Question about Drills
I have a 12" Delta drill press - Model DP 300L. The spindle is slipping so that it has hardly any torque. It is not the belt that is slipping, but the spindle. I can hold the tip of the chuck and turn the pulleys without turning the spindle. I tried hammering up from the bottom but that had no effect. How can I fix this?
  • roblstern May 19, 2009
    That answer had nothing to do with the model I have and provided no help. I need advise, not a manual. Can someone please help?
  • 245 Answers
Here is a complete parts break down of your drill press. http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/delta/DP300L_TYPE_1 it looks like this is one of the ones that use a cogged spindle and sleeve to drive the chuck. you have probably stripped one or the other without tearing it down and seeing which part is worn would be guessing as to what is wrong with the spindle. with the parts breakdown of how it goes together it should be fairly simple to get it apart and find the worn part. that website also sells all the parts you will need.
Posted on May 19, 2009
    Novelist:
  • 130 Answers
We have a complete parts assembling and dissembling manual for dela drill press.i will give you the link to this anual.so that you can use it for future requirements too.the manual has all the diagrams and fitting and fixing procedures .it will help you understand each and every part of your machine.here is the link:
http://www.owwm.com/pubs/1141/1708.pdf
thanks and please do not forget to accept the solution.
keep updated.
Does any know much about a Rockwell delta drill press model o-2140-a?
Rockwell Manufacturing Co. - Photo Index ...
vintagemachinery.org/mfgindex/detail.aspx?id=698&tab=4
02/24/2015, Jointer, 6" Short Bed Jointer, Model No. on Motor: JB82B710CW · 6" ...12/30/2014, Drill Press, Delta Rockwell Homecraft Drill Press 11-120 · 11" ...
Aug 27, 2015 | Delta Drills
What size taper is on a delta DP220 drill press so I CAN BUY A 1/2" DRILL CHUCK TO PUT ON IT
If its possible, pop along to a local machine shop and ask nicely if they could help with identifying the Morse Taper, if its a Morse. Go online for what tapers would have been used around that period. Drill chucks are usually 1/2 UNF mount even if its a late metric unit. You would need a Morse to 1/2 UNF or taper to taper if you buy a taper fit chuck.
Dec 29, 2014 | Delta Woodworking Vintage Delta Dp 220 14"...
Will a variable drive pulley setup from a Jet JDP 12 work on my Delta DP 250?
if its a press fit on the motor spindle the parts need to be the same specs ...accurately measure the diameter of the motor spindle.. pulleys are usually machined to match motor spindle ,, if your pulley has a bush it may have been reduced from its bigger size and i may not have enough info so i may be wrong.. pete
Apr 30, 2014 | Drills
Spindle Pulley replacement
I need a pulley a few years ago that I could not find till I found it on ebay.
Apr 10, 2014 | Delta A08513 Spindle Pulley
Delta shopmaster manual
if you want to remove the whole assembly take off the spring and tap out the lowering shaft. once that is done your spindle assembly will drop down,, with a little help.
Oct 07, 2013 | Drills
My spindle slide out of the drill press. I remove spindle to clean , what did I do wrong.?
Please look at this site:
http://www.ebay.com/itm/DELTA-MILWAUKEE-14-Drill-Press-DP-220-Instructions-Parts-Manual-0239-/310388408599
This site has pictures that might help:
http://www.ebay.com/sch/sis.html?_kw=Vintage+Delta+14%22+Drill+Press+DP220+%22Triple+Duty%22+Bench+Model+Tilt+Table
Jan 23, 2013 | Delta Woodworking Vintage Delta Dp 220 14"...
Delta 12" Variable Speed Drill
try cleaning the pulleys buy a good belt (gates) install belt and make sure you have good belt tension
Feb 06, 2011 | Delta Machinery Delta ShopMaster DP350 12"...
I am using a Delta 17-950L drill press that when I use a 2" Forster bit the spindle stops. drill press is new and have cut approximately 100 2" holes. thought that the bit was dull so I purchased a new bit...
This sounds like a belt tension problem. If the motor pulley is still spinning but the spindle pulley is stopped try increasing the tension on the belts.
If both the pulleys slow down or stop together, then try reducing the spindle speed to give it more torque under load.
Dec 13, 2009 | Dewalt Delta 17 950L 16.5" Twinlaser...
Delta model DP 300L I need an intruction manual
Yes it is. Go to Dewaltservicenet.com and in the middle of the page at the bottom it will ask if looking for manuals. type in your model number and it will direct you to a page that you click on user manual for you to view. Let me know if any problems, I just looked at it a minute ago.
Jan 26, 2009 | Dewalt Delta DP300L 12" Twinlaser...
Drills Logo
66 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
