Question about MSI Computers & Internet
Fan on full speed and than switxh off msi cx700
As stated in the 2 comments, the cooling system was cleaned and the problem remains.
  • 41 Answers
Check your graphics cards control pannel if you have one and you may have a manual fan adjust their, if not try a utility called speedfan which lets you manually adjust your fan speed.
Posted on Jul 10, 2014
I have 2007 Suzuki XL7. I replaced radiator and fan assembly. Fans do not work. Is there a relay? If so, where is it?
Most fan and Ac relays are located in the under hood fuse and relay box. Adequately marked in owners manual or on plastic cover
Sep 03, 2016 | Suzuki XL7 Cars & Trucks
Cooling fan is too slow.
  1. right click the battery icon on the bottom right toolbar
  2. select "power options"
  3. select "high performance" (if not visible use drop down to show additional power plans)
  4. click "change plan settings"
  5. click "change advanced power settings"
Feb 19, 2014 | MSI Emachines E528 Original Laptop Genuine...
Laptop cooling fan running at very high speed
Try loading and using a program called speedfan to control your fan speed if that is appropriate. This can also show you your CPU temperature (if you can figure it out). Core Temp can show you temperature of modern CPUs, amongst others.
Otherwise try cleaning you CPU of dust - search the internet as to how to this safely.
18.April.2014
Feb 05, 2014 | MSI pr600 fan
You will need to disassemble the fan and clean off dust accumulated. also check for any obstruction of the fan slot.
Dec 29, 2013 | MSI Computers & Internet
Black screen problem
Hello there, I am the computer technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Pavle Suboti.
Your computer is overheating and is shutting the video off to prevent damage. It is most likely the graphics card that is suffering from too much heat. Clean the card of dust if present.
Also it is important to install lots of 120mm fans in modern computer systems to expell heat and introduce freash cool air from outside the case into the system.
Use a program called MSI Afterburner to adjust fan speed to a set heat vs fan speed curve. This allows one to set fan speed higher for high tempreatures. For a cool graphics card.
Leave the program open to see how hot your graphics card gets.
Chat to gaming friends or google to learn how to use MSI Afterburner effectively.
A cool systems is a happy system.
Take care!
Apr 15, 2012 | ASUS Video Card EAH6850 DC/2DIS/1GD5...
Hello, I have a 1995 mercury sable and just replaced the upper radiator hose last weekend and for the past week, I have been dealing with overheating, I have added 50/50 coolant and the temperature...
First replace your Thermostat, and then have your Electric cooling fan checked.
Try getting a scan at Autozone, Advance, or Oreillys autoparts. They will do it for free. Or if you just want to buy a few parts, observe if the cooling fan even comes on. There are 2 temperature sensors on most Ford's and one makes the dash gauge work and the other makes the Electric cooling fan work. Just have the car a little warm and when you get the dash gauge to move, disconnect the temp sensors one at a time until you find the one that controls the gauge. The remaining sensor controls the cooling fan. Remember, the gauges only work when the engine is running.
If your cooling fan still does not work, ask the parts guys how many speeds your vehicle is suppose to have on its fan. Usually, when the A/C is turned on, high speed kicks in; for sure when you have overheating, it should be on high speed. The Electric cooling fan has a Relay that can be bad. The fan motor can also be bad.
The loss of Antifreeze in the system can be from boil over. As long as the car runs decent, there is no reason to expect a blown head gasket. With the Radiator cap off, you may be able to see bubbles on the surface of the radiator if a head gasket is allowing compression to get into the cooling system.
Just start with the easiest things like a Thermostat, then go to the next solution and work your way through the possibilities. I hope my comments are useful to you.
Jun 26, 2011 | 1995 Mercury Sable
Code p1652 on a 1996 pontiac grand prix does anyone know what it means the book for computer codes is incomplete
Trouble code P1652 means: Cooling Fan 2 Relay Control Circuit Malfunction
I would start by checking power supply to the cooling fans,making sure the coolant system is full,& using a scn tool to verify the proper operation of the cooling fan system.Here is some info to help you.
