Question about Dryers
Dryer shuts off when let go of the on button
Kenmore Gas dryer: Does not stay on after pressing on button, the ignitor glows when the button is depressed then lights however as soon as you let go of the button the dryer stops - please help!
  • 864 Answers
If the motor stops when the button is released check the motor relay switch. If the motor runs but the flame goes out check the flame sensor.
Posted on May 20, 2009
You have answered this question before but does the ignitor stay on during the drying cycle? Kenmore series 80, model 110 72822101 gas, It starts correctly, ignitor glows, gas ignites,run for 5 to 6 min....
yes..
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 07, 2011 | Kenmore 72802 Gas Dryer
Dryer is blowing cold air
If electric then the thermostat or the heating element has failed.
If gas: First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Feb 22, 2010 | Kenmore Dryers
GNSR465EB3WW
Jan 18, 2010 | Kenmore Dryers
Kenmore model 110.72702101. The dryer ignites when you first turn it on. When the gas shuts off it does not relight when the ignitor glows. I replaced the ignitor and the radiant sensor and still have the...
if you have already replaced the ignitor and the new one is glowing white hot, not orange, and you have replaced the sensor, then the next logical part to replace would be the gas coils. hope this will help solve the problem.
Oct 24, 2009 | Kenmore Dryers
Gas dryer turns on but does not heat up
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Aug 05, 2009 | Dryers
Sears kenmore gas dryer 417.92052101does not stay lit.
Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. If it glows for several seconds (up to 15 seconds) and then goes out, then the problem is probably the solenoids (coils). If the ignitor glows and stays on, then the problem is usually the flame sensor.
Jul 11, 2009 | Dryers
Maytag gas dryer runs but does not heat
If yo smelled gas then the ignitor may not be working.
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor does not glow then the thermostat is bad.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.   If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
May 30, 2009 | Maytag MDG2600BWW Gas Dryer
Kenmore Elite Dyer Model # 11071082000
Hi. thanks for the question. the problem you have is with the coils ,on the gas valve. 2 little coils . replace them. thanks the appliance doc
Sep 30, 2008 | Kenmore 72802 Gas Dryer
Kenmore elite gas dryer
Does the ignition glow when you start the dryer? if so you have power to gas valve and ignition system. if not you may have an open thermostat or thermalfuse.
If the ignitor just sits there and glows all day, you have other problems, It could be a gas valve, or ignitor sensor.
Jun 04, 2008 | Kenmore Elite HE4 Electric Dryer
Maytag gas dryer wont stay hot
Check the exhaust to see if it is clogged. If not, you may need a pair of gas valve coils (not very hard.)
Replace the coils if you see the ignitor glow and shut off, without the gas valve opening up.
Mar 09, 2008 | Kenmore 63942 Dryer
Dryers Logo
61 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
