Question about Saddlemen Heated Explorer Seat With Backrest For Harley Davidson Road King FLHR 1997-2007 / FLHRC 2007 / FLHRC I 1998-2006 / FLHR I 1996-2006 / FLHX 2006-2007 - 897-06-030H
Engine idles up while riding and check engine light comes on. When I let out the clutch and put a load on it, the light will go out and the idle will bog down while putting a load on the engine.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Would really help if we actually knew what kind of vehicle it was, did you add anything onto it or make modifications ???
because i dont think a heated seat with backrest is the problem UNLESS you wired it up yourself
Posted on Dec 29, 2013
Honda unicorn drive chain is jumping with extreme knocking sound.
Try checking the gearbox oil level and adjust the chain.
Apr 03, 2017 | 2005 Honda Unicorn
How do I put the drive belt back on my yard man automatic riding lawn mower?
The v side of the belt goes in the v of the pullies and the flat side of the belt rides on the flat pullies. It looks like the flat idle pully is bent out of alinement. The one showing in video with no belt on it that is the last pully the belt runs on before returning to engine. The belt comes from the engine to a spring loaded flat pully, to v pully on right of mower ,to v pully on left, to flat idle pully // that looks to be bent // then back to engine. Put belt on all pullies saving the spring loaded pully for last.
Apr 09, 2013 | Garden
07 harley xl1200c. go for a cruise at steady rpm. highway speed. start to slow down and the idle stays high. if i pull in the clutch it really revs up. downshift and it can actually ride me along at like...
Hi Fareseedjr, high idle on fuel injected models can be casued by a faulty IAC valve located on the top front of the induction module. It has either failed electronically and needs to be replaced or mechanically getting gummed by contaminated engine blow by. You can try cleaning the unit by removing the air cleaner and backing plate, unplug, unscrew and remove the IAC. Using carb cleaner and " LOW " volume compressed air to clean the metal pintle and shaft that is spring loaded and has an operating length of just under 1 inch. Aventurous souls who did not heed the low air warning have launched pintle and spring into parts unknown. There is no guarantee this will work but worth a try since a new one is $50 Good luck
Sep 15, 2011 | Harley Davidson XL 1200 C Sportster Custom...
After a 2 hour ride out yesterday in daylight,i always turn my lights on to be seen when returned home switched engine off opened garage went to start bike again and completely dead has a data tool duo...
Might have 12.67 volts, but not enough amps to crank engine or light the lights properly. Try putting a charger on the battery, bring it to a full charge. Next, put a load tester on the battery to see if battery is weak or dead cell. If battery checks good, check the charging system. With engine running at idle, put volt meter on battery-read volts, then rev engine to high idle. Volts should climb higher than idle reading.
Apr 18, 2011 | Yamaha YZF Thunder ace 1000 R Motorcycles
'02 Yamaha XJR1300 Rattle/vibrating noise from bottom of engine
how do you adjust the headlight beam on a xjr1300 naked 2002 bike, is it as simple as undoing the 2 bracket bolts at the sides of the lights and re-setting the lights to a new level ??
currently it seems to be set for riding with a pillion passanger or heavy load at the rear as the lights are set low, no one flashes me even if i ride at night with full beam on !
thanks xjr cambs
Apr 18, 2010 | 2002 Yamaha XJR 1300
With my 2004 Ford 6.0 liter when pulling a hill with a load it seems like the turbo boost is not as strong after pulling for a while and the power is less. If I pull over and let it sit idling for a few it...
sound like engine getting hot when you pull a heavy load going up hills. when putting load on a engine it will over heat and will lose power because it inhales less air by volume.make sure your air filter is not clogged.a diesel engine needs a good air flow or breathe the air filter need to clean.also a restricted exhaust.if you have a restricted air filter and exhaust system the turbo not going to work good.also check coolant fan clutch.if you turn it by hand and it free wheel fan clutch needs to be replaced.if cooling fan clutch has resistance then its good.a bad coolant fan clutch will cause engine to over heat.
Nov 23, 2009 | 2004 Ford F250
2005 honda crf450 cant get the idle right & is
Bigger jetting (a higher fuel/air ratio) will not cause overheating. But an air leak between the engine and carburetor can cause overheating - and an erratic idle. Make sure the carb is correctly connected and there are no air leaks. An air leak could also be the cause of the popping that you were attempting to address by re-jetting.
Once any air leaks are corrected, adjust the idle mixture screw to attain the highest idle speed when the engine is at normal operating temperature. Then, use the idle speed screw to set the correct idle speed.
Finally, ride the bike at full throttle for a short time, pull the clutch and coast to a stop. Remove the spark plug and check the color; a tan or light brown color indicates correct jetting. Too light = too lean. Too dark = too rich.
Nov 01, 2009 | 2005 Honda CRF 450 R
Crankshaft pulley slows down when a/c engaged.
It is the harmonic balancer, ie. pulley. It is a two piece--with rubber between the two. It will, especially if belt dressing or other lubricant has penetrated it, slip. I just ordered a new one online for $70. It is a fairly common problem.
Aug 30, 2009 | 1995 Isuzu Rodeo
1993 Toyota Paseo - Engine dies when clutch depressed
Absolutly, Your idle control valve at the end of your fuel rail has a vacuum line and its sensitive to pressure changes. One way to double check that would be to hook everything up normally and pull that vacuum line off your idle control valve. Are the symptoms the same?
Jun 04, 2009 | 1993 Toyota Paseo
Saddlemen Heated Explorer Seat With Backrest For Harley Davidson Road King FLHR 1997-2007 / FLHRC 2007 / FLHRC I 1998-2006 / FLHR I 1996-2006 / FLHX 2006-2007 - 897-06-030H Logo
Top Saddlemen Cycling Experts
John Egan
John Egan
Are you a Saddlemen Cycling Expert? Answer questions, earn points and help others
