Question about Garden
No pressure at all
No pressure from unit even when motor is on all repair sites are engine only. one person said it is a throw away unit. 020238 model help please thanks mancf@sbcglobal.net thanks mike this is a briggs and stratton speed clean sorry my first time on this sit
  • 104 Answers
It will be one of the seals in the diaphragm pump unit , good luck getting parts and if someone will fix it for you it probably will cost more than the unit itself
Posted on May 23, 2009
On 2003 Toyota camry 4cyl where oil could leak from on drivers side rear upper pt of motor after an overheating and shut off on its own
ANY oil seal could be leaking from this severe and overheat that the engine shut off. Clean the engine of all oil and then try and locate the leak.
Jan 05, 2017 | Toyota Cars & Trucks
Karch k591. it stops and starts on full pressure - is worth repairing?
not really. It sounds like either a motor or unloader problem I work on washers full time and in my honest opinion these electric washers and a ripoff. You cant work on them as they dont even use industry standard parts. I would invest in a gas engine washer for small homeowner needs. If you must use an electric one, stay away from the ones at Walmart/homedepot etc. check out pressurepro com They can give you better options. Good luck
Feb 23, 2015 | Karcher Garden
Water pump runs constantly but no water pressure or water comes out of hose.
Lots of possibilities. Inlet filter might be clogged. I once had a lizard crawl into a water feed line, totally blocked the feed. Check valves might be stuck closed. Discharge hose might be plugged. Pump might be trashed ( if it is a vertical engine it is probably a throw away pump) Nozzle might be plugged.
Disconnect the hose at the discharge and turn on the water supply. It should have a stream of water even without the motor running. That will check the inlet filter, feed pipe and check valves.
Oct 07, 2014 | Garden
My hec washing machine just stopped working seemingly mid cycle,still full of water.the red error lights were flashing seven times and in the manual it says the motor has over heated,its not under...
It's probably cheaper to throw away than to repair. This is a throw away society now you know. If you can buy a new motor and replace the old one good luck but the last one I had apart it was a throw away motor that would not come out of the machine.
Mar 01, 2018 | Washing Machines
On my kobalt digital air compressor i have 150
This was a poor design for kobalt with digital readouts.. The compressor waqs made by several comanies including campbell hausfield and porter cable, But some were imported.
There under the controls is a switch that cuts out the motor, It looks like an oil pressure switch on older cars. There is also a manifold tree that holds the guages and the regulator. There will also be a circuit board that holds the electronics for the regulator control.
Remember you have to set a value to bring up the pressure and the board senses the tank pressure and "Bleeds" off via a solenoid to hold the pressure. The ticking sound you hear is the solenoid, ITs not repair/replacable.. its part of the controls.
If the unit is under warranty you might eant to ask lowes who is their off site repair center, or ask is it available to be exchanged.
Personally, and professionally.. this model is oiless, so it has a shorter life as to being reliable compared to oil lubrication. For the extra bucks you will come out with a more reliable and easier to service model.
Nov 18, 2009 | Air Tools & Compressors
I have a Sunbeam Mixmaster Model 2366. The motor
Still have it? If yes, please e-mail me at rgr04@yahoo.com
Jul 12, 2009 | Sunbeam Food Mixers
Garden Logo
200 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
