Question about Ingersoll Rand Rotary Screw Compressor 230 Volts Single Phase 5 HP 185 CFM
Compressor oil capacity
Oil capacity
How much freon does a 2002 Chevy Tahoe take with a 4.8 v8.The system has already been evacuated and is ready to be recharged.
Should have a sticker on the radiator core support that shows how much it takes . But if your's is missing here
Refrigerant System Capacities
Application
Specification
Metric
English
PAG Oil GM P/N 12378526 for United States
PAG Oil GM P/N 88900060 for Canada
Accumulator Replacement
-ml*
- oz*
* Add 60 ml (2 oz.) of PAG oil, plus the equal amount of oil drained from the accumulator.
Compressor Replacement
60 ml
2 oz
Condenser Replacement
30 ml
1 oz
The Delphi replacement compressor is precharged without PAG oil.
The Denso replacement compressor is precharged with 237 ml (8.0 oz) of PAG oil.
Evaporator Replacement
90 ml
3 oz
Evaporator, Rear Replacement
90 ml
3 oz
If more than the specified amount of PAG oil was drained from a component, add the equal amount of oil drained.
Total System PAG Oil Capacity
240 ml
8 oz
Total System PAG Oil Capacity with Rear A/C
330 ml
11 oz
R-134a
Refrigerant Charge
0.8 kg
1.8 lb
Refrigerant Charge Utility with Front and Rear A/C
1.2 kg
2.7 lb
Refrigerant Charge Suburban with Front and Rear A/C
1.4 kg
3.0 lb
Mar 15, 2017 | 2002 Chevrolet Tahoe
Oil capacity air conditionercompressor 2010 holden cruze
the oil in an ac compressor is in the compressor on installation and does not need replacing or replenishing. The oil travels with the gas and is through out the system
you may get the oil capacity of a new compressor but you will need the compressor make,model and check on line to the compressor manufacturer as Holden will not have that information
Feb 12, 2015 | Holden Cars & Trucks
V09a1aa4ak oil capacity
There is no need to add oil to an ac compressor unless you have had a massive leak. new compressors come with the right amount of oil. The compressor oil circulates with the gas and by the time the gas pressure drops from a leak then the amount of oil leaked out is just a few drops. Excessive oil in the system stops the TX valve from working and causes problems . If still in doubt then talk to an accredited ac specialist
Aug 01, 2014 | 2010 Mazda 2 1.25i
What s the A/C compressor oil capacity in 2003 dodge durango with rear A/C
If it was shipped empty just add the amount that's stamped on the compressor. But most of the ones that I have seen where shipped wet/ full . to check get a beaker and simply remove the plugs and drain the oil into the beaker. when the system is opened it is recomended that you replace the RECEIVER DRYER also. if the compressor is damaged internally then you need to replace the EXPANSION VALVE also. hope this helps
_____________________________________________
Refrigerant Oil Capacities
Total System Fill - Front A/C Only 5.07 fl oz (150 ml) Total System Fill - Front and Rear A/C Only 7.40 fl oz (220 ml) Receiver/Drier 1.0 fl oz (30 ml) Front Evaporator 2.0 fl oz (60 ml) Rear Evaporator 1.0 fl oz (30 ml) Condenser 1.0 fl oz (30 ml) Compressor drain and measure the oil from the old compressor
Jun 28, 2014 | 2002 Dodge Durango
Ingersoll Rand ultra coolant oil for rotary compressor.
Jun 03, 2013 | Ingersoll Rand Compressors 5-HP,...
Clark c500 y55 oil capacity
I am guessing you may have put this question in the wrong category, you say hydraulic oil? This is the air compressor category, but all manuals for Clarke compressors can be found here
http://www.clarkeservice.co.uk/product_manuals/air_compressors.shtml
Oct 05, 2012 | Air Tools & Compressors
2003 jeep liberty air conditioning oil capacity
If the compressor is dry of oil (new compressors will either be shipped with or without oil) and you need to add oil you can never go wrong by adding three ounces. Once the compressor is installed turn it by hand several times. Then install the belt and add freon.
Aug 07, 2012 | 2003 Jeep Liberty
I am doing a full evacuation and recharger on a 1995 buick lesabre and I need to know how much compressor oil and the viscosity of the replacement oil Can anyone help?
r-134, 39 oz of freon, pag 150 oil, 8 oz oil, now that is the capacity for a new compressor and systen cleaned, or you need to drain yours old compressor and add half to the compressor and half into the accumalator/drier to have the correct oil amount in the system.
May 21, 2011 | 1995 Buick LeSabre
What is the A/C Compressor Oil Capacity in a 2002 Dodge Durango with the dual system?
The system oil capacity (Total- if all components replaced or flushed) is 10.0 oz. Manufacturer oil proceedure for the compressor alone is to drain and measure oil from the old compressor (make sure to turn shaft a few times to get it all out) and add the same amount of new oil to the new compressor. Chrysler says that you must use a sp15 PAG oil.
Note that you must flush the entire system when replacing the compressor in order for the warranty to be valid on the replacement part. Also require is the replacement of the drier assembly.
Have a great day!
Jan 21, 2011 | 2002 Dodge Durango
Oil capacity for craftsman air compressor circa 1978 model #106..
I have a 2hp craftsman air compessor with a two cylinder pump, Here is the info from my manual as far as oil capacitity:
Remove oil fill plug and slowly add
a compressor oil until it is even with the
top of the oil fill hole. NOTE: Do not
allow oil to be lower than 3/8"
from the top at any time. When filling
the crankcase, the oil flows very slowly
into the pump. If the oil is added too
quickly, it will overflow and appear to
be full. NOTE: Crankcase oil capacity is
approximately 16 fluid ounces.
I buy my compessor oil from Lowes in the tool department. It comes in 16oz and sells for about $3. I wouldnt worry about how many ounces it holds but rather that the oil level is to top of filler hole. Lowes also sells a synthetic oil for about $7 and is recommended for severe conditions (hot / cold / used all day). Good Luck!
Apr 25, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Ingersoll Rand Rotary Screw Compressor  230 Volts Single Phase 5 HP 185 CFM Logo
19 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
