Question about Vacuums
Ergorapido keeps cutting out - Vacuums
Where do I find the serial number please
Not all items made by Eureka have serial numbers. Unless its a high end machine, there won't be a serial number. You will only find a model number which is just a general number defining what model the machine is.
Oct 01, 2015 | Electrolux 2-in-1 Stick Handheld Vacuum,...
Electrolux ergorapido plus
Christmas 2013 I was given an Electrolux ergorapido. I put it on the charger and red light won't come on or if it by chance does it flashes three times and then cuts off.
Aug 13, 2013 | Vacuums
Electrolux 2 in 1 Ergorapido stick Vacuum. Motor runs then cuts out after 3 - 4 seconds. Sometimes it will run properly for 10 minutes so batteries are good. Why does it cut our usually?
If the hand held is working correctly (By itself) try pulling up a little bit on the 4 metal connection tabs on the wand. The connection tabs were not making a proper connection on my unit.
Oct 20, 2012 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Do i keep my ergorapido charged all the time when not in use?thank you
you can if you want to but in order to get the best of it when useing it you should keep charged
Dec 29, 2009 | Electrolux Vacuums
My electrolux ergorapido wont power on . Have only used it a few times. It has been on the charger for approximately 2 weeks without use.
If it will not come on there are several things you need to check. First off you should call and have your model type and serial number checked to be sure your unit isnt affected by the recall they had due to expanding batteries. Second you do have a 2 year warranty on the unit and if it wont even turn on there may be a defect. Are the blue charging lights coming on? If they are and your transformer is warm then there is more then likely a defective battery in the unit and you should contact customer service at 1800-896-9756
Jul 18, 2009 | Black & Decker AV1200 DustBuster Handheld...
Vacuums Logo
18 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
