Question about Cell Phones
Master reset for zte-cf350 - Cell Phones
ZTE projector needs a factory reset how can I fix this problem
Master reset from settings menu
A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloads, ringtones, images, apps, contacts, and Visual Voicemail. It does not delete data stored on the SIM card or SD card.
  1. From any Home screen, tap Apps > Settings > Backup & reset > Factory data reset > Reset phone.
  2. If your phone is password protected, you'll be prompted to enter your Pattern, PIN, or Password.
  3. Tap Erase everything.
Master reset with hardware keys
A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloads, ringtones, images, apps, contacts, and Visual Voicemail. It does not delete data stored on the SIM card or SD card. If the device menus are frozen or unresponsive, you can master reset using hardware keys.
  1. Back up data on the internal memory.
  2. With the device turned off, press and hold the Volume Up and Power buttons until the ZTE logo screen appears, then release.
  3. Press the Volume down button to highlight wipe data/factory reset.
  4. Press the Power button to select.
  5. Press the Volume down button repeatedly until Yes -- delete all user data is highlighted.
  6. Press the Power button to select.
  7. Wait as the device resets.
Device resets ZTE ZMAX
Feb 12, 2018 | ZTE Cell Phones
How to master reset zte z798bl
Hi @Kyle Glenn
Please follow the steps below:
Hope this helps!
Nov 01, 2017 | ZTE Cell Phones
I recently got a used ZTE 2958 and it wont advance past the google sign in screen due to a previous reset. No info known re former owner. Suggestions?
You need to do a factory reset.
If the device menus are frozen or unresponsive, you can master reset using hardware keys. To perform a master reset, follow these steps:
  1. Back up all data on the internal memory.
Jul 22, 2016 | ZTE Cell Phones
1 Answer How do i get passed the previous owners google account on my zte mavern
Hello, i sugest a Data Master Reset...
Settings >Backup and Reset >Data Master Reset.
You'll have all sorts of junk on your phone from its last owner until you do :-)
May 28, 2016 | ZTE Cell Phones
Need motorola ZTE locked up don't know why need help ASAP please help
Do a soft reset as described.
A HARD reset removes EVERTHING and put the phone back to new. All Data GONE.
  • ZTE Warp - Soft reset ' Phone Tips and Tricks www.phonetipsandtricks.com/tips/zte-warp/soft-reset-76 ZTE Warp - Soft reset - To soft reset your phone press and hold the Power and Down button together for 10 seconds and the phone should restart. Wait about 10 seconds ...
  • DROID - Master Reset / Factory Data Reset - Motorola Support https://motorola-global-portal.custhelp.com/app/answers/detail/a... Factory Data Reset is a tool used to remove everything that was imported, added or installed on the device. WARNING: When using this feature; everything is deleted.
  • Reset Cell Phone ::: How to reset ZTE resetcellphone.com/solution/ZTE How to hard master reset ZTE series cell phone One stop site for cellphone ( mobile ) hard master reset instruction to factory default for all makes - alcatel apple ...
  • Jan 02, 2016 | Motorola Cell Phones
    ZTE Savvy Z750C stuck on startup ZTE logo
    Go as though you are going to perform a master reset as per the tutorial here http://www.satechhelp.co.za/39/rest-zte-savvy-straight-talk?show=39#q39 but select "Wipe cache partition" instead, reboot using the "Reboot now" option and see if it doe not get passed the logo screen. You will have to perform a master reset as per the same tutorial on the link above if the issue still persist.
    May 03, 2014 | ZTE Cell Phones
    I cannot access the internet on my zte warp n860 after i did a master reset
    You need to contact your service provider, as the phone is master reset, you need to install the internet setings on the device again. Also check if the data plan is active on your device after the reset.
    Dec 14, 2012 | ZTE Warp Android N860 Smartphone With Car...
    Master reset security zte f160
    please follow the below steps;-
    MENU--Settings,Select Master Reset to reset the phone to the default factory settings.
    Note:the default password is 0000.
    Nov 01, 2011 | ZTE Corporation C78 Cell Phone
    Can you please help me unlock my zte f160 phone?
    hey i am in the same boat...Got this link. I am hesitant to try because i don't wanna spent that much money for $10 refurbished phone...
    http://www.gadgetoz.com/post/how-to-unlock-att-f160-phone/
    Mar 28, 2011 | Cell Phones
    Cell Phones Logo
    16 people viewed this question
    Top Cell Phones Experts
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
