Question about Compaq Computers & Internet
Dim screen (Desktop)
I know you guys are thinking "Higher it up in AMD settings" No, The Windows 8 options are "Not Available" I have highered the brightness on it and my monitor but still there are a lot of things I can't see, I have tried 3 VGA cables as it doesn't support HDMI all cables were plugged in and screwed in too, what can I do to make it look like it should on a laptop screen or other desktops >_< I have tried it on other monitors, one of them worked fine, it was a Dell monitor, any tips?
  • 3 more comments
  • MrFixit
    MrFixit Dec 29, 2013
    Hi jay bourn, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Is the monitor consistently dim through the entire screen or is it brighter at the top or the bottom?
  • Gamr13 Dec 29, 2013
    Thank you for the reply, The monitor is constantly dim, not any side brighter than the other
    It's certainly not my T.V if I plug my PS3 in or laptop it works grand, and this PC works grand with my monitor that is for the main Desktop
  • MrFixit
    What is the model number of your desktop computer?
  • Gamr13 Jan 13, 2014
    apologies for the late reply: 100-005ea
    Champion:
  • 411 Answers
Control Panel\Hardware and Sound\Power Options
at the bottom there is settings for screen brightness.
To get to control panel on 8, (not 8.1) go to desktop, then Winkey+c and click settings then control panel.
Posted on Jan 07, 2014
4 Suggested Answers
ehsan_bba
  • 112 Answers
SOURCE: No Display from new Acer Desktop AX1700
check all power cable. check vga cable,
Posted on Jan 26, 2009
QHabib
  • 126 Answers
SOURCE: Hi,how do I know wheather I need DVI or VGA cables
no worries, any monitor you buy now which is an LCD has both inputs DVI and VGA. However, it might not necessarily provide both cables. I suggest you buy one where both cables are included.
From the description, the cable you have is VGA. The VGA PC interface for it should be smooth with small holes in it. The DVI PC interface is wider than VGA
Posted on Sep 02, 2009
SOURCE: Does the Acer Aspire R1600 support extended
No. It does not support dual monitors with VGA and HDMI.
Posted on Jul 20, 2010
Why dark manor game didnot support my monitor risolution
Windows XP
  1. From your desktop, right-click and select Properties.
  2. Click the Settings tab.
  3. Adjust your screen resolution to 1024 x 768 (or higher) and select OK.
  4. Try playing your game again.
Windows Vista
  1. From your desktop, right-click and select Personalize.
  2. Select Display Settings.
  3. Adjust your screen resolution to 1024 x 768 (or higher) and click Apply > OK.
Windows 7 and Windows 8
  1. From your desktop, right-click and select Screen resolution.
  2. Adjust your screen resolution to 1024 x 768 (or higher) and click OK.
  3. Try playing your game again.
Mac
  1. Open up the Apple menu.
  2. Select System Preferences.
  3. Click on the Displays icon.
  4. Select the Display tab to adjust your resolution to 1024 x 768 (or higher).
  5. Reopen your game.
    _
    Try this out it seems to work for some people, if that does not work try this out:
    Switch to Windowed Mode
    If you continue to have trouble playing your game in full screen mode, switch to windowed mode. Under the main menu of the game, select Options, and un-check Full Screen mode (or vica verse if you already have windowed mode on, switch to fullscreen)
    Thanks and I would appreciate a reply if that got fixed or not.
    Good Luck!
Apr 27, 2014 | bigfishgames.com
Zoom on desktop
Try Right Clicking on a empty space on the desktop and select Properties. Click the Settings Tab and go change the screen resolution. The higher the resolution, the smaller the icons. Normal resolution is about 1024x768, but you can make the icons even smaller by increasing the resolution.
If you can't get into the screen resolution that way, turn off the computer and boot up into safe mode.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal.
When the computer boots up click Start/Control Panel or Start/Settings Control Panel and look for Desktop or Appearance and Personalization.
Look for Screen Resolution or open the desktop and click the Settings tab. Make the resolution higher to make the icons smaller. Normal is 1024x768 but you can make it higher.
