Question about PfaFF Sewing Machines
Bobbin case inserting wrong
I am trying to insert the bobbin case into the bobbin housing. The housing (metal hardware that the bobbin case sits in) was not moving that I recall when I started sewing tonight. I threaded a bobbin and went to insert the bobbin case. The bobbin case would not insert with the large opening facing up. The hardware that holds the bobbin case can now turn left or right, but will not turn up enough to allow the bobbin case to be inserted and sit at the correct angle. I just bought this machine and today is the first time using it. Any idea what is wrong?
  • 1,263 Answers
Hi, Can i ask what model Pfaff it is ?
Regards
Rob
www.electronicrepairs.co
Posted on Dec 29, 2013
  • Daniel
    Daniel Dec 30, 2013
    It is a Select 4.2
  • Robin Hill
    Robin Hill Dec 30, 2013
    Ignore the cleaning Advice, can you show me where it come loose ?
  • 66 Answers
SOURCE: how to thread bobbin, insert in machine correctly. Lost manual.
go to link: http://www.youtube.com/watch?v=YL433PhG05c
a vidio is here that will show you the route to follow for your automatic threading to work. You may need to watch it a few times as it is demonstrated very quickly near the begining only once.
Posted on Jan 18, 2009
Mongo32
  • 111 Answers
SOURCE: inserting bobbin
needle's in backwards
Posted on Jun 01, 2009
  • 96 Answers
SOURCE: My Kenmore 12912 sewing machine doesn't sew right.
Are you sure you have the proper bobbin for the machine I have purchased spare bobbins before and they sometimes dont work for all machines
Posted on Dec 13, 2009
Testimonial: "I think I'm using the bobbins that came with the machine, but I'll check this out. Thx. "
  • 980 Answers
SOURCE: I have a singer modle 3820, recently thread got
You need to look in the bottom of the machine under the raceway to makie sure you do not have a broken gear at the very worst,
Posted on Jul 14, 2010
  • 6 Answers
SOURCE: After placing the bobbin in
Tension for the bobbin thread may be wrong. Adjust the tension for the bobbin thread, not the top thread.
Posted on Feb 06, 2011
I just recieved an older kenmore 24 stitch sewing machine and it has no manual with it , my problem is why wont the machine pick up the bobbin thread ?
You can probably find a manual from Sears. They carry a ton of Kenmore user manuals.
First thing to always try--insert a brand new needle!
Bobbins do usually have a specific way of being loaded. Most machines require the bobbin to be inserted into the bobbin case so when you pull on the thread tail, the bobbin turns clockwise (this is when you are looking at the backside of the bobbin case - at the bobbin). Also, be sure to thread the bobbin thread through the bobbin tension mechanism.
Tip how to put bobbin into the bobbin driver on sewing machine
If the upper thread is not picking up the bobbin thread, it is usually because there is a timing issue (means the needle is arriving at the bobbin at the wrong time to connect with the bobbin thread).
Sewing machine won pick up bobbin thread hook timing fix
P.S.--if your Kenmore is non-computerized (ie, mechanical) be sure to oil using fresh, good quality sewing machine oil or Tri-Flow Synthetic Oil (NOT cooking oil, 3-in-1, WD-40, or old stinky brown stuff that may be in the accessory box). Apply a couple of drops every place metal rubs on metal (while hand-rotating the handwheel). Do NOT oil nylon, rubber, or belts!
Jul 11, 2016 | Kenmore Sewing Machines
Keep the thread from collecting on the arm that holds the bobbin case in? My Brother LB-6800 sews quilts, and embroiders great until yesterday, The thread wraps around this small arm every time now.
Try taking the bobbin case out and re-insert. It sounds like the case that holds the bobbin is not inserted correctly. You might also try checking to be sure that the needle is inserted properly. Sometimes the needle gets loose and drops down too low. unscrew, push the needle up as far as it will go, then tighten the screw.
Jan 24, 2015 | Brother LB-6800PRW Project Runway Limited...
