Question about Car Audio & Video
I have a gm-3500t two channel power amplifier and I have a 2006 cobalt and the batterie in the 2006 cobalt is already in the trunk so I wired the 400watt amp with 1200watt cable to the stereo and put the hot wire on the batterie and grounded the negative and wired my subs and my power light is not coming on like my amp is getting no power and I checked the end of the hot wire connected to the amp and there was power so I'm stuck and answers???
    Habit-Forming:
  • 21 Answers
Make sure you have a good ground, and also check the fuse.
Posted on Dec 29, 2013
5 Suggested Answers
Zealot21
  • 83 Answers
SOURCE: we installed the amp with
In car audio always make sure that you are feeding your amplifier with the voltage that it requires, usually 12v to 14v (some amplifiers can do 12v to 18v). If you have a voltmeter, check your voltage reading if its reading 12v above, if it reads 11.9v below & just stays there & keeps on going down then your problem is with your voltage.
The possible causes of the protect light to turn on in a amplifier is: 1. low voltage - the amplifier is not running on its required voltage / is not getting enough voltage 2. thermal protect - too much heat, usually this occurs when an amplifier is in a tight space & the voltage keeps going down this will cause heat. 3. shortage - wire's are touching each other 4. poor ground - always make sure you ground your amplifier to your vehicles chasis
Hope this helps your concern. Have a blessed weekend.
Posted on Apr 24, 2011
  • 112 Answers
SOURCE: Amplifier and sub installation in a boat.
norally grounding them in the same place is ok but it could just theres not enough power from the amp too power two subs try hooking up one and see if that gives you the sound your looking for
Posted on Jul 09, 2009
etirbynnor
  • 655 Answers
SOURCE: amplifier loads
Hello ronnieyannon,
A single 4 ohm speaker wired to each channel, like you have them wired, presents a 4 ohm load. And it appears that you have them connected properly. The 401s is only stable to 4 ohms when bridged, so if you were to parallel the 2 4 ohm subs in bridged mode, the load would be 2 ohms and the amp would most likely overheat and go into protection.
I'd wire them the way you have them wired.
Each channel of the amp outputs only 100 watts into 4 ohms. That is adequate for regular full-range speakers, component speakers, mid-range drivers, and even some small subs. But it is a little low on power for most subwoofer applications.
Hope this helps.
Posted on Apr 23, 2009
  • 7 Answers
SOURCE: Thumping speakers - no power light is on - wired correctly
the amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
Posted on Nov 02, 2008
How to open my truck on 2006 cobalt
can u get to the bat underneath the vehicle and very carefully touch one to a good - grnd on vehicle and touch other cable or heavy wire to posie + on the bat...careful!!...have a friend help...
Dec 18, 2013 | 2006 Chevrolet Cobalt LS
Were is pcm at on 2006 cobalt ss
pcm is attached to the front side of battery box under hood, 4 10mm screws and wire connections, make sure the pcm your replacing it with is already programmed with your vin or pats will shut er down,
Aug 02, 2012 | 2006 Chevrolet Cobalt
Getting into a trunk of chevy cobalt w/o keys
09' colbalt dead battery cant get in trunk key stuck in ignition
May 30, 2012 | 2009 Chevrolet Cobalt
Where is the battery in a 2006 cobalt
the battery of your cobalt is located in the trunk of the vehicle. first place i looked was the hood and to my surprise it wasn't so i looked in my owners Manuel and read that it was located in the trunk.
May 06, 2010 | 2006 Chevrolet Cobalt
Problems with 2006 chevy cobalt power steering
There are several bulletins GM has put out about the steering on those cars.
Aug 05, 2009 | 2006 Chevrolet Cobalt
How do i change the car battery for 2006 cobalt?
the battery is located in the trunk under the carpet where the spare tire is located, loosen the 10 mm nuts on the terminals and pull them off, gently pull the vent hose from the battery, loosen the bolt for the battery hold down, usually a 13mm or 15mm, remove battery and reverse the process to install
Jun 12, 2009 | 2006 Chevrolet Cobalt
Battery removal
I think they put the battery in the trunk use a 10mm to unbolt the battery/Please rate my response thank you very much
Jan 27, 2009 | 2006 Chevrolet Cobalt
Power steering
On a cobalt it has electric power steering, the first vehicle I've ever encountered with that.
Jan 26, 2009 | 2006 Chevrolet Cobalt
Battery
Check the trunk...in the spare tire compartment.
Nov 22, 2008 | 2006 Chevrolet Cobalt
06 cobalt stock system hook up
I cant really assist in this matter but I can let you know that I have a system in my 2006 Chevy Cobalt and that I have an aftermarket cd player installed. I had to pay $130 for a special adapter for it to be wired into the system because GM's newest idea of installing the stereo and airbags on the same wire scheme, is kind of a dumb idea.
Jul 02, 2008 | 2006 Chevrolet Cobalt
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
