My mow videoke premium tkm-370p wo concerto pro 2 mic delay what to do?
  • 165 Answers
HELLO KRIS if your batteries are ok
adjust from the main menu and make some test to check if your voice is not delaying
adjust the tempo from 9 left too slow from 9 to right faster
best regards antonio
Posted on Dec 29, 2013
How to repair the blinking red light in my wow premium?TKM-340P.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Dec 19, 2016 | Televison & Video
Tkm- 340p videoke red light blinking same time screen also blinks but no display What is the source of problems
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Jan 10, 2016 | Televison & Video
How can I connect a microphone to yamaha rx v692
If your trying to have a PA sytem with these unit, you need to have a
separate mic mixer.
But if your trying to setup a Videoke Sing-along System , just connect
the Mic to the player Mic Input.
But if you need and feel to DIY, there is another option
and only if you can.
Oct 20, 2012 | Yamaha RX-V692 Receiver
How much round up PRO do you mix per gallon of water
It depends on the amount of active ingredient you need to kill the plants in your property. The rate is dependent on the size of the plants. For a final concentration of 1/2% (plants under 6" in height - do not mow them short the day before spraying), you need 2/3 oz of Roundup Pro (not the Roundup Pro Concentrate). However, if your area has perennials that are larger (stressed or 1-2 feet tall), you might need 2% Roundup, and then you need 2 and 2/3 oz of Roundup Pro.
Please read the label for your product and identify the plants in your location to get the appropriate rate.
Many Monsanto product labels are available as PDFs here: http://www.cdms.net/LabelsMsds/LMDefault.aspx?manuf=23&t= .
Do not mow or disturb the plants for three days after spraying. You may need to apply the Roundup in 7 days to get any plants that you missed (or weren't affected by the first dose). Wait another 3 days after the second application before planting in the area.
I hope this helps.
Apr 23, 2011 | Roundup "" Weed & Grass Killer
There is a 2 second delay with my snowball. I am trying to record and a vocalist needs to listen to their voice quality when doing so, however it is very difficult to actually record with headphones on...
The delay isn't the mic, it's the mixer or how you're routing signal that's causing delay. If you're using a stander mixer use 2 separate "aux.'s" one for your vocalist and 1 for yourself. OR i aux for your vocalist and you listen to final output (stereo mix)
Mar 02, 2011 | Blue Microphones Snowball Professional...
Tape loop
You may need to purchase a cheap external mixer with both mic and line inputs, and use that to mix the mic with the DVD audio. In most receivers, you can only select one input at a time. The output of the mixer can then be plugged into any spare receiver input, such as AUX, CD, DVD, etc. When not using Karaoke, you can simply turn the mic input down to prevent it from interfering with the DVD signal, but will still need to have the mixer on to hear DVD's.
Jun 26, 2008 | Onkyo TX-DS797 Receiver
Broken karaoke mic ed8000 model
Hi im joe,
if the screen says no font, no picture, no song data it means all the data installed was lost. you have to send it to the nearest service center to have it reprogram.
Feb 24, 2008 | Magic Sing Along Consumer Microphone
Wantind to add mics to my karaoke machine-Vocopro GiGMan karaoke system
I'd get a small mixer, then run mics into that, mix em down to 2 channels then send em to the karaoke machine, that way you have control in mixing multiple mics down to 2 channels, I wouldn't bother with 1/4 " mini plug mics or splitters personally.
A D.I. box ( direct injection ) takes an instrument or line level signal through a step down transformer and it comes out the other end as a mic level signal, the purposes of it are for running an electric instrument into it wich is split into 2, one for going to the input stage of a mic pre, the other can go back out to an instrument amplifier, this way you can run a direct signal into the console via " direct injection " into the mic pre as a mic level signal and also can run it to your instrument amplifier in order to be able to also mic the speaker cabinet acoustically at the same time, there are many benefits to this, for instance in live shows if the speaker cabinet or mic fails then you still have the direct signal, also since the direct signal tends to be punchier and clearer, cleaner, than an acoustically mic'd signal, they can both be mixed together at the console to give a a desired blend of each signal. Since there is a small delay between the direct signal and the acoustically mic'd signal because of distance of the mic from the soundsource delaying the direct signal a bit may be desired. D.I. boxes are only for instruments, they are superflous for vocals, the quality of the D.I. box does matter and active D.I.'s are the way to go, passives are as they are in speaker crossovers, less than desirable quality. There are also many tube D.I. boxes, generally a D.I. box isn't necessary for running an instrument into a consoles mic pre because most consoles take line level inputs as well, and there are other ways for getting a line level signal into a console by bypassing the mic pres anyways, If you have quality mic pres it's good to use them for the initial gain stage though as opposed to boosting instrument level to line level using a crappier preamp, for instance running an electric instrument input through an effects pedal will raise the instrument level to line level but of course an expensive mic pre will do a better job of it than an effects pedal will, since the first gain stage is paramount to quality......................
Nov 17, 2007 | Audio Players & Recorders
97 people viewed this question
 Grubhead
Grubhead