How to thread a bobbin
Hold the bobbin case in your left hand, with your right hand, insert the bobbin with the thread unwinding from the right. Pull the thread through the small slot in the top of the bobbin case, then hold the bobbin tight and pull the thread under the bobbin case tension spring ( a flat piece of metal). When you pull the thread out, there should be some tension on the thread and the bobbin should unwind counter clockwise. If there is no tension on the thread, it's not under the tension spring on the case. If the bobbin turns the wrong way, remove it and turn it around, and put it back in.
Oct 30, 2014 | Sewing Machines
I suspect the "housing" you refer to is not seated completely. Be sure to wiggle it until it slips into place. Once it is seated, the bobbin case should seat firmly as well.
May 02, 2017 | PfaFF Sewing Machines
I have a hyundai 8 stitch sewign machine been working brillant but last night it kept missing the tread and the thread breaking or jabbing . today looking at it i see when it jabs the Bobbin Case Inner...
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
if the sewing machine has a top loading bobbin, you may have to have the sewing machine checked to see if there is something wrong with the bobbin case or the hook and hook race.
I suggest try a new needle--one for the fabric being sewed
also try another bobbin
rethread the sewing machine top and bobbin, using every thread guide.
Aug 21, 2013 | Sewing Machines
The bobbin thread keeps breaking
Jan 21, 2013 | Brother Sewing Machines
How do i fix my sewing machine underthread keeps breaking
Nov 04, 2012 | Sewing Machines
Kenmore bobbin issues
try these suggestions
Oct 25, 2012 | Kenmore Sewing Machines
Plastic casing around the bobbin
That piece is a sweep that helps keep the hook clean. It is not necessary for the machine to use, I have thrown away many of them. If you can get your hook put back in you should be ready to go.
good luck!
Jan 30, 2009 | Necchi 3101 Mechanical Sewing Machine
My Bernina 930's lower tension is off. When I sew the stitches are tight on top, but loose on the bottom. How can I fix this? I've tried messing with the tension and have cleaned the bottom.
Hi - you might have a dirty bobbin case, or need a new one. IAfter awhile, little teeny dust bunnies can collect in your bobbin case and cause your bobbin tension to go wonky, especially if you use cotton thread. If you happen to have an extra bobbin case, try using the new bobbin case to see if that solves the problem. Otherwise.....
  • Remove your bobbin case and take out the bobbin. Find a small, stiff brush like the one that came with your machine and stand in very good light. Brush out the inside of your bobbin case, and push one or two bristles of your brush into any opening you can see. If you see any trace of dust but you can't get it out, use tweezers to gently pull the dust out. Now look at the outside of your bobbin case. In the small opening where you insert your bobbin thread into the bobbin case, there is a small piece of metal with screws in it the lays over the bobbin case. Brush that area carefully, and again, insert one or two bristles under than piece of metal and into any other small opening where the bristles will fit. Try sewing again. If you are still getting loops, take out your bobbin case with the bobbin thread still inserted and grab the bobbin thread with two fingers. Let go of the bobbin case - sort of like you are holding a yo-yo. If the bobbin case starts to drop as soon as you let go, your bobbin tension is loose. If the the case doesn't move, gently snap the bobbin thread you are holding and see how far the bobbin case moves down toward the floor (you might need to try this a couple of times, the bobbin has a nasty habit of flying out). When you do the snap, the bobbin case should move down about two inches and stop. If do not know how to adjust the bobbin tension, either check your manual or take the machine in for service.
  • If you haven't already, it's a good idea to remove the thread plate that sits under the needle and clean that area out with your brush. Also, get a really good flashlight and check the area where you insert your bobbin case. Gently turn your fly wheel and look inside the hook area - remove any dust or bits of thread.
In general, you should oil your machine as indicated in your manual as often as directed. You should change your needle every 10 hours of sewing - or each time you start a new project, and you should take your machine in for service every one or two years - even if you only use it once and awhile.
Hope this helps, Ginny
Dec 06, 2008 | Kenmore 19365 Computerized Sewing Machine
Sewing Machines Logo
237 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