In Windows 7 just click Start and in the search box type: Screen Resolution. Look up at the top for the returned search results and click on Screen Resolution. Go in and set the resolution higher.
After you change the resolution reboot and let windows go into it's normal boot up mode.
May 23, 2012 | HP Compaq 6710b Notebook
Change the resolution on my Samsung B2030 LCD Monitor
1600X900 is a higher resolution than that of 1280X1024. Therefore 1600X900 is a better resolution. If you would like to run at the lower resolution simply right click your desktop screen and click properties. Then on the settings tab use the slider bar to adjust the resolution. Lower to the left and higher to the right. If the desired resolution is unavailable then you could try downloading and installing the latest drivers for your graphics card installed in your computer.
Your card will either be AMD/ATI Radeon or Nvidia. You will need the model number of the graphics card, the latest drivers may increase resolution support for your card.
Also look on the bottom right hand side of your screen for an Nvidia Control Panel logo in green. Right click it and select the option to "change screen resolution" This may provide you with additional resolution options.
Take care!
damnor01
Nov 02, 2011 | Samsung B2030 LCD Monitor
I have an emachines El-1352G-41W What are my options to expand this system into "CAD" system?
If you mean AutoCAD then you need the following:
You can get more information at:
http://usa.autodesk.com/autocad/system-requirements/
For 32-Bit AutoCAD 2012
  • Microsoft® Windows® 7 Enterprise, Ultimate, Professional, or Home Premium (compare Windows 7 versions); Microsoft® Windows Vista® Enterprise, Business, Ultimate, or Home Premium (SP2 or later) (compare Windows Vista versions); or Microsoft® Windows® XP Professional or Home edition (SP3 or later)
  • For Windows Vista or Windows 7: Intel® Pentium® 4 or AMD Athlon® dual-core processor, 3.0 GHz or higher with SSE2 technology; for Windows XP: Intel Pentium 4 or AMD Athlon dual-core processor, 1.6 GHz or higher with SSE2 technology
  • 2 GB RAM
  • 2 GB free disk space for installation
  • 1,024 x 768 display resolution with true color
  • Microsoft® Internet Explorer® 7.0 or later
  • Install from download or DVD
Jul 11, 2011 | Acer eMachines Black EL1352G-41w Desktop...
My printmaster 2011 gold won't install. what should I do
Installing printmaster 2011 gold on PC.
System Requirements:
Windows XP (Home & Pro) SP3/Windows Vista SP2/Windows 7*
Pentium IV 1.6 GHz or better (2 GHz recommended) or comparable AMD Processor
1 GB RAM available (2 GB RAM or more recommended, 2 GB required for Windows Vista and Windows 7 users)
Available Hard Disk Space: Installation disc requires approximately 2.7 GB; downloadable content can require up to 36 GB of hard drive space
Internet connection required to access content 16 MB Video RAM (64 MB video RAM recommended)
DVD-ROM drive, keyboard and mouse
Monitor resolution:1024 x 768 or higher (1152 x 864 or higher recommended)
QuickTime version 7.5.0 or higher is recommended (Available at www.quicktime.com)
Java version 6 or higher required (available at www.java.com)
Recommended Additional Equipment:
Printer, Digital Camera
Macintosh OS X 10.4.8 or greater* (with the latest Java update)
PowerPC G4 500 MHz or faster (G5, PowerPC or Intel Mac--1 GHz processor or better recommended)
Available Hard Disk Space: Install disc requires approximately 3.0 GB; downloadable content can require up to 36 GB of hard drive space
1 GB RAM (2 GB RAM or more recommended)
8 MB Video RAM (64 MB video RAM recommended)
22 GB (hard disc space)
Monitor resolution 1024 x 768 or higher (1152 x 864 or higher recommended)
QuickTime version 7.5.0 or higher is recommended (available at www.quicktime.com)
*Administrator privileges are required to properly install the program on Windows XP, Windows Vista, Windows 7 and Mac OS X
Do your system meets the above requirement?
