Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 44832
Last week I noticed the clothes in the machine were still very wet at the end of the cycle. After watching the machine in action I noticed that when it went into the spin cycle it would only spin at high speed for a couple of seconds and then wind down and stop. It would then repeat this process a few times but every time it got up to full speed it slowed down right away. This was my original problem.
Tonight I was reading some of the troubleshooting and went to look at the machine. I noticed the load that was in the machine was half wet and half dry. I ran the load again and it filled with water but now the drum did not spin at all. When I pressed cancel the water drained out. I tried running it again with no luck.
Did the first problem lead into the second problem or are they two different problems? Are there any solutions I can try myself? What is the estimated cost to make the repair on my own vs calling Sears?
  • 64 Answers
Sounds like the drum is not revolving at all on the spin cycle Could be quite a No of things, ie belt off or broken, motor carbon brushes need replacing, timer fault, speed control module fault, or even a broken wire or loose connection somewhere etc etc.
 Does it revolve on the WASH cycle? If so we can probably eliminate the above, in which case come back to me. Sorry no idea how much it will cost to fix. Have a look see what you find re above
Posted on Oct 19, 2007
Kenmore elite model 11027052602 clothes wet after spinning cycle why
You might have a restriction in the outlet hose. Worse, you might have a bad pump.
It is easy to check for the constriction. Pour water into the tub, set the timer for the spin cycle and watch how strong/fast the water leaves the hose. Check for water beneath the tub.
Oct 07, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
I own a Kenmore washer Model 110.22722100. The last couple of weeks, it leaves the clothes wet. It drains like it is supposed to and spins. What is causing this to happen?
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Here is the part you will need.
Nov 28, 2010 | Kenmore Washing Machines
Clothes still wet after cycle is over
Be sure drain hose is not kinked and no higher than the top of washer to drain pipe. Remove clothes as soon as it stops spinning
Jun 23, 2010 | Kenmore 23822 Top Load Washer
Cloth are still very wet after wash (it used to be very dry and it started happening since last week)
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Feb 07, 2010 | Kenmore Washing Machines
Kenmore Elite H3E Washer Drain/Spin Problem
hi
it is the belt problem
check it///thank u
please rate it
Jul 04, 2009 | Washing Machines
Series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Mar 20, 2008 | Kenmore 24622 Top Load Washer
Kenmore front load wet clothes
Before going further it is important to determine if the machine is reaching full spin. Make sure the unit is set to MAX extract and watch the inner tub. The tub should be spin really fast (1000 rpm's or better) during the final spin. If not you have lost one of the phases on the motor.
Jan 08, 2008 | Kenmore Elite 45986 Front Load Washer
Broken washer/dryer
This sounds like a motor control board is faulty. Please load a couple of towels in the machine run it. Watch the machine as it goes through its' cycles.
1. Do the towels tumble when the machine is washing ?
2. When it begins to spin, does it spin one way at a fast pace or does it spin one way and then the other ?
Answering these two questions will help in troubleshooting your problem.
Jan 07, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
471 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
