Onkyo hdmi problems
Onkyo HT-R680 with loss of sound for 1/2 to 1 second every 3 to 5 minutes on all hdmi inputs.
  • 151 Answers
SOURCE: DVD signal received in wrong aspect
PRESS SETUP GO TO MISCELLANEOUS PRESS ENTER THEN DOWN TO OSD SETUP PRESS ENTER AGAIN AND DOWN TO MONITOR AND CHANGE TO 16.9.
HOPE THIS HELPS.
CABLE GUY.
Posted on Jun 04, 2008
SOURCE: Cable TV blinks on and off when connected to my Onkyo receiver.
I have the same problem.  It only occurs with my HD DVR (HDMI cable), not my blue ray (HDMI cable), or my xbox and wii (component video).  Video and audio cutout is random and drives the family nuts.  I am desperate for a solution.
Posted on Mar 22, 2010
  • 4 Answers
SOURCE: I have an Onkyo TX-SR606 connected via hdmi to a
The problem is with the HDMI daughterboard in the AVR is bad. This is a well documented issue on this interweb! A general search in google can confirm. Here are some stuff cut and pasted frm their site and another forum. Onkyo USA Corporation (hereinafter referred to as Onkyo) hereby warrants all Onkyo products PURCHASED DIRECTLY FROM ONKYO OR AN ONKYO AUTHORIZED DEALER- WARRANTY PERIOD (from date of purchase) New Products: Receivers 2 years Parts & Labor-- You can go to the Onkyo webpage to find a n authorized service repairman.
*** I took mine to a service repair place today, the guy said that he had two that he just fixes yesterday. He said that this issue has given him a ton of work. Just make sure that you have your receipt from AN UNAUTHORIZED DEALER and that your still under warranty. Receivers 2 years Parts & Labor
Posted on Jul 31, 2010
SOURCE: onkyo ht-r960
I had the same problem at 1 year after purchase. I was upset. In addition to looking here, I also emailed the company. They took a month to get back to me, but their solution worked perfectly.
"Try resetting the unit by pressing VCR/DVR and the standby/on button at
the same time on the front of the unit while it is turned on. The unit
will display CLEAR and shut down. All settings will be erased. "
All my components connect without any problem now. Hope this helps.
Doug
Posted on Jan 17, 2011
SOURCE: I have an Onkyo HT-R680.
I've been having similar problems. I placed small fan to better circulate air in the closet I keep it in and that has fixed the problem so far. So some sort of thermal overload, I suppose?
Posted on Apr 26, 2011
The sound has gone out in my receiver, it is an Onkyo HT R680, do you have any suggestions
Owdy.. mon..
firstly. .are you technical enough. . To remove the amplifier cover and make voltage checks..?
Jan 26, 2015 | Onkyo Audio Players & Recorders
When i connect my onkyo ht-5300 system to my 60"sharp aquos tv with hdmi cables i get no video or sound
You need press the input button on your TV's remote.Then you need to select the input setting for HDMI.On mine,there is also an HDMI 2 input so depending on how your's is wired,it could be either one but that should get you what you want to achieve.Good luck,Greg
May 02, 2011 | Onkyo HT-S580 System
I have an Onkyo HT-R680. I have noticed after about an hour or more while playing Xbox or PS3 the sound will start to cut in and out. 5 secs of sound, 5 secs no sound. Continually like that untill I shut...
Feb 23, 2011 | Onkyo Audio Players & Recorders
I have a n onkyo av reciever ht-r560 only the front 3 speakers go on when im using it i know the rest work and are plugged in correctly because the volume tester outputs sound through it. Is there an on...
Your sound might not be working because the HDMI and optical audio inputs might not be working.
I made the mistake of buying the Onkyo HT-560 and in less than two years all of the HDMI video inputs started intermittently breaking. Sometimes when you selected the channel both the image and the sound would not come though.
Also the rear speakers stopped working from time to time and I have to run the setup again to get them to turn back on.
I am not sure that Onkyo was ready to introduce this technology, it has been a nightmare and my stereo is going to cost almost as much as I bought it for to fix it.
Oh and there customer service was no help, they just told to bring it to an "authorized service center for repair". They had also had no idea where there was one in my city it took them a day to get back to me.
The Onkyo HT-S5100 looks almost identical to the HT-560 not sure if they are different in anyway.
Stay away from Onkyo in the future! I know I will.
Sep 02, 2010 | Onkyo HTR500 Receiver
Mar 21, 2010 | Audio Players & Recorders
Onkyo ht-r960
Doug
Jan 20, 2010 | Onkyo TX-SR606 Receiver
I have a Onkyo HT-S6100 sound system which has the HT-R667 receiver. I have a DirecTV dvr hooked up with hdmi, a PS4 hooked up with hdmi, and a Wii hooked up through component cables. The receiver is...
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
Sep 26, 2009 | Audio Players & Recorders
Issues Displaying picture from HDMI upconversion
I've posted this other places. Hope it helps.
May 22, 2009 | Onkyo HT-S5100 Theater System
No audio from my PS3 through the Onkyo 5100 7.1
if you are using an HDMI cable dont expect sound to come out (even thought HDMI carries both audio and video) the onkyo HT-s5100's Receiver is the HT-r560. the 500 models of the onkyo receiver does not allow HDMI to carry both audio and video. it only allows the video signal to pass to the receiver.
if youre using optical for audio w/c is what you need then these are the steps you need to follow.
*first make sure that the optical connections are ok at the back of the receiver.
*make sure that your DIGITAL INPUT is set to either OPT1 or OPT2 whichever optical input you used to connect the optical cable.
*then go to your PS# settings : go to sound settings / audio moutput settings/ select digital out (optical).
then enjoy.....ü
Jan 27, 2009 | Onkyo HT-S5100 Theater System
What is the best audio configuration with this setup?
You can't just plug in optical cables. Both the TV and amp have to be adjusted to allow the different type of signals to pass. I have an Onkyo receiver myself and you have to set the sound type up for each input. It's a bit tricky to do without a manual, but you can probably download one for free if you have lost yours.
Mar 12, 2017 | Onkyo HT-S5100 Theater System
16 people viewed this question
 Grubhead
Grubhead