Nov 15, 2010 | Broderbund PrintMaster Platinum for PC
Have uinstalled arcsoft impressions but cannot get
Arcsoft MediaImpression 2
Requirements
Windows XP SP2, Vista, Windows 7:
Pentium IV 1.6 GHz or equivalent AMD Athlon
512 MB RAM (1 GB recommended)
300 MB available hard disk space
NVIDIA MX440 or ATI 9200 or higher
1024 x 768 pixels, 16-bit color monitor or higher
Microsoft Windows Media Player 9.0 or higher
Microsoft DirectX 9.0c or higher
Apple QuickTime® 7.0 or higher recommended
Internet Explorer 6.0 SP1 or higher
Macintosh OS 10.3.9, 10.4, 10.5, 10.6:
PowerPC G4 800 MHz processor or equivalent (Power PC G5 or Intel Core Duo processor recommended)
768 MB or higher recommended
300 MB available hard disk space (1 GB recommended)
1024 x 768 pixels or higher recommended
Do your PC meet the hardware and software requirement for Windows or Mac?
Jul 26, 2010 | Arcsoft MediaImpression for PC
I have purchased a ION slide to PC scanner, It is plugged into a USB2 port, My system runs on Windows XP Pro with a NVIDA Graphics accelerator, V2.70 with latest updated driver, an AMD 1.01Ghz processor,...
change your desktop settings for a higher resolution, such as 1024 x 768
1. right clich on desktop
2. select properties
3. select "settings" tab
4. change "screen resolution" to a higher resolution ("more")
5. accept changes and try scan again.
Sep 01, 2009 | Office Equipment & Supplies
Hi, I've Toshiba Satellite 480CDT laptop installed with windows 98. Can my computer install & support windows XP? I just want this computer to share files with my desktop P4 system which has windows...
These are the recommended hardware requirements in installing windows XP:
  • PC with 300 megahertz or higher processor clock speed recommended; 233 MHz minimum required (single or dual processor system);* Intel Pentium/Celeron family, or AMD K6/Athlon/Duron family, or compatible processor recommended
  • 128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
  • 1.5 gigabytes (GB) of available hard disk space*
  • Super VGA (800 x 600) or higher-resolution video adapter and monitor
  • CD-ROM or DVD drive
If your laptop pass all this requirements then you can upgrade your windows 98 to windows xp operating System.
Jun 16, 2009 | Computers & Internet
Laptop problem viewing screen
try this >>>
right click on an empty space on your desktop
click on properties
click on the settings tab
on the screen resolution box, adjust it to a higher pixel
click 'apply' then 'ok'
Oct 21, 2008 | HP Pavilion dv6000z Notebook
Nero 7 wont work on vista
What error comes up?
Nero 7 is not made for vista, however I got it to work..
General System Requirements
  • DVD-ROM drive for the installation
  • Windows® 98/98SE/ME/2000 (Service Pack 4 or higher), Windows® XP, Windows® Server™ 2003, Windows® Media Center Edition 2005,
  • Windows® Internet Explorer® 5.5 or higher
  • To install Nero 7 you must have administrative rights for all operating systems higher than Windows® 2000.
Processor and Installed Memory
  • For writing audio and data discs: 800 MHz Intel® Pentium® III processor, AMD™ Sempron™ 2200+ or equivalent, 128 MB RAM
  • For TV recording, DVD and video authoring: 1.2 GHz Intel® Pentium® III processor or AMD™ Sempron™ 2200+, 128 MB RAM
  • For capturing and burning in real time: 1.6 GHz Intel® Pentium® 4 processor or AMD™ Sempron™ 2600+, 128 MB RAM
Hard Drive Space
  • 1 GB hard drive space for standard installation of all components
  • Up to 9 GB free hard drive space for DVD images and temporary files
Display Settings
  • Microsoft® DirectX® 9.0 or higher • Graphics card with at least 8 MB video memory and minimum resolution of 800 x 600 pixels and 16-bit color settings. However, 24-bit or 32-bit are recommended.
Optical Device
  • CD and/or DVD/DVD-RAM recorder
Sound Devices and Speakers
  • 16-bit Windows® compatible sound devices and speakers • Installation of the latest WHQL (Microsoft® Windows® Hardware Quality Labs) certified device driver recommended
Nero 8 was
Nov 29, 2007 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
48 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
