Question about Bolt. MULTI port fuel injection throttle body. Emission
Harley davidson sportster i felt a washer or bolt come off my shifter on the inside and now i hear some clanking noise how do i check it and what are the steps to take also it sounds like it's dry inside but it has oil
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pontiac Master
  • 1,727 Answers
What were you doing to cause this issue. unless you are an experienced mechanic, this isn't something you should even try to tackle...
Posted on Dec 29, 2013
2008 Harley Davidson XL 1200 C Sportster Custom shifter adjustment
Hi, Angela for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can not find the best tool you ever bought for your Harley, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
Shifter Pawl Adjustment The Sportster and Buell Motorcycle Forum The...
Harley Davidson Gear Shift Linkage and Neutral Issues
Harley Davidson 2008 Sportster Service Manual
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
2008 Harley Davidson Sportster 1200 Custom Owner Manual
6ya Instant Expert Help To speak to me personally absolutely free
Jun 04, 2018 | 2006 Harley Davidson XL 1200 C Sportster...
What is the Banjo bolts on the front of a 1989 Harley Davidson Sportster?
i believe it is 10 mm banjo on the sportster front brake system
Mar 22, 2015 | Harley Davidson Motorcycles
My 06 harley sportster shifts up and now is stuck in 5th gear because it won't shift back down, the shifter moves freely going down, but won't change gears
Hi Anonymous, and the usual suspects are: shifter pawl, shifter cam, shifter cam follower, or shifter fork. I know you are crying your eyes out because you can't find the first and very best tool you ever bought for your Sportster to let you know which suspect it is. Well dry those pretty blues because for a mere $5.50 you can download another one, please visit website below:
Harley Davidson Manuals Mark Workshop
Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 10, 2013 | 2000 Harley Davidson XL 1200 S Sportster...
Engine diagram 1975
the shifter pawl spring needs to be checked.
Jun 22, 2013 | 1979 Harley Davidson XLH 1000 Sportster
2005 Harley Davidson XL 1200 R Sportster keeps slipping back in neutral from first gear @
Hi, Bigdog12319 and the usual suspects are:
1. Shifter pawl improperly adjusted.
2. Shifter drum improperly adjusted or damaged.
3. Shifter engaging parts/dogs badly worn or rounded.
4. Shifter forks bent.
5. Damaged gears.
1200 sportster slips from first gear to neutral
Harley Davidson 2005 Sportster Service Manual
http://mybikemanuals.com/harley-davidson/2005-harley-davidson-owners-manuals
Instant Tech Relief To speak to me personally absolutely "FREE"
Apr 10, 2012 | 2005 Harley Davidson XL 1200 R Sporster...
Under torque my 2002 1200 sportster sounds like the primary is skiping and make s clanking noise i have checked the primary chain adjustment and its fine it only has 800 mi on it
The large nut on the compensator sprocket may be loose causing the problem. I am a bit confused though. You aren't clear about what has 800 miles on it. Does the bike, a 2002 model, only have 800 miles on it or does the new primary chain have 800 miles on it? Either way, if it's doing this, I'd pull the primary cover off and check everything inside the primary.
Good luck
Steve
Oct 16, 2010 | 2002 Harley Davidson XL 1200 C Sportster...
My Harley 883 Sportster suddenly became stuck in 5th gear.
More than likely the shifter pawl has broken. Breaking in 5th gear is kind of unusual however, they usually break between first and second.
You'll have to remove the outer primary cover to look at the shifter pawl. It's partially covered by the clutch assembly.
Mar 07, 2010 | 1993 Harley Davidson XLH Sportster 883
2009 sportster makes clanking noise when shifting. also has a small loaf to it in low speed unless ridding the just alittle
tighten the primarary chain for the clang and up the low speed jet in the carb or if your feul injected temp sensor
Sep 02, 2009 | Harley Davidson Harley-Davidson Motorcycle...
05 sportster 1200 custom making a noise from
Sportsters are noisey beasts, are you new to Harleys if so it is most likely normal. I know when I first got mine it sounded to me like it was coming apart. I changed to Mobile 1 synthetic oil and it quited up.
Jul 10, 2009 | 2005 Harley Davidson XL 1200 C Sportster...
Bolt. MULTI port fuel injection throttle body. Emission Logo
26 people viewed this question
Top Pontiac Vehicle Parts & Accessories Experts
jerry emmons
Jeffrey Turcotte
Jeffrey Turcotte
Hashim Khan
Hashim Khan
Are you a Pontiac Vehicle Part and Accessory Expert? Answer questions, earn points and help others
