Question about Siemens Microwave Ovens
Siemens error 7 - Siemens Microwave Ovens
Why does my siemens microwave cut off after a few seconds
The magnetron, "heart of the microwave", the inverter board, "7 years old or less" and possibily the keypad control board.
Apr 20, 2012 | Siemens Microwave Ovens
Swindle microwave oven cuts out after ten seconds
The problem is caused by the magnetron, "heart of the microwave" or the inverter board, "if 7 years old or less" and possibily the keypad control board.
I have lost my user manual for my Siemens surpresso s 40 . Where can I downloud one ?
You can download it from here.
http://www.siemens-brand.info/siemens-surpresso-s40-manual.html
Jul 20, 2011 | Microwave Ovens
My Siemens HF87950GB inner glass panel broke during cooking, do I need to replace the whole microwave oven or just the glass or the door? where I should I go to get a replacement? Thank you!
This is a problem that at least a few others have experienced with your microwave and may be the subject of a recall although I could find nothing on their website.
I would definitely go to Siemens first as this definitely sounds like a manufacturers defect. Even if they have not publicly stated this in a recall, they likely know it is happening and may fix it (even out of warranty) if you push. ConsumerReports.org may be interested... I would talk to them if you don't get any satisfaction from Siemens.
Otherwise, the glass should be standard tempered glass that a local glass shop can get if you bring the door to them, or just a sample of the broken glass (for thickness) along with the internal dimensions of the glass.
Make sure that the metal mesh/screen remains in place and is not damaged, as this is what prevents the microwaves from escaping the cooking chamber.
Siemens Customer Support Website
Siemens Service # 1-866-447-4363
Oct 21, 2010 | Siemens HF87950GB Convection Microwave...
We have an Engineer coming around for the third time this week. Appliance is under two years old but keeps blowing out when we cook rice for 20 minutes or more. was told it might be ventillation problem...
Possible that the magnetron, the capacitor is weak or defective.
It will be good to choose a low heat program to try and see if the fuse will stay, if so the magnetron has errors.
It will be good to post a complaint to the official customer care of Siemens to find a solution.
Sep 30, 2010 | Neff H5430 Convection Microwave Oven
Glass door for a Siemens microwave hf 879
I've the same problem. Inside glass broke while heating.
May 20, 2010 | Siemens HF87950GB Convection Microwave...
Siemens HF87950GB /03
If the display is dim and another problem is denoted on the dim display, the problem may be the power supply which may be in common with both items. The power may have surged to a high level before going out which could have damaged the power supply. The only way to know is to probe the power supply with a voltmeter. If the board doesn't show the power levels, usually +5V or +/- 12 V DC, read the values on the electrolytic capacitors on the board. Usually 16 V caps are used on 12 or 5 volt supplies, 32 V caps on 24 V supplies, etc. Be very careful or leave this to a profesional
Nov 24, 2007 | Siemens HF87950GB Convection Microwave...
Microwave Ovens Logo
Top Siemens Microwave Ovens Experts
William Miller
William Miller
Steve
Gerry Harvey
Gerry Harvey
Are you a Siemens Microwave Oven Expert? Answer questions, earn points and help others
