Infocus lp120 computer no signal - Office Equipment & Supplies
  • 4234 Answers
SOURCE: Infocus LP120 Retrying-Power Light Turns Red...
Usually when the lamp is good and you get this message, the ballast is bad. That is the part thatdrives the lamp. Check with Infocus for a repalacement balast.
Dan
Posted on Apr 09, 2008
wellss123
  • 4 Answers
SOURCE: Fan stopped
Its internal circuitry might be telling it to not run--a remnant request during the last cool down. Hopefully it is the fan itself. Try the master reset command. If you do not get an image before its shuts off, look in your owner's manual, count the way you manipulate the menu buttons to get to the reset, and try it between the moment you first turn it on, and it shuts off. Unfortunately some units will not let you input commands untill it is 'up to speed'. My Eiki is like this--nothing untill it is fully bright. Depending on your 'exploration' desire, short of going to a repair place, or buying a new one, you might try seeing if your unit is dirty, see if you have power to the fan (voltage meter--maybe 5-7 volts), or something is jammed in there. Depending on its age, the fan just might be dead, Jon.
Posted on Feb 24, 2009
  • 74 Answers
SOURCE: my LP120 says that no computer signal detected
check your cable, and make sure your source is good. if everything checks out then you main board is defective.
Posted on Aug 15, 2009
projdoc
  • 2237 Answers
SOURCE: InFocus LP120 Projector shuts off automatically
overheating or power supply problem.
Posted on Sep 03, 2009
projdoc
  • 2237 Answers
SOURCE: LP120 : fan stopped error
you can purchase and replace the blower assembly- part # 505-1917-00. it's tricky, but you can do it. find an infocus authorized service center form their web site to buy it.
Will not regonize computer source
The projector looks for Horizontal sync & Vertical sync signals from the VGA source. If it finds these signals only then the source is connected. Even if the sync signals are found, the RGB switching should be working. Either there is a problem in sync circuitry or RGB switching. You need to be well conversant with the circuitry.
sonsunny
Mar 29, 2011 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Laptop display will not project onto screen
A couple of possibilities...
Connect a separate monitor to your laptop and verify that your laptop's external monitor port is functioning properly.
If yes, connect and power up the LP120. Press the source key on keypad. You should see the projector switch from video to computer.
Last option, does the projector display an "out of range" message on the screen. If so, reduce your laptop resolution to 1024 x x768.
Apr 05, 2010 | InFocus LP120 / 1000 Lumens / XGA / DLP...
My Infocus LP120 sometimes has a pink tint to the display. Sometimes it displays perfectly fine. any ideas?
make sure you have the correct input selected. if you're using a computer, make sure it's on computer and not component.
Mar 20, 2010 | InFocus LP120 / 1000 Lumens / XGA / DLP...
InFocus LP120 that will not power on.
it project?..but in 10 sec.it off? im pretty sure that the lamp ballast of your projector is defective. but if deadset? check the power supply and your power cord. if still not working your power supply board is defective.
Oct 28, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Infocus LP120 projector with the shakes
if you are refering to the image shaking, you need to replace the colorwheel. if you mean the projector physically shakes, replace the fans and/or the colorwheel. they are the only 2 moving parts in the machine.
Oct 14, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
How do I restore computer signal with InFocus DLP projector?
select the computer input through the menu, or press input. and make sure the resolution matches.
Sep 22, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
My LP120 says that no computer signal detected
May 18, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Jan 19, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Dan
Apr 09, 2008 | InFocus LP120 / 1000 Lumens / XGA / DLP...
jasbo
jasbo