The Powertrain Control Module (PCM) controls the operation of the cooling fans. This is accomplished by providing a ground path for the cooling fan relay coils within the PCM. The relay contacts will close and complete the circuit between the fusible link at the battery junction block and the fan motors. Whenever there is a fan ON request both fans will be running.
Power for the fan motors is supplied through a fusible link at the battery junction block. Battery positive voltage is applied to the cooling fan relay contacts and coils. The cooling fan relays are energized when current flows through the relay coils to ground at the PCM. The cooling fan relay #1 control circuit is used for low speed cooling fan operation. The cooling fan relay #1 control circuit and the cooling fan relay #2 and #3 control circuit are both grounded for high speed fan operation. The cooling fan relay control circuits are monitored by the PCM. Before using the Electric Cooling Fans diagnostic tables be sure to perform the Powertrain On-Board Diagnostic System Check. If diagnostic trouble codes P1651 or P1652 are present, use the appropriate DTC diagnostic tables prior to performing Electric Cooling Fans diagnostics.
Important:
When certain Diagnostic Trouble Codes (DTCs) are present, the PCM may command the cooling fans to run all the time. It is important to perform the Powertrain On-Board Diagnostic System check prior to diagnosing the engine cooling fans.The PCM will complete the ground path for cooling fan relay #1 under any of the following conditions:
- When engine coolant temperature exceeds 105°C (221°F)
- When A/C is requested and ambient temperature is greater than 10°C (50°F)
- When A/C refrigerant pressure is greater than 190 psi (2 volts)
For high speed cooling fans operation, the PCM will delay control of the cooling fan #2 and #3 relays for 6 seconds. The 6 second delay ensures that the cooling fan electrical load will not exceed the capacity of the system. The PCM will complete the ground paths for cooling fan relays #1, #2, and #3 under any of the following conditions:
- When engine coolant temperature exceeds 113°C (235°F)
- When A/C refrigerant pressure is greater than 275 psi (2.9 volts)
If a problem that involves the low speed cooling fan relay control circuit (cooling fan relay #1 control) exists, DTC P1651 should set. If the problem affects the high speed cooling fan relay control circuit (cooling fan relay #2 and #3 control), DTC P1652 should set. A problem with the ECT sensor should set DTC P0117, P0118, P1114, or P1115. Any of these DTCs will affect cooling fan operation and should be diagnosed before using the Electric Cooling Fan Diagnosis table. The Electric Cooling Fan Diagnosis table should be used to diagnose the PCM controlled cooling fans only if no DTC is set.
Hope this help to solve your poblem (remember rated and comment this help).
Mar 21, 2010 | 1996 Pontiac Grand Prix
What is the fan speed supposed to be on a speeze 5t321b1h3cpu cooler? k
4200RPM - But most all systems control the fan speed and speed them up to cool as need. so they will rarely even run at full speed.
Feb 28, 2010 | Spire Speeze Cooling Fan CPU Heatsink &...
My lcd screen on my new msi cx700 keeps flickering and going black. if i press the top corners of the screen bezel the screen returns to normal.Could this be a bad screen, backlight, inverter, something...
This may be due to the inverter board found behind your lcd panel.
Take it apart & solder the two sides of the coil found on the inverter board. This loose solder is caused by heat.
Please send me your feedback & vote to motivate us & to help us help you.
Feb 11, 2010 | MSI CX700-020US INTEL R4330 T4200 SYST2.0G...
Infocus in26 fan runs continually
The fan does run continuously on this projector however it should be running very very slow when the projector has completed it's lamp cool down routine.
The reason for this is that a portion of the switching power supply remains energized (running) when the projector is at rest. But as I mentioned it should run very slow in this state. If it remains running full blast then most likely the fan speed control chip is shorted which can cause fail 2 ways, either the fan 1. runs full
speed or 2. remains stalled (then the projector will go over-temp and shut itself down) I hope this answers you question.
Cheers
Dec 18, 2008 | InFocus IN26 Multimedia Projector
Computers & Internet Logo
73 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
