Question about Zanussi ZWD1270 Front Load Washer / Dryer
My zanussi ZWD12270G1 wont turn on
Machine lost power during a drying cycle.so i checked power to plug sockets and changed the fuse in plug but still no power.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 129 Answers
THE MOTHERBOARD MIGHT HAVE FUSED OUT , NORMALLY YOU HAVE TO TAKE THE TOP OFF AND LOOK FOR A FUSE NORMALLY A 4amp LOOKS LIKE A GLASS FUSE LET ME KNOW
Posted on Dec 29, 2013
  • 8 Answers
SOURCE: zanussi aquacycle 1200
May be the Bearings.Open door and try moving drum, hold at top of drum and pull foreword and back if drum loose main bearings gon. Replace bearings.
Slim Jim
Posted on Nov 26, 2007
  • 1294 Answers
SOURCE: Zanussi ZWD1471W Washer Dryer error codes help please!
Click on Zanussi (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line. And dont forget to rate me, on this great site.
Posted on Dec 05, 2007
  • 101 Answers
SOURCE: zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Posted on Apr 23, 2008
SOURCE: zanussi washing machine drum will not go round at all
i had a similar problem with a zanussi machine
a cheap bracelet got washed with some clothes and it found its way into the drum housing jamming the drum.
it may have been cheap to fix, but i just got rid of it cos it was 4 years old anyway
i now have a zanussi ZWF1231W just past its 1 wear warranty that has just died completely except for an "on indicator light"
the store inform me that i will have to pay the zanussi engineer a Euro 90 call out charge, plus labour costs, plus parts if needed.
im a little bit disappointed with zanussi to say the least
bozcro
  • 867 Answers
SOURCE: Zanussi ZWD1470W fabric conditioner compartment won't drain
fabric conditioner is dispensed during rinse cycle, if it does not work then either, try pouring hot water into dispenser, as conditioner tends to get goopie when dry, thus may have clogged up
Posted on Dec 11, 2009
My zanussi zwg6141p wont spin and cut out during wash?
replace the carbon motor brushes and retry if it wont spin usually the water isnt taken out fast enought to satisfy the vaccume switch so its the pump the switch or an air lock
so empty the machine totally and expell all water from all hozes and check the waiste is aok for flow no jams your left with either the pump motor issues bits of b.a wires or the main motor brushes
Mar 05, 2015 | Zanussi Washing Machines
Zanussi Washer Dryer wont wash!
Sounds like the switch that tells the controller that the door is closed and locked is actually bad or the plastic molded part holding the switch is broken. Inspect the interface for cracks.
Nov 22, 2014 | Zanussi Washing Machines
Blown fuse after milk spilt on to plug Zanussi ZWF 1000M
It could be defective main board problem
Dec 10, 2013 | Washing Machines
Hello.. I have a Zanussi Electrolux essential 1200 6kg machine. My problem is that during the wash (usually about 40 mins into it) the machine seems to think the cycle has finished and cuts out before...
Something could be stuck in the pump , drain the machine down drain hose next to drain plug when all water is out put a towel under drain plug unscrew then look in the drain plug and your see a little propeller, make sure it turns and nothing stuck there to stop it turning and leave clean then try again good luck
Dec 13, 2017 | Zanussi FC1200W Front Load Washer
Dec 11, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
Washing machine keeps stopping mid wash and coming up error (32 motor surrisc) zanussi keeps stopping and reporting E32 as a fault, how do i fix this?
Hello
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Feb 26, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi washing machine wont spin
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi turbodry w 1042 w
probably short to earth on the dryer elements. to check. take top off, disconnect dryer elements then run on dry program. if the trip stays in, then you have identified the fault
May 16, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi ZWD1270 Front Load Washer / Dryer Logo
188 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
