Question about Westminister Time Warp Shelf Clock
Turn off chime - Westminister Time Warp Shelf Clock
I want to turn off the alarm chime on 2016 1500 ram
door chime or headlight reminder chime ??? as im not in the knowing that the headlight chime can be shut off as for the door chime they can be tuned down by simply adding a few pieces of thick tape overtop of chime under dash (I know there loud)
Dec 16, 2016 | Dodge Ram 1500 Cars & Trucks
How do I turn off hourly chime?
Your watch could be defective but at the point where you turn off the hourly chime, check the face for a symbol that disappears.
Dec 18, 2015 | Puma Faas 200 Sport Watch
My sterling and Noble westminster chime clock is not chiming. I have brand new batteries installed but still no chime
A handsome clock in solid red oak. The face is off white with a convex lens and a bright brass-toned bezel. The Westminster chime is pleasant sounding while counting the hours.
Runs on 4 AA batteries; two to manage the clock and two for the chime. The external speaker is located at the top of the clock for a clear, unimpeded sound. A button on the chiming unit allows you to control the striking of the hours.
You will see above that one set of batteries does the chime. Make sure they are good and inserted with correct polarity.
As mentioned, look for a button switch to turn the chimes off It is a feature so you can turn the chimes off when you go to bed.
Sep 14, 2015 | Home
How do I stop the continuous hour chimes on a WESTMINSTER chime mantel clock ?
Is this a older type mantel clock or an electric. A older one has a small arm on the back of the wooden case just move it to it's opposite position and that should stop all chimes. A few times that small switch is on the inside but very rear. If it's electric it also should have a switch to turn off all chimes.
Feb 06, 2015 | Home
Program simon security system chimes
To turn the chime on for your door/window sensor on a Simon 3 panel push the "chime" button on the keypad. Hope that helps!
Oct 27, 2012 | GE Security Simon 3 Wireless Home Security...
The chime of my Howard Miller mantle clock are not w/the actual hour set.How can I reset the chimes? Daylight Savings time has messed me up.
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Nov 06, 2011 | Seiko Mantel Clock
Mantel Clock With Westminster/Whittington Chime: How to set the chime properly...
Pressing the red button advances the chime count by one. Continue to advanced the chime count until it matched the hour shown on the clock face.
May 18, 2010 | Seiko Mantel Clock
2007 HHR Radio and chimes not working
Check the radio fuse. As unusual as it seems, GM has started having the radio (even though not turned on) generate the chimes and turn signal sounds. If the radio fails, all the chimes fail too.
This applies to other vehicles besides the HHR. My 2003 Silverado had the door chimes fade down so I could barely hear them. The fix was to replace the radio (under warranty, fortunately...).
Mar 10, 2010 | 2007 Chevrolet Tahoe
I want to know how to turn on the hourly chime on timex ironman 30 lap watch
I have a Timex Men's Classic Digital Silver-Tone Expansion Band Watch #T78587. To turn the chime on and off on this watch, I press the Start/Stop button on the top right once. This toggles the chime on and off. If you hear a single beep then you have turned it on. If you hear no beep you have turned it off. You can tell the chime setting by looking at the colon seperator between the hours and minutes. If it is flashing then the chime is on and if it is not flashing then the chime is off. This is not explained in my watch manual nor in any of the manuals I downloaded from Timex.com.
Dec 14, 2008 | Timex Ironman 30 Lap 53952 Wrist Watch
Disarm door chime
According to my manual.
>Turn Chime Doors on:
1. System must be disarmed. Press Chime Doors button.
panel will announce,"Chimes On". Chime Doors button will be lit.
> Turn Chime Doors off:
1. Press Chime Doors button.
panel will announce, "Chime off". Chime Doors button no longer lit.
Sep 02, 2008 | GE Security Simon 3 Wireless Home Security...
Westminister Time Warp Shelf Clock Logo
14 people viewed this question
Top Westminister Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Westminister Audio Player and Recorder Expert? Answer questions, earn points and help others
