Question about HP Computers & Internet
HP D9811 monitor freezes and then starts blinking on and off
I can be searching the net and then wham... the screen image gets all distorted and then the monitor starts to blink on and off, as if its trying to correct itself. I have to just power off the computer from the power button since the mouse freezes as well and the crt+alt+del doesnt work either. Once I restart it works fine until at any random time it happens again. Could my monitor be going bad? It is a kinda old(2001) as is my computer. the computer came with Win 98 but has been upgraded to XP. Thanks in advance.
    Novelist:
  • 118 Answers
Since you mentioned that your mouse freezes and your keyboard freezes, I'm pretty sure your problem does not exist in your monitor at all, but in the computer itself.
The first place I would look for a fix is in your video card. Since you started with a 98 machine and upgraded to XP, I'm not sure how that was done. It has been problematic in my experience to run a FAT32 file system under a XP operating system, and in those days it was a common upgrade.
The problem with it was, and is, that the drivers are built for an NTFS file system and FAT32 is on your pc.(maybe)
The first change I would make (well, as a tech, it would be to erase the hard disk and reinstall the os, but let's just talk about the fix here) is to look at the drivers for the video card, and check with the manufacturer of the video card for the most current one.
If that is already the most current, check the file structure to see if it is FAT32; and if so, consider backing up your data and reinstalling the OS under NTFS files structure.
good luck
tony
Posted on May 20, 2009
  • tony price
    tony price May 20, 2009
    good luck
    tony
Wide screen stretches all my photos
Wide screen monitor distortionDepending upon the screen resolution that has been set inDisplay, the image will be distorted on these large wide screen monitors.
Create a large circle image using a draw program such as Paint (hold down theShift key as you create the circle as it will draw a perfect circle).
Open Control Panel - Display - Settings tab and adjust the Screen resolutionslider, increase or decrease the screen resolution then bring the circle imageto the front and check the image, if the circle is still distorted then changethe screen resolution and check the circle again until you are satisfied withthe image of the circle. When you are satisfied then click apply.
Dec 09, 2011 | Samsung Computers & Internet
Tip
Wide screen monitor distortion Depending upon the screen resolution that has...
Depending upon the screen resolution that has been set in Display, the image will be distorted on these large wide screen monitors.
To correct this distortion.
1. Create a large circle image using a draw program such as Paint (hold down the Shift key as you create the circle as it will draw a perfect circle).
2. Open Control Panel - Display - Settings tab and adjust the Screen resolution slider, increase or decrease the screen resolution then bring the circle image to the front and check the image, if the circle is still distorted then change the screen resolution and check the circle again until you are satisfied with the image of the circle.
3. When you are satisfied then click apply.
on Feb 24, 2011 | Computers & Internet
I have an HP LP2065 monitor that I am trying to hook up to a laptop. When the monitor is hooked up it will flash the image on the screen and then go out. When you push the input button on the front of...
The monitor is faulty, this is confirmed when you connected to several laptops.
The fault could be a faulty inverter board which supplies high voltage to the CCFL lamp for the back lighting. Have a close look at the monitor at a sharp angle, if you see a faint Windows image then it is definitely a back light fault.
For parts, check out these WEB sites.
LCD screens and Inverters
www.lcdparts.net http://www.yallstore.com http://www.shope2.com/ http://www.invertercentral.com/qrySearch.asp?Adword=1500&search=1500&Campaign=Google-Models-NA&gclid=CO3lg7HJlKMCFQcbewodZB2qoQ http://www.nylaptopparts.com/ http://www.ccflwarehouse.com/
Mar 05, 2011 | HP LP2065 Monitor
Screen stretched out horizontally and distorting picture. None of the settings buttons appear to solve this. I can shift the image vertically or horizontally; but not squeeze it horizontally.
There are adjustments in the size of the items on a screen under the screen properties, settings. If you right click on the desktop screen and then properties you can get there. There is at least one size which causes a distortion of images being displayed. This may be your problem.
Feb 28, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
A box stating not optimum mode-get distorted internet images
Sounds like your resolution is not set correctly.
Try going to Start-->Control Panel-->Display and choose the Settings Tab
Under there change the resolution slider bar to 1280x1024
Should do the trick!
Jul 11, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Monitor freezes up with multicolor wording or distorted images
Sounds to me like a few possible things...
1) Bad connection to the monitor, check the cable connection, if you see or suspect any damage, buy a new monitor or test with a friend's monitor.
2) Video card could be bad, if it has a video card, you could simply buy a new card to see if it will fix the problem. If the video port is attached to the motherboard (meaning onboard video), the motherboard could be damaged.
3) The motherboard could be bad. Sometimes fried motherboards will garble the screen like this on bootup.
Mar 25, 2009 | IBM Computers & Internet
Hp 2 2207 monitor problem
You need to update your video drivers. If there is no upgrade, than buy a new video card from walmart for 80.00. This will solve your problems.
Mar 05, 2009 | HP w2207 Monitor
Screen image appears fuzzy, jumpy and broken up into lines.
gardenman13, I would certainly complain to HP about their w22 monitor!! Find out if the units warranty is still valid and can be swapped-out for a REFURBISHED unit. Your w22 shouldn't be hazy, distorted, or flicker for any reason. My best guess is that it (w22) has problems inside with it's "cold-cathode-fluorescent-lamps" and electronic ballast circuit called an INVERTER circuit, which could also cause the main "switch-mode-power-supply" to go a little NUTS upon STARTUP!! FYI you are dealing with a technology similar to the curlie-Q CFL screw-in light bulbs. Their ballast's are called CONVERTERs (ac to ac) and are cheaper. Your lanps are thinner and straight, hung on rear of your LCD panel. I hope this was informative. Please rate this on fixya. 12fixlouie
Dec 11, 2008 | HP W22 LCD Monitor
22-inch Wide screen X2Gen LCD Monitor
Monitor Help CH000241, No display on the monitor. CH000242, Distorted or skewed image on monitor. CH000243, Monitor has a tint of one color.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Gateway FPD2275W LCD Monitor
TV shuts off automatically
I Can Assure You That This Problem Is Associated With 2 Capicators On The Power Supply Board.
Aug 24, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Computers & Internet Logo
214 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
