Question about IBM (14R0060) Monitor
How can I use my apple lcd monitor (model m7649) to my dell
I need to use my apple monitor to dell desktop. but the connector is different from them.
The apple have a called adc connector, that data and power for the monitor is the same connector.
What I'm going to do this?
regards
  • 1 more comment
  • dhodongrom May 19, 2009
    My dell desktop have a analog input and vga..
    thanks
  • Anonymous May 19, 2009
    The situation is like this: Dell desktop computer and a apple lcd monitor having adc connector. THe monitor having a fix cable installed. The data and power going through the monitor is using this cable having the end of this is an ADC type cable..So I can't used this because the dell have a vga and analog output connector..How will my monitor work with my dell desktop?
    because as normal not apple monitor, the power cable is separately installed.
    thanks.
  • Frank Zhang
    Frank Zhang May 11, 2010
    whats your destop video CARD output interface? is there a DVI PORT?
  • 191 Answers
Here you need to do:
1) you need find a video card with a DVI port and analog output ports, upgrate this card in your destop if you can not find a DVI port at your destop.
2). then you need buy a ADC to DVI adapter because your monitor ADC port is a digital port. you may reference here:
http://store.apple.com/us/product/M8661LL/B
and you can buy the parts at:
http://shop.ebay.ca/items/?_nkw=dvi+to+adc+adapter&_sacat=0&_trksid=m270&_odkw=adc+to+dvi+adapter&_osacat=0
hope help you fix it. please take a rating let me know huw much helped you thanks!
Posted on May 19, 2009
I have dell optiplex 755 desktop with lcd monitor.everything is all right but monitor starts for 2 seconds and then turns off help me to solve this problen
If is possible we need to establish if the monitor is defective or not. Please connect to a different monitor/LCD TVscreen or just unplug the monitors data cable from the back of the computer powered it up and check if is giving you a message on the screen as "No signal detected". It will tell you that the monitor is fine and is a problem with your Dell computer.
Jun 29, 2011 | Dell Optiplex 755 Desktop Desktop Computer...
Getting a new flat panel lcd screen to work on my
It should work right out of the box, although with imac's you may need to install the software that came with the monitor first. Try Safe mode if it won't show up any other way, safe mode skips the drivers for the most part, it may allow you to see the installation disk, install the drivers and whicever app's u need from the disk. Also make sure you have the correct connector on both ends and the cable that came with the new moniitor, "not the old one", that may be it right there. The pins are different on different systems. Let me know what happened, if your old monitor works, it's a setting, try running multi monitors thru video properties menu so you can se what's the heck is goin on with the installation disk, good luck
May 20, 2010 | Apple Refurbished iMac 20-inch 2.0GHz...
Hi,how do I know wheather I need DVI or VGA cables to connect CPU to a Monitor.I sold monitor when I got laptop now I want set up the Dell Dimension 3100 as aback up,so I'm looking at wide sreen monitors...
Most of the Widescreen monitors come with DVI as well as VGA connector. A VGA connector and DVI connectors are different in many aspects. First of all the DVI connector would be white in color and VGA would be blue.
VGA connector has 15 pins and DVI has 24 +1 pin
Sep 02, 2009 | Dell Dimension 3100 PC Desktop
How do I connect my apple model m7649 monitor to a dell laptop? Thanks to anyone, ron
you should be able to get hold of a convert that plugs in to your laptop then you should be able to plug the monitor in to the converter with out having any problems with display settings
hope the information is abit of help to you
Mar 04, 2009 | IBM (14R0060) Monitor
I need power cords for my monitor
The monitor needs a power cord and a signal cable. The power cord is a standard 3-prong detachable cord just like the one on nearly every desktop computer and many other electronic appliances.
The signal cable may be one of two types, depending on your computer's video connector. The monitor has connectors for both VGA (a D-shaped connector with 15 pins) and DVI (a rectangular connector) inputs. You need a cable with whichever type of connector fits your computer.
You should be able to find the power cord at Radio Shack, any of the big office supply places, or retailers who sell computers. The signal cable may be available there as well, or you can order from a number of online vendors.
The monitor also allows you to plug in a USB cable from your computer so you can plug in USB devices like a keyboard or mouse. For that you need the same kind of USB cable you would use to connect a printer.
You can view or download a copy of the monitor user's guide at Dell's site here:
http://support.dell.com/support/edocs/monitors/1704fpt/EN/index.htm
If this solution has been what you need, please take a moment to rate it. Thanks for asking here!
Feb 21, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Can I use an Apple M7649 Studio Display with a MacBook Pro
Do you have the black unibody Macbook Pro that was just released, or the silver model?
Since the display is DVI, it will directly hook up to the silver model. If you have the new model, you need a mini DVI to DVI adapter.
Nov 22, 2008 | Computers & Internet
Mac Mini G4 Flickering Screen at Start Up
Did you check the wires?  Sometimes if you pull one loose it flickers.
Aug 13, 2008 | Apple Mac mini G4 Desktop
Monitor no display
hi, check out the connector pins if any is damaged or bent, if not try it on a different system just to confirm that its not the display card problem, let me know??
Oct 20, 2007 | Dell E173FP 17" LCD Monitor
Studio display m7649 picture will not come up when connected to toshiba laptop
I am not sure how youve manage to connect these 2 items. You did not specify whic Portage you have, but even the most recent only has SXGA video port. The Apple cinema display connector is ADC. APPLE DISPLAY CONNECTOR. No computers on the planet have this port except for apple's. It's basically a modified DVI connector. In order for you to use this monitor with your computer, you would have to purchase a DVI to ADC connector , which is another APPLE only item and selld for $100 new. You would then have to purchase a SXGA to DVI adaptor...It sounds like a costly endeavor, and with a connections your Portage's onboard video card , amynot even support the resolution for this monitor.
Hope this helps.
Oct 17, 2007 | Apple Studio Display 17" LCD Monitor
Computers & Internet Logo
956 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
