Question about Panasonic Irons
Assembly of iron NI-22AWT - Panasonic Irons
How do i increase the iron heating temperature (thermostat) in Panasonic Electric Iron NI-22AWJ
Check the voltage at your power point, irons draw a lot of power. most irons have a temp setting switch cool med hot . If this a new iron return for service.
Feb 18, 2015 | Panasonic Irons
I have black burn on the soleplate of my iron that nothing seems to get it off. any suggestions
Here is a tip that will help you with cleaning the sole plate of your iron...
Cleaning a Steam Iron Soleplate
heatman101
Dec 17, 2010 | Panasonic NI-C78SR Iron
Panasonic NIA56NR NI-A56NR Iron shut off and wont turn back on
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Oct 04, 2009 | Panasonic NIA56NR NI-A56NR Iron
THE LIGHT IS ON BUT THE IRON WON'T HEAT UP.
heatman101
Jul 06, 2009 | Panasonic NI-R73NR Iron
Panasonic Iron won't heat
most iron cases can not be seperated from the iron plate but, if you can take off the bottom plate you will see a heating element and attached to that a small cylinder it has a point on one side and a flat end on the other it is called a thermal fuse and radioshack sells them
they are made in different versions so take the fuse in to get the right one clip it back in and your iron should work again
Apr 24, 2009 | Panasonic NIA56NR NI-A56NR Iron
NI-A57SR steam Iron suddenly not functioning
I had the same problem, when I took it apart, I noticed the theromstat points needed sanding. Just a reminder, make sure to write down the order of wire leads before disconnecting. By the way to test if the heating element is working connect white lead to the second connection from the left and black lead to the far right. Place your iron flat down on a wet cloth ( so that you won't burn your surface). You can also use an electrical tester. If heating element does not work though, it is time to buy a new iron.
Dec 31, 2008 | Panasonic NI-A57SR Iron with Auto Shut-off
Iron is out of order
an appliance repair center could probably fix it but you have to consider the cost against a new iron
mostly it is more costly to repair than to fix
Oct 19, 2017 | Panasonic NI-A57SR Iron with Auto Shut-off
Wiring digram for Panasonic NI-A57SR Iron
Same issue i believe
with metal part laying flat (ironing position) and looking at bottom side, from the left to the right - white & blue leads, lamp(resistor lead), red then both black leads and other end of lamp.
im guessing the themal fuse is the lamp? what is the PN where can i get it.
i had a small shere fall out of the unit, besides the positioning switch where else would this be located?
Thanks
Dec 13, 2008 | Panasonic NI-A57SR Iron with Auto Shut-off
My panasonic NI-R73NR iron went off and is not coming back on.
Check fuse in plug, check wire in plug for loose connection. Turn the thermostat a little higher to 'freeup' the contact mechanism. Check continuity with a ohm meter on the irom conacts, check lamp on iron
Aug 11, 2007 | Panasonic NI-R73NR Iron
Irons Logo
26 people viewed this question
Top Panasonic Irons Experts
Jim Goldsmith
Jim Goldsmith
Bill Boyd
Rani wadia
Rani wadia
Are you a Panasonic Iron Expert? Answer questions, earn points and help others
