Question about Norelco Health & Beauty
Philips norelco PT 720
Won't charge anymore, light flashes
3 Suggested Answers
freetek
  • 5568 Answers
SOURCE: Norelco shaver 6866XL won't charge, light glowsred
The battery is probably one with multiple cells and one (or more) of them has shorted preventing the total from reaching a voltage that appears as fully charged.
If the cells are Ni-Cads, this is a common problem with them and when a battery-operated item of mine fails, I replace those older types with NiMH cells if the battery compartment can accept them.
I have 'restored' countless NiCads over the years by 'zapping' them with a fairly high current for a second or two; voltage isn't important as long as it is in excess of 2-3 volts but the source should have a few amps capacity.
This type of cell grows 'whiskers' that will cause them to short completely or develop a path that causes them to self-discharge faster than normal.
Posted on Oct 16, 2009
  • 9 Answers
SOURCE: Norelco/Philips jet clean shaver cleaning bath no longer works
I have had three 1050CC shavers all with the same problem. Apparently other models have the same issue. After about a year of use, the unit reverses after dipping the shaver into the cleaning solution for a second. Two were replaced by Philips within the 2 year warranty period. I still use the 3rd one. There are several things you can try. If the cleaning solution is low this will cause the shaver to reverse and not clean. Add more cleaning solution. I have noticed that sometimes I have to add more fluid to the unit after a week of use. Sometimes it is necessary to fill the solution a little above the max fill line. Be careful though. Filling it too much above the max fill line can cause cleaning fluid to run out of the bottom after a cleaning cycle. If the above two fixes don't work, then press the clean button and after the unit reverses back up, wait about 5 or 10 minutes and press it again and it should stay down as long as there is enough cleaning solution in the unit. If you wait too long or too little to press the button, it won't work. I have noticed if I press the button immediately after it reverses the same problem occurs. Also if I wait 30 minutes before pressing the button the same problem occurs. There must be some sort of timing cycle. You may have to repeat this process a few times to get it to stay down and clean. This is the only way I can get mine to clean now. Obviously something is getting dirty or wearing out over time in the cleaning system. Since I have had 3 shavers with the same problem, I know many others have had it too. Philips must be aware of the problem. It is frustrating that they don't offer help on their own website and consumers have to band together to solve problems that they should be solving. The two year guarantee is very generous, but there is a design flaw with this product.
Posted on Jan 23, 2011
Norelco 900rx schematic
Contact Norelco directly to request the wiring diagram.
Apr 06, 2018 | Norelco Health & Beauty
HQ8 or HQ6? What is the correct head replacement?
These Philips Norelco Replacement Shaving Heads HQ8/52 are compatible with the following series: 7100 series, 7200 series, 7300 series, 7700 series, 7800 series, 8800 series, PT/AT700 series and PT/AT800 series. They are sturdy and durable and provide for a smooth finish. The Norelco razor heads keep your shaves close and comfortable and are easy to replace.
Norelco HQ6The Norelco HQ6 is men's replacement heads. The Norelco HQ6 is made up of stainless steel and contains 3 cutters. The Norelco HQ6 works with all Quadra Action razors. HQ6 Features:Replacement Heads Stainless Steel 3 Cutters / Combs
Norelco HQ6
Oct 14, 2015 | Head Health & Beauty
To charge
Men\'s Grooming / Norelco
1-800-243-3050
Monday - Saturday 9:00 AM - 9:00 PM EST
Sunday 9:00 AM - 6:00 PM EST
Excluding Major Holidays
good luck
Apr 19, 2014 | Philips arcitec 1060 Electric Shaver
I lost the silver cover that goes over the on/off switch and LED charge indicator light. Can I replace this? Philips 6615X Electric Razo.
This item can be purchased at shaveroutlet.com from the link below
http://shaveroutlet.com/shaver-replacement-parts/other-parts/philips-norelco/norelco-philips-reflex-plus-protective-cap-p-324.html
Sep 14, 2013 | Norelco 6615 X Electric Shaver
I have a Norelco arcitec 1050 electric razor and I have lost my instructions. What does it mean when the red light starts flashing (picture of razor heads)?
Means that the the replacement heads indicator flashing, it's time to replace new heads. That Norelco RQ10 heads for Norelco arcitec 1050 electric razorreplacement parts.
Aug 15, 2011 | Health & Beauty
Red light at bottom flashes even when razor ids fully charged. What can causrethis?
When the battery is almost empty (when there are only 5 or fewer shaving minutes left), the battery symbol lights up red.
Make sure that the battery does not have a memory effect. What I suggest is taking the shaving head unit off and running the shaver till empty, then recharging. Check if the red light is still flashing.
There's also a head indicator at the bottom of some shavers.
To remind you to replace the shaving unit, the shaving unit symbol flashes (all types) and you hear a beep when you switch off the shaver (RQ1090 only). This happens at the end of 7 successive shaves to remind you to replace the shaving unit.
Without knowing what model you have it's difficult to diagnose further.
May 23, 2010 | Norelco Arcitec Electric Shaver -...
Health & Beauty Logo
29 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
