Question about Electrolux EIED55H Dryer
Electrolux Affinity Dryer model ADE775n2hs0 error 68
2 Suggested Answers
protek480
  • 1723 Answers
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
Posted on Sep 25, 2009
Frigidaire affinity dryer error 68 and hot to touch
Hey friend, thank you for allowing me to assist you!
I understand that you are getting an E68 error code on your Frigidaire Affinity dryer, it usually stands for a key (button) that is stuck closed (active). Let's try entering a "Function Test Mode" and perform the Key Test to determine which button could be the problem. To perform "Function Test Mode": Press and hold START and the CANCEL button at the same time for 10 seconds. The key that is stuck should blink. Free the key and perform the test again. If the button is free but the error code still exists, the electronic control will more than likely need to be replaced after it has been properly diagnosed by a professional. If you need help in contacting a technician you can view the manufacturer website to find available technicians in your area. Hope this is helpful. -Matt
Jul 26, 2014 | Dryers
What do i do when my frigidaire dryer shows error code 68
Good Morning Friend,
I understand that your Frigidaire dryer, model# LEQ2152ES0, is showing a 68 error code. The E68 error code means that there is a possible button that is stuck. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Once power is restored start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 18, 2014 | Electrolux Dryers
Frigidaire affinity error code 68
what is the name and model of these dryer.rate these for clean solution
thanks
Jan 16, 2013 | Dryers
ERROR CODE E64 FOR FRIGIDAIRE AFFINITY
Please CALL Frigidare. We have had the same problem with our dryer and now the washer quit! Our set is only 3 years old! With all of the problems reported on the Internet there should be a recall on this set! They need to be informed! I am highly disappointed in the short lifespan of the Affinity Washer and Dryer. Dont know if I would purchase this brand ever again!
Mar 02, 2012 | Electrolux EIED55H Dryer
Metal on metal sound. we have a frigidaire affinity
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Dec 26, 2010 | Electrolux Frigidaire Affinity AGQ8700FE...
Error e 68 pops up and dryer turns off. Doe sthis
Hi
Thanks for using FixYa. E 68 error means that there is a leakage of current to the ground on heater or fuse opened. Also check the resistance of the NTC which should be around 50K ohms. If not then you need to replace the water inlet valve assembly.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 30, 2009 | Frigidaire Dryers
ERROR CODE 68 ON AFFINITY ATF7000EE
check tech sheet located inside washer cabinet at bottom. remove lower kick panel to access.
May 04, 2008 | Frigidaire Affinity ATF7000E Front Load...
Electrolux EIED55H Dryer Logo
51 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
vince
JP Services
JP Services
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
