Question about Garden
Are there different types of rain gauges? - Garden
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 32 Answers
There are a few different types of rain gauges. Standard rain gauges, Weighing percipitation gauges, tipping bucket rain gauge, optical rain gauge and the aucoustic rain gauge. They each measure rain in a different and some of them interesting ways.
Posted on Dec 29, 2013
Bought a new Dakota dash gauge panel and all gauges work but the fuel gauge.
There are different types of fuel gauge with slightly different working principles so it is important for you to know what type of gauge you have and the requirements of the circuit in order to wire it correctly and test it all if it doesn't work.
An internet search will furnish you with these details, below is such a search and links to a couple of results...
https://www.google.co.uk/search?q=different+types+of+fuel+gauges&rlz=1C1CAFB_enGB673GB676&oq=types+of+fuel+gauge%3F&aqs=chrome.3.69i57j0l4.18549j0j8&sourceid=chrome&ie=UTF-8
https://www.uniquecarsandparts.com.au/how_it_works_fuel_gauge
http://www.tpub.com/basae/57.htm
Mar 18, 2018 | Cars & Trucks
Tip
How to measure rain fall when your rain gauge overflows
Most rain gauges that you will make at home will only measure up to one inch of rain fall. The problem with this is that if you live in a place where you will get more than one inch of rain your measurement if taken incorrectly will be very skewed. If your rain gauge has been constructed correctly you should have a fail safe in place.
When you construct a rain gauge you should have a measuring tube inside of an over flow tube. The meausuring tube will hold about one inch of rain fall, but when more rain falls the inside tube will overflow into the outer tube. To measure the excess rain fall you will follow a few simple steps.
Start by reading the inner tube of the rain gauge and then carefully empty the tube. Make sure that you don't pour out the water that has overflowed into the outer tube.
Once all the water for the measuring tube has been emptied carefully pour the excess rain water into the measuring tube. To get the most accurate reading try your best to not spill any water out, you can pour the water over a bucket to make sure that if you do spill any out you will catch it and be able to measure accurately.
If there is a lot of overflow you might want to measure a little bit of overflow at a time to get an accurate read. As you measure, write down the measurements and when you finish add up the values to get the reading.
The readings are done in inches so you have a reading that is 1.00 and has an overflow that measures up to .50 then the total read out will 1.50 inches.
on Feb 02, 2014 | Garden
The Holman Digital Rain Gauge where do place the collection bucket.
You place it in the yard with at least 4 feet of distance from any object. Must be a clear place. If you cant do that place it in as open area as you can.
Jan 31, 2015 | Cameras
What is a rain gauge?
A rain gauge is also known as an udometer, its an instrument that is used to measure rain over a period of time.
Dec 29, 2013 | Garden
Difference between gauges and gages
A gauge is a measuring instrument ie rain gauge --oil pressure gauge--- temperature gauge
A gage is a pledge--thing deposited as security--a glove thrown down as in a challenge--in nautical terms it is a relative position as regards to the wind
(refer to pocket oxford dictionary)
Aug 25, 2013 | Cars & Trucks
I need a manual for Rain Harvesting Pty Ltd TATG02 Tank Gauge Level Indicator
You can find one on this page:
http://rainharvesting.com.au/products/measuring-a-monitoring/tank-gauge
Jul 07, 2013 | Rain-X Rain Harvesting Pty Ltd TATG02 Tank...
My rain gauge is from England... how much does each line on the gauge measure?
on the standard NOAA rain gauges using the metric system, each line is 0.2 mm
Jan 28, 2013 | Garden
What are the most common types of rain gauges?
standard NOAA rain gauges are the ones you are used to seeing. there are also weighing precipitation gauges, acoustic gauges, optical gauge, and tipping bucket gauges.
What does a simple rain guage consist of?
There are a variety of commercial rain gauges available on the market, however making a simple rain gauge is quick, easy and only costs as much as a plastic bottle. Chances are you already have everything you need to make this simple rain gauge, which is fun to construct, and interesting to use. Read on to learn how to make a simple rain gauge.
  1. Cut the top off of your plastic bottle. Cut about a quarter of the way down, to where the bottle begins to have a consistent diameter. Be careful to cut the edge as smoothly as possible, salvaging both pieces of the bottle.
  2. 2
    Remove the bottle cap and turn the top part of the bottle upside down, placing it into the bottom part. Connect the two halves with paper clips.
  3. 3
    Place the plastic bottle rain gauge in a location where it will easily collect rain without impediment from surrounding trees, plants or buildings.
  4. 4
    Help your rain gauge stand upright by placing it in a sand or gravel filled bucket. Simply make a hole in the sand or gravel large enough that half the bottle gauge sits into the pit. Use the gravel or sand to support the edges of the bottle gauge.
  5. 5
    Measure the amount of rain caught by your gauge by emptying the contents of the bottle rain gauge into a measuring cylinder.
Feb 07, 2011 | Home
Garden Logo
848 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
