Question about Arcsoft TotalMedia
Tv channels cannot be detected
I moved from kenya to malawi. i tried to change the region to malawi but i cannot detect signals for both the tv and radio. what should i do to correct the situation?
On my Techwood it as built in freeview but every other channel is right except bbc1 and bbc2 both channels say bbc wales,How do i get them back to bbc1 and bbc2 please PLEASE HELP.THANK YOU.
What you need to do is retune the TV, but when it is finished look at the regional settings. Or if the regional option is available before retuning, retune selecting your area so then you get normal BBC channels. It's likely that at the moment the channels for BBC are located at the very top end of the channel list say? - channel 800+.
You are clearly picking up signals from many transmitters. With regional settings you can change it to the area you live in.
But you will have to take into account how good your aerial is. Otherwise the signal quality will not be good on same transmitters. So the set may only suggest those with the best quality signals.
ITV stations might also change.
When done it will move the channels you mention to the top end of the guide, to 800+.
Note many HD channels have no regional options. For example here in Yorkshire we only get ITV Granada and not Yorkshire TV on the HD channel for ITV1. And BBC1HD does not show any programmes when local news comes on.
Jul 02, 2016 | Televison & Video
No Digital Channels Detected
Jason, good you have narrowed down the problem. So tv 1 does not detect channels. Re-connet and try making sure all cables are properly connected.
Mar 03, 2014 | RCA LED55C55R120Q 55" 1080p 120Hz LED HDTV...
Regional channel
you're stuck to use the tv tuner directly with a cable...
maybe try to connect your tv as a monitor only (AV1, AV2 ?) with a digital decoder sending the signal to it...
Feb 23, 2014 | Nvidia Computers & Internet
How do I change the channel on my Emerson LC320EM3FA 32" flat screen TV? I've tried the auto programming that does not work. When I press the channel button on the TV, it just changes the source...
Has it detected any channels? Are you connected to Cable TV wire or antenna? Has it worked before? Without it detecting channels, all it can do is change inputs.
Sep 08, 2013 | Televison & Video
Hooked up the tv to my existing cable and it will only receive 15 channels. All my other tv's receive many more like 100 +. I did the auto detect when I hooked up the tv and 15 is all it detected.
This is a fairly common issue, either the TV has the upper channels blocked or the signal in that room is just not as strong so a quick scan is passing them over. I will give you the steps to remedy both issues. If the channels show up weak or snowy or not at all after trying these steps you may need to install a booster where you current line splitter is but try these steps first as the TV can easily compensate for a slightly low signal.
Enter the TV Menu, Select TV, Select Channels, Select Master List. Look for channels with X beside them, if they have X they are blocked, simply move down the menu selecting each one to remove the X.
Now that you have verified or corrected your master list select Turn on Additional Scan from the scan menu and run a new scan. The additional scan will take a lot longer but will take more time on each channel and should find them even if the signal is a little low.
Hope this helps FixYa,
Chris
Jan 04, 2011 | Vizio M220VA 22 in. LCD HDTV
New auria tv with antenna will not stay on any of the number 61 channels like 61.1 through 61.4. Other channels are fine.
You are pointing your antenna on the wrong direction.Move it around until you find the strongest signal. When you did the channel scan, the box (or tv) detected a signal but since it is to weak now, it will not display it.
Jan 03, 2010 | Goldstar GLV-B1000 4 in. Television
Tv suddenly shows no audio and no video for digital channles only yet all digital channles are detected durring the channel search
Sounds like you have a bad signal from the antenna or the cable. Unlike analog TV if the signal level drops below a certain level you loose the picture and sound completely. The fact that digital channels are detected during channel search does not mean they have a good signal. Try moving the antenna about.
Nov 29, 2009 | Olevia 237T 37 in. LCD TV
Switching between a 720 hd channel and a 1080 hd
The unit has an auto detection circuit to determine what signal is being input, it then processes it, however if the signal is altered (different channel) the TV will at times try to process it through the wrong resolution circuit causing problems. Change the input of the TV and then change it back and it will redetect the 720p instead of the 1080i and display it properly. Check with Sony for possible updates.
Crampy
Nov 28, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
No channels can be detected have tried 2 Daewoo DS608P boxes connected to same telly but same thing happens. Signal strength seems fine boxes have been working fine for years.
I am the same. Not a sausage from my same model Daewoo freeview box today. Scans and re-scans and not a single channel to be detected.
Rob
Jul 05, 2008 | Televison & Video
No receipt of signal or antenae
Since it has voice or sound then I don't suspect the tuner but probably the tuner does not have the 33 volts that goes through r106 location number on the board. It is a 27K resistor and can be bought for about a dollar at Radio Shack. (pack of 2or3) A repairman or someone experienced in electronic soldering and desoldering can change it easily. Could cost around $50 to repair depending on the serviceman. If it has rca jacks (red, white and yellow) The tuner can be bypassed if you have a cable box that passed these signals: audio left and right and video. Hope this helps
Dec 30, 2007 | Sanyo AVM-3258S 32" TV
Computers & Internet Logo
Top Arcsoft Computers & Internet Experts
Piyal Perera
Piyal Perera
huzaifa mahmood
Are you an Arcsoft Computer and Internet Expert? Answer questions, earn points and help others
