Question about Refrigerators
Replace bulb on gva fridge - Refrigerators
?y light is out and I don't know where the light is so I can replace it. I can't find my manual. Model number: GX5FHDXVTOO. WHIRLPOOL FRENCH DOOR
There should be a plastic grille mounted on the ceiling of the fridge, usually, a good tap with the palm of your hand, towards the rear of the fridge will pop the grille loose and expose the light bulbs. Be sure to replace the bulbs with 40w appliance bulbs only! if replacing the bulb doesnt work, you may need a new light switch or the metal tab in the bulb socket may not be contacting the base of the bulb properly...
Apr 25, 2016 | Whirlpool Refrigerators
Need a remote control for a gva 42inch plasma TV. Have tied to remotes all ready none worked.
http://www.ebay.co.uk/sch/i.html?_odkw=remote+control+for+a+gva+42inch+plasma+TV&_from=R40&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.TRS0&_nkw=remote+control+for++gva+42inch+plasma+TV&_sacat=0ub5kip
May 06, 2015 | Televison & Video
How to change a light bulb in a diplomat fridge
I Googled Diplomat Fridge light bulb and came up with this: Copy www.youtube.com/watch?v=U-yyPGlRoZ0. Go down the page until you come to a video called "How to replace a fridge light bulb". It is there, you have to look.
Jan 02, 2015 | Refrigerators
Light inside fridge
unplug from power unscrew the bulb pull the bottom bulb contact out slightly replace the bulb plug in and, test
otherwise replace the bulb
Nov 18, 2013 | Furniture
"FR-480" & "fridge light not working"
remove the plastic cover after turning off power to fridge. the bulb will be a screw in type and may be simply loose in the socket. If not remove the bulb . Replace the cover and get a new bulb turn the machine back on until you do Any electrical wholesaler will have one Take the bulb as a sample.
Apr 29, 2013 | Refrigerators
Correct code for a old gva tv
GVA was Good Guys brand made by Hisense Try code 0208
Mar 27, 2011 | One For All URC-3415 Remote Control
Why do my lightbulbs keep blowing
Hi there and welcome to fixya,
There are a lot of attributes to that.. it could be unregulated voltage or a poor bulb quality. I recommend buying a higher quality bulb or better, replace it with the same type (fridge bulb).. some bulbs can't handle sudden temperature change inside the fridge that's why.
Hope this helps
Dec 28, 2010 | Refrigerators
Remote control for gva hgg6830
I do not know who the primary manufacturer of GVA is but I can tell you who sells the brand. I provided a link to the web site. As far as universal remote go I don't think you will have much luck because GVA is what known as a house brand.
Hope this helps.
http://www.thegoodguys.com.au
Aug 24, 2009 | Macally Televison & Video
GVA TV
I have a GVA TV problem with his remote First four minutes it work properly then stop working. Batteries replaced many times still same problem. Give the solution.
Jan 12, 2009 | Televison & Video
Refrigerators Logo
21 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
