Normally in all phones as it is switched ON the time needs to be set before the main menu comes up. So as soon as the time window comes up you can set the time, time zone and proceed. Also you can access time setting from the MENU>settings> clock/time/date set. Open the window and proceed.
Sometimes turning the screen on and off then pressing home will help. To prevent it from freezing try looking at the programs that are running (Menu--> Settings-->Applications-->Running Services) The less apps running the more stable the phone will be. You can also uninstall unused apps.
To Hard Reset Samsung Seek to Factory Default Setting:
1. From Home menu screen > Main menu tab, located at the bottom
2. Tap Settings
3. Scroll down to the bottom of your cell phone menu
4. Tap Reset
5. Tap Reset Settings
6. Read the statement displayed then Tap Proceed
7. Enter the 4 digit number then Tap Done
If you want to unlock it
Software reset Samsung Seek M350:
-From the Home menu screen , touch the Main menu tab, located at the bottom -Touch Settings -Scroll down to the bottom of the menu -Touch Reset -Touch Reset Settings -Read the statement displayed then touch Proceed -Enter the 4 digit number then touch Done Hard reset Samsung Seek M350:
-From the Home menu screen , touch the Main menu tab, located at the bottom -Touch Settings -Scroll down to the bottom of the menu -Touch Reset -Touch Reset Phone -Read the statement displayed then touch Proceed -Enter the PIN then touch Done to confirm the Phone Reset
Your Samsung Seek M350 will run quicker after resetting it. You can check it, hope you like my work.
Good Luck and please rate 4 thumbs up for the free answer
To make sure that the monitor is ok, do you by any chance have an option to connect it to some other monitor? Or even your tv ...it should have a VGA in the back. It can be that your video failed on the motherboard of your computer. Let me know then we can proceed with the other step
lens assembly (barrel unit) struck up. slightly push lens while power off & pull the lens while power on. repeat this 2 to 3 times it will works. dont apply any oil in the barrel unit. but you may use body spray or room spray to solve this issue permanently
Set TV to standby and press Info, menu, mute then power. The set
should turn on with the service menu available scroll down until you
select reset press right hand arrow next to enter and then enter. TV
will turn off. When switched on it goes into Plug and Play mode to
reset the analogue and digital tuner. Allow a full reset then you
should be ok.
Sounds like a bad digital board to me. Not too hard to replace in those models but, you do have to write down a few settings before replacing it. These settings are available in the service menu. Any questions let me know [email protected]
