Question about LaCie 32GB PetiteKey USB Pocket-Drive
How to remove write protect on usb lacie petite key
How can I remove the write protect on lacie petitekey 32gb?
Why my computer is not reading lacie cookey usb
your usb key may have failed or it is in a different format that your pc cant read
Mar 24, 2014 | LaCie Cookey Flash USB Key - 32GB
Remove write protection
try formatting it through low level format tool.
Mar 01, 2014 | Centon Data Stick Pro 32GB USB Flash Drive
Disk is write protacted
To remove write protection:
Open Start Menu >> Run, type regedit and press Enter. This will open the registry editor.
Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Double click the key WriteProtect in the right pane and set the value to 0
In the Data Value Box, press OK
Exit Registry, restart your computer and then re-connect your USB pen drive to your computer.
Dec 31, 2013 | ADATA A-data USB 2.0 Drive, C008 Series,...
My 32GB USB Drive needs formatting but when I try it says that it is write protected. How do I remove the write protect?
Follow the steps to remove the write protection from the pen drive:
1. Open the Windows Registry Error by pressing a shortcut Windows-r
2. Type regedit into the form and press the return key on the keyboard.
3. Navigate to the following Registry key:
4.Double click the key Write Protect in the right pane and set the value to 0 In the Value Data Box. Press OK
5. Exit Registry
6. Restart your computer and re-connect your USB pen drive on your computer.
Mar 05, 2013 | Computers & Internet
LaCie Rikiki Hi Speed USB 2.0 320 GB Hard Disk repair
Check Device Manger and Disc Management. Best I can do with translation problem. Good Luck
Aug 27, 2012 | LaCie Petit Hard Disk hard drive - 320 GB...
How to remove write protection from datatraveler 32gb
  • Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
  • Navigate to the following path:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlStorageDevicePolicies
  • Double click the key WriteProtect in the right pane and set the value to 0
  • In the Data Value Box, press OK button
  • Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer.
That is it, done. Goodluck
Jun 16, 2011 | Kingston Technologies 512MB DataTraveler I...
How do I remove the write protected on my Lacie 500g external drive?
Steps to make your drive Write Protected Or Remove write protected:
1. Open Registry Editor by typing regedit in Run dialog.
2. Navigate to the key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\
3. Find a sub key inside it named “StorageDevicePolicies”. If it does not exist there then we need to make it. Right click on “Control” key -> New -> Key. Name it “StorageDevicePolicies” without quotes.
4. Now right click on this newly created key and then click New -> DWORD value and name it as “WriteProtect”.
5. Modify this key and give it a value 1.
6. Click OK, and remember to restart the PC.
Now no more data can be transferred to the drive but to start using the drive again just give the “WriteProtect” key a value of 0 instead of 1 and restart the PC.
Aug 12, 2010 | LaCie (301146U) 320 GB FireWire 400...
LaCie d2 Quadra drive... not showing up on PC after working on a MAC
You need to make sure the drive is formatted for the PC. The Mac will read and write to a FAT32 partition, but the PC cannot see a Mac formatted drive as you have seen.
The only problem is that there is a 32Gb limit per partition for FAT32 drives.
It's not ideal but it's the best you can do easily.
Jan 13, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie 32GB PetiteKey USB Pocket-Drive Logo
213 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
