W864 Fault
Mar 11, 2008 | Miele W864 Front Load Washer
The flashing lights
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Check your pump too after refering to your manual.
Rate me pl.....if helped.
Jan 14, 2008 | Washing Machines
Aug 10, 2007 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic Premier 500 Front Load Washer Logo
15 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
