Question about Archos 605 WiFi Digital Media Player
Connect connect my archos 605 with WEP address!!!
I just purchased the archos 605 80gb, I have been trying to connect it to the internet with my WEP address that I use at home with my laptop. I was using a 128 bit Encryption Level number/letters and the archos would'nt let me put in all of the numbers that needed to be put in, they cut me off before the numbers were finished and I could'nt put them all in. So then I changed my WEP address to a 64 bit one which gives me 10 numbers/letters, then tried to put those into the archos but when I hit 64 bit, it would only let me type in 5 numbers, not 10. I have purchased the web browser plug-in and would like to use it with my WEP key.... Can anybody help me out??????????????? Thanks
I have a 20 to 30 digit wep key and i just changed the settings to 128 bit and made it a hexadecimal wep. (hexa- ?) it should work.
Posted on May 27, 2009
SOURCE:
My archos 605 gen 5 cannot connect to internect
Try:- Menu Settings Language and Region WiFi Region.....set to "EUROPE" Followed by: Menu WiFi Status WIFi ...important that pasword format corresponds to that of your WiFI system eg WEP or WPA. The type of format will dictate the length of code. Generally WPA can accept a longer code than WEP format although a short code can be used for either. If your Archos is set to WEP and your WiFi network set to WPA (or vice versa) the format conflict will not allow the correct password to recognised It should be possible to use the
Dec 30, 2009 | Archos 605 WiFi Digital Media Player
Archos 605 160gb keeps switching off
I save all my data to an external hard drive, restored factory settings and then transfered my data back to the Archos. It seems to be working OK now.
Before anyone else tries this they need to make sure that they have the access codes for any plud ins that they've purchased.
Apr 05, 2009 | Archos TV Plus, 80GB 80 GB Hard Drive
My Archos 605 80gb cannot find my netgear wireless thingy!!!!
I had the same prob with a LinkSys. Puzzling for sure. Finally, I went to a Crystal restaurant (hot spot) and it connected. So, I knew it wuz my router. Finally stumbled on to the prob. I had to key in the 605 MAC address in the router table. Now, it works beautifully. You can find your MAC address under "Settings." Hope this helps!
Jan 18, 2009 | Archos 605 WiFi Digital Media Player
Archos 605wifi not switching on
Hi, my Archos 605 160GB is doing the same, Sorry to say the battery has gone.
2 options
1. Back to Archos
2. Replace the battery yourself I ordered mine from HK from the web site BatteryUpgrade. co. uk for about £24 - If you search on Utube there is a video showing you how to change the battery on smaller 605's
Jan 09, 2009 | Archos 605 WiFi Digital Media Player
ARCHOS 605 30MB SLOW INTERNET SPEED and OPERA BROWSER CRASHING: Speed tests from Speakeasy.net show download speed less than 300Kb/s and up load speed is 127Kb/s, while an adjacent wireless laptop...
How do I get internet away from my house on my archos 605 wifi, I can get it on my BTHUB in the house, is there a list of HUB I can conect to. when I try to conect a list comes up but they are all locked
Nov 11, 2008 | Audio Players & Recorders
Archos 5 - Wifi keeps failing
reset the router to factory default ,then set it again ,sometimes routers need this ,you should information in netgear website .
Its pretty simple and try setting up wpa ,its more secure
Aug 06, 2017 | Archos 605 WiFi Digital Media Player
Wireless connection
From the home screen, select the Wifi connection icon (middle icon on the right). It says 'scanning for networks'. It should then bring up any networks in range, including yours. Select yours and enter your WEP key or WPA key and click connect.
It should then connect.
Hope that helps.
Jul 31, 2008 | Archos 605 WiFi Digital Media Player
Cannot connect to network with WEP key encryption
It will not connect to a wireless network with WEP. it supports only the latest encryption. Try changing the encreption on your router to WPA or WPA2
Mar 17, 2008 | Archos 605 Digital Media Player
Archos 605 copying films from DVD to the player
If change the setting of the 605 to "hard disk" then a PC sees the 605 as a hard disc when connected using the usb lead. You can then copy and paste files directly to the 605..
Feb 19, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 WiFi Digital Media Player Logo
352 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Harrie
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
