Question about Apple iPad 32 GB WiFi Tablet PC
Ipad only charging to 30% overnight
Put on charger 7:30pm last night and when look at 5:am next day it was only 30% charged
    New Friend:
  • 14 Answers
Might be a faulty charging cable I'd suggest buying a new one , also never let the battery run completely dead plug it in before it goes off .
Posted on Dec 30, 2013
5 Suggested Answers
SOURCE: charge the ipad in Car
The ipad need high power usb port.
The normal iphone/ipod adapters will not work.
buy an dc/ac outlet and a second charging brick from apple!
Posted on Apr 12, 2010
  • 846 Answers
SOURCE: Apple Ipad won't charge
IThe iPad needs more power than the average USB device. It doesn't run and charge at the same time on a regular USB port. If it doesn't charge with the original charger though, you have a hardware issue. You can always take it to the apple store and demonstrate the problem there, you'll probably receive a replacement. If you have issues with the warranty, there are third party places that will find our what's wrong. If you want to do it yourself, the good news is, it's not too hard to open it. Here is an iPad Repair Guide that shows how to open an iPad. If you want somebody else to do it for you go to iPad Repair NYC.
Posted on Apr 26, 2010
  • 104 Answers
SOURCE: i got a ipad for
Most chances are the problem is the cable. You can try connecting the ipad to the pc, if you can connect then the problem is not the cable, but the charger.
You could try to use another cable from a friend with an ipad/ipod/iphone, just to be 100% sure.
Also try moving the cable around, the cable may be interrupted, it happened the same for me with my iphone.
Regards,
katharsys_i
Posted on Mar 03, 2011
charles0285
  • 160 Answers
SOURCE: Can't charge the ipad from the USB charger
To get Ipad to show as charging download Asus AiCharger from web and restart computer after install.Plug in usb from Ipad and should now show charging http://event.asus.com/mb/2010/ai_charger/
Please Rate
Posted on Nov 02, 2012
My kindle fire loses it's entire charge overnight when turned off. It occasionally makes a beep
Amazon.com: Customer Discussions: battery life on kindle fire hd
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Nov 12, 2012 - My son bought himself a kindle fire hd over the summer and we are having some issues with ... and unused yesterday from a full charge and it was < 5% (red battery) last night. ... a paperwhite kindle as its much lighter and I'm fed up losinghours to addictive .... ETA I tried again last night to power off and charge overnight. Kindle Fire HDX 8.9 battery ...
Dec 3, 2013
Kindle Fire HD won't charge?!
Apr 10, 2013
Kindle - Losing charge when ...
Oct 9, 2012
Kindle Fire HD Battery tips
Sep 17, 2012
More results from www.amazon.com
Dec 09, 2015 | Tablets & eReaders
My apple ipad is not reponding when iam charging it how do i reset it
If you charge your iPad on a power adapter, the iPad should respond while charging, except if your iPad battery is so low the apps need more power to run.
If you charge your iPad on the USB port of your computer, it is normal you cannot use your apps as the iPad is not only in battery charging mode but also in synchronizing mode with iTunes in the computer. You should lose the habit to charge the iPad on the PC and use a dedicated power adapter instead, as dedicated power adapters charge the iPad battery 2 to 4 times faster than the USB port of most computers.
USB port power: 2.5 Watts in general (5 volt x 0.5 A = 2.5 Watts)
iPhone charger: 5 watts
iPad charger: 10 or 12 watts
Jul 26, 2014 | Apple iPad 32 GB WiFi Tablet PC
MY i pad will not charge
As soon as you connect your iPad to a working charger, it will beep. If you plug in the cable and you don't hear the beep, assume something is wrong. Just find out what, the cable or the charger.
Don't try to charge the iPad with a computer, because the 500 mA a USB connector from a computer can give, is not enough even to start.
But you can use a computer to test the cable, because the iPad should beep and say on the screen not charging.
If there is no beep when connecting to a computer, you have to use another cable. If it beeps, buy a new charger. 5 Volt 2 A. The best an Apple charger.
Jul 17, 2014 | Apple iPad2 WiFi 64GB
Ipad will not start?!
There are a few things to try. 1) Press the power button and the home button (on the front) at the same time. If that doesn't work 2) try plugging it into a different charger than you normally use. If that works, you need a new charger. If it doesn't show that it's charging within 30 seconds, your iPad charging port or battery probably has a problem and will need repaired.
Jun 25, 2014 | Apple iPad 32 GB WiFi Tablet PC
Why will my ipad not charge and what do I need to do?
try resetting it, power it off completely. If still not working check charger on another device to make sure charger is OK. If it is you will need to have it repaired, new battery or charging circuit or new socket
May 21, 2014 | Tablets & eReaders
My ipad is not charging at all has been completely dead & when i plug it in has a plug picture what can i do?
Are you using the 5 volt 2.1 amp charger. The ipad won't charge with out this charger.
Mar 27, 2014 | Apple iPad 64 GB 3G Tablet PC
My coby MID7012 isn't going to the home screen after I charged it. Its flashing coby over and over. But its not turning on. What do I do?
Sounds like you are in a "Boot Loop". Let's try to break the Boot Loop. Plug the device into the charger, then press and hold the power button for 60 seconds - make sure the device is OFF after the 60 seconds. Let change overnight. Next Day, unplug the device from the charger, then press and hold the power button for 30 seconds, wait 30 seconds, press and release the power button normally, the device should be out of the Bootloop.
Jun 12, 2013 | Dell Android 2.3 Touchscreen 7" Internet...
My iPad 3 battery is charging slowly how do I speed it up?
Make sure you are using an authentic charger if that doesn't help update your ipsw to the latest firmware
Apr 18, 2012 | Apple iPad HD
How do I make the new iPad's battery recharge faster?
There are many things you might be doing wrong but slow battery charge is a problem with the new iPad. The battery is actually a lot bigger than the iPad 2 which means it is going to take you much longer to charge.
Use the provided charger and don't charge from your computer. It is almost twice as slow to do it plugged into a computer. Charge it at night to give it the most time to charge as possible. I usually turn it off so programs don't run and slow down the charging speed. Every little bit helps.
I can help you with other things too if you ask.
Mar 27, 2012 | Apple iPad HD
Ipad won't turn on
Hold the on switch and menu button together for a hard reset. If you can reset it, there may be an issue with your motherboard. If apple doesn't replace it for you, You can get the board at iPad Repair and there is a guide that shows you how to put in the part at Electronics Repair Guide.
Feb 11, 2010 | Apple iPad (16 GB) WiFi Tablet PC
Apple iPad 32 GB WiFi Tablet PC Logo
89 people viewed this question
Top Apple Tablets & eReaders Experts
Virgil Wolter
Level 1 Expert
Aaron Galvan
Level 1 Expert
John mullen
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
