Question about Philips WACS700 Shelf System
Wac installer - Philips WACS700 Shelf System
Philips WACS 700 - Hi - My machine has not
Hello there
di you try to hold power buton pressed for 30 sec?if that is not working need to open and te reset on EPROM.
Dec 01, 2009 | Philips WACS700 Shelf System
Convergence problem red lines are out of wac on
Most of these sets use two STK-392-110 convergence IC's; both along with any open resistors around them need to be replaced and the set adjusted.
You can buy the chips on Ebay for less than 13 dollars(look for suburban electronics--Sewsale--they have the best price on these parts and give a 6 month warranty) if you are able to replace them yourself if not, look for someone in your area to do the job for you; this is the slow time of year for TV repair shops---some shops get 300 or more for this repair. I fix a lotof these smaller sets(42 etc) for 200 parts and labor.
Find someone and make sure BOTH IC's are replaced. If you have questions let me know here. I do this for free so if this was helpful give me a vote here.
regards, SD TECH
Aug 25, 2009 | Toshiba 42H81 42" Rear Projection...
Got new laptop with vista. Can t install wacs700 software.
Hi !
I strongly suggest that you discuss WACS related issues in theStreamium Café (www.streamiumcafe.com). This is where you will find ananswer to your problem (look for the WACHandler" threads where you willfind a link to my application ;)
You can also try the WADM application from Philips. It is made for the newer WACS units but it works with the WAC700 also.
Cheers !
/Mathias
Jan 25, 2009 | Philips WACS700 Shelf System
Cannot use my wacs700 with my vist laptp.
try downloading wach handler from http://www.lucia-mathias.com/wacs/ i think this works with vista and is much superior to philips software
Dec 28, 2008 | Philips WACS700 Shelf System
Philips wireless music center v2.0
Nov 11, 2008 | Philips WACS700 Shelf System
Philips WACS700 Shelf System Logo
13 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
