Question about Canon PIXMA iP4000 InkJet Photo Printer
Ip4000 firmware updating - Canon PIXMA iP4000 InkJet Photo Printer
Sansa/Sandisk m240/1.GB Firmware information. I would like to be able to download firmware software for this device. If not a link for the older version of the firmware. Or maybe some suggestions for...
good day sir hope that this will help you to your problem....
What is a firmware, and what does a Sansa Firmware Updater do? Firmware defined
Firmware is the software code that powers your Sansa player. SanDisk actively and periodically updates the capabilities, functionality, and reliability of your Sansa player through this firmware. For optimal experience with your Sansa player, SanDisk recommends that you update your firmware with each new release.Firmware updates are free.
The Sansa Firmware Updater is an application designed to deliver the latest firmware, software support, User Manuals right to your desktop.
Download Sansa Firmware Updater.
Sansa players supported by the Sansa Firmware Updater:
- Sansa c200 series
- Sansa Clip / Clip+
- Sansa e200 series
- Sansa Express
- Sansa Fuze
- Sansa Fuze+
- Sansa View
Supported OS:
Windows 7, Windows Vista, Windows XP, Windows 2000 SP4
NOT supported:
Mac & Linux
NOTE: Administrative access is needed on your PC to run the Sansa Firmware Updater.
if this help you please rate me sir thanks you...
Jun 05, 2011 | Computers & Internet
Canon ip4000 remove print head
Hi! You may access tha manual by clicking here. Please use the set up instruction manual (2nd m,anual from the top). Thanks for visiting FixYa.com!
Jun 06, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
IP4000 powers on for only one second and then dies
From the service manual, this complaint is caused by a power supply problem.
To repair, one needs to replace the power/logic board. This requires updating the EPROM after installing the board.
Solution - trash it and buy a new printer.
Jan 23, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
My canon ip4000 was working perfectly until yesterday. Suddenly it won't print the correct colors. Sometimes the nozzle check looks perfect, sometimes some colors are low, sometimes colors are mixed...
It could be a few different things but letys try the easiest first. Go into control pane/jprinters/ and do a deep nozzel cleaning. leave the printer idle for about a hour or two before trying to print again. You may have to repleat this procedure. If this does not fix your problem it could mean that you need to update a driver for your printer or that you have changed your colour settings in a graphic program such as adobe. Failing all else you may just need brand new cartridges. I have a canon i860 and found a very inexpensive site online to order the cartridges for a few dollars each. even if you don't need the cartridges right now check out the site and stock up.
http://www.piloshop.ca/index.php?main_page=advanced_search_result&search_in_description=1&keyword=canon+i+series+cartridges
Jan 09, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
I have a Canon Pixma IP4000 and keep getting this message: The printer is updating the firmware. Turn the printer off and then back on. If this message appears again, update the firmware once more. No idea...
What I suggest is that you go to this site http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=10239 and select the Operating System that's on your computer and download the latest drivers and then install them. This should correct any problems that you are having Bud
Dec 28, 2008 | Office Equipment & Supplies
Waste ink absorber full on canon pixma ip4000
cannon pixma ip4000 waste ink absorber is almost full what do i do, getting patchy printing, have cleaned and deap cleaned and this hasn't ;helped
Jul 23, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
14 people viewed this question
old marine
old marine
