Question about Photography
Pictures are blurry
Pictures look like the camera was moving. Pictures are blurry.
Some pictures- only the middle of the picture is blurry.
I am hoping its something minor. If not I will have to take it in
I am using a faster speed film since its sports pictures. Any suggestions
Renae
Canon EOS 650
    Problem Solver:
  • 18 Answers
Maybe you have the camera set to a slow shutter speed. Try putting it on Program mode.
Posted on Apr 13, 2009
SOURCE:
Pictures come out blurry if any movement
The most likely culprit is a slow shutter speed. If the subject moves while the picture is being taken, you'll see it blur. If non-moving objects show up sharp while the moving objects are blurred, then this is definitely it.
Another possibility is camera movement. Try putting the camera on a tripod or a table or other steady support, then use the self-timer to take a picture. If everything in the picture is blurry, then this is probably the reason.
The third possibility is that the camera isn't focused on the subject. Try taking a picture of the subject when it isn't moving and see what happens.
Mar 16, 2013 | Olympus Sz-12 14mp Wide-angle With 24x...
Some of my pictures are blurry using a cannon rebel 3. how can i fix this problem?
There are several possible causes for blurry pictures.
1) Camera motion. If everything is blurry, it's most likely because the camera moved while the picture was being taken. Make sure your shutter speed is fast enough if you're handholding the camera (longer lenses require faster shutter speed). Alternatively, put your camera on a stable surface, such as a tripod or a tabletop.
2) Subject motion. If the subject is blurry but the background is sharper, then the subject may have moved while the picture was being taken. Use a faster shutter speed. Raise the ISO if needed. There are limits, of course. If you're trying to photograph a fast-moving object in the dark, you probably won't be able to.
3) Improper focus. If the subject is blurry but something else in the picture is sharp, then the camera probably focused on the wrong object. Move the focus selector to the subject you want in focus. Alternatively, center the viewfinder on the subject, press the shutter button halfway to lock focus, then reframe and shoot.
Without any more specific information as to what and how your pictures are blurry, I'm afraid the above is all I can give you.
Jan 13, 2012 | Canon Cameras
My olympus FE-240 takes blurry pictures in night mode.
It's you...in night mode the shutter stays open much longer...plenty of time for you to move the camera. Use a tripod.
Dec 17, 2009 | Olympus Stylus 700 / 700 Digital Camera
Sony cyber-shot dsc-w200 taking blurry pictures in auto mode...
Its due to slow shutter speed setting.
If you want to take moving object picture, set high speed shutter, there would an icon of golf stick that is for moving object pictures.
Mar 23, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
My camera takes blurry pictures
I would try placing the camera on the table (very solid surface that doesn't move) then activating the self timer to take a picture. this will make sure you eliminate the chance that it's you and not the camera. if it still comes out blurry and you haven't inadvertantly switched it to manual focus, if the little thing has such a feature, you got a busted camera.
Feb 04, 2009 | Sony Cyber-shot DSC-T10 Digital Camera
Blurry bright pictures
1.go to menu go to quality and put in fine. make sure also that your flash is on during the night and your not moving the camera around while your taking pictures.
Oct 12, 2008 | Samsung Digimax D53 Digital Camera
Pictures ive taken on my refurbished sd850 are blurry
it might be because your camera moved while you were taking pictures or try cleaning the lens...
Aug 03, 2008 | Canon Cameras
Fuzzy pictures
The blurry pictures are due to movement. Sometimes adjusting the flash helps.
Mar 19, 2008 | Samsung Digimax S630 Digital Camera
WHEN TAKING PICTURES OF MOVING OBJECTS THE IMAGES ARE VERY BLURRY, ALSO SOMETIMES WHEN WE TAKE A PICTURE THE WHOLE PIC IS BLACK ANY HELP?
WHEN TAKING MOVING PICTURES YOU SHOULD BE ON THE RIGHT SCENE MODE. AS FOR BLANK PICTURES WE HAVE FOUND THAT GENERIC SD CARDS CAN CAUSE THIS.
Nov 23, 2007 | Panasonic Lumix DMC-FZ50K Digital Camera
Photography Logo
1,287 people viewed this question
Top Photography Experts
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Photography Expert? Answer questions, earn points and help others
