Question about Durabrand Portable DVD
I need replacement cords for my monitors - Durabrand Portable DVD
Go to tandy and buy the replacement cord and go to web page do it yoursef electronics. and type in diy monitor repair.
Posted on May 19, 2009
How can I replace the power cord?
most of them just unplugged see if that part is still there . replacement cords are cheap
Mar 27, 2016 | Computers & Internet
I NEED APOWER CORD FOR DAEWOO L950
I can't find information online about your monitor, so I'll give you a generic answer for all monitors.
Almost all monitors use a C13 cord - the same kind used for a desktop computer. Some use a C7 (two-wire, like that used for some name brand laptop adapters) or a C5 (three-wire, used on other laptop adapters)
C13 image:
C7 image: ac15wna-r.jpg
C5 image:
These images were lifted from the Mouser Electronics website (AC Power Cords Mouser ). They also carry C13 cords with right-angled plugs, which may be more convenient with some monitors.
There are a very few monitors that use an external power supply, which is like a laptop computer power adapter. If this is the case, the voltage and current requirements for the power supply should be on the label on the back of the monitor, and the only other thing you have match is the plug on the power adapter output cord (it needs to fit the power jack on the back of the monitor). Note: the voltage of the power supply must be the same as that shown on the label (usually 12 VDC) and the current rating must be the same or higher. If you don't see the voltage and current listed on the label, look closely at the power jack - the numbers may be molded into the plastic next to it.
It is rare to find a monitor with a permanently attached power cord. If this is the case with yours and it is damaged, do not attempt to splice it outside of the monitor. Put a replacement plug on if the good part of the cord is long enough, and use a good extension cord. Otherwise, you should open up the case and replace the entire cord. You will probably have to get a connector for the part of the power cord inside the monitor also. (If you are good with soldering, you may be able to splice to this connector, using heat-shrink tubing to insulate the connections.)
May 08, 2014 | Daewoo Computers & Internet
Not working
it could be possible that the pwr cord might have gone bad. change it .
before doing that try disconnecting the pwr cord from the back of monitor and hold the pwr button for 30 sec. connect the pwr cord properly and then restart the comp. if this does not work then check with other pwr outlet. if this doesnot work then replace the monitor its a problem with the monitor and needs to be replaced// nothing is wrong with the computer//
May 07, 2010 | Fuji FP-988D 19" Flat Panel LCD Monitor
Dell w3206c no turn on
Biker,
The power cord is probably loose.
check the cord where it connects to the monitor and push it in to re-seat it.
Nov 11, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Replacement AC/DC cord to power up my 1730B comp monitor
You cannot use a VGA cord to power a monitor. That is the cord that connects the monitor to the computer and is not the power cord. Almost all monitors use the exact same 3 prong power cord. Any computer shop will have a used one on hand.
Sep 06, 2009 | Solarism LM-1730 (Black) 17 in. Flat Panel...
I need a replacement power cord
Found one here:
http://acebargains.stores.yahoo.net/acpoadforwel.html
and ebay looks to have a few as well:
http://cgi.ebay.com/AC-power-adapter-Westinghouse-LCM-17V2-sl--LCD-monitor_W0QQitemZ360118562836QQcmdZViewItem
Hope this helps. You are right this far from a typical power supply cord. Most just need to the cord with a 3 hole female end that plugs straight in the monitor.
Mar 02, 2009 | Westinghouse Computers & Internet
Monitor Cord
there is interference effecting the cabling. you will need to replace the cable. if you can not replace it you will need to get a new monitor
May 23, 2008 | Xerox XG-91D 19" LCD Monitor
I need a new power cord
you can go to any monitor repair shop & get it.
just tell model no. or take the sample which is defective.
good luck.
Oct 11, 2007 | Kogi L9CH 19" Flat Panel LCD Monitor
Durabrand Portable DVD Logo
59 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
